Old 08-07-2012, 05:41 PM
Formulabruce's Avatar
Note the clock Knob, That is a '70- earlier 71 item only..
the lighting, or it sure looks like black plastic???
  #3562
Old 08-07-2012, 05:43 PM
edit repeat
  #3563
Old 08-07-2012, 06:10 PM
Norwood's Avatar
Norwood Norwood is offline
The speedo is not a 70.......
  #3564
Old 08-07-2012, 06:17 PM
njsteve's Avatar
njsteve njsteve is offline
Here is another shot from when I looked at the car a year or so ago. At the time, the car needed the engine rebuilt as it would lose oil pressure without notice. Probably an oil pump check valve issue. Hopefully that has been attended to.
It is one of the fluted black screw-on knobs which do have a different thread taper than the chrome knobs that used the center set screw. My December 1971 built 72 Formula had that black clock set knob.
  #3565
Old 08-07-2012, 07:01 PM
Brewster's Avatar
Brewster Brewster is offline
The knob could have been replaced since they do come off but you are correct in the fact a 73 would be chrome in appearance. Pretty cool car and hope if finds its way to a good home and owner.
  #3566
Old 08-08-2012, 10:22 AM
sd455hota's Avatar
sd455hota sd455hota is offline
Norwood, I sent you a PM for some stuff. Thanks
  #3567
Old 08-14-2012, 10:49 PM
For archival purposes, and in case anyone missed it in the general 70-73 threads :
The Red 73 SD Test Car used in several magazine tests of the day has been found and documented. Turned up in Australia - with Right hand drive conversion.
SD engine is gone. Car is still solid and otherwise held up pretty well overall for a car that had no special treatment and an unknown pedigree.
It is a "Y" code car, btw
Pretty interesting ordeal
Link to that thread :
http://forums.maxperformanceinc.com/...d.php?t=704249
  #3568
Old 08-15-2012, 07:12 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Unhappy YUCK!
Wow!
ID:	294573   Click image for larger version
ID:	294574   Click image for larger version
ID:	294575   Click image for larger version
ID:	294576   Click image for larger version
Regards,
"455HO" Lloyd
  #3569
Old 08-15-2012, 07:31 PM
Brewster's Avatar
Where and when??? Poor baby!
  #3570
Old 08-15-2012, 07:32 PM
Pepi's Avatar
Pepi Pepi is offline
Originally Posted by Lloyd-TX View Post
Wow!
OUCH
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #3571
Old 08-15-2012, 10:31 PM
Larry Navarro's Avatar
Mike Pergande's SD........pre-1990 before it went on the ISCA show circuit.
  #3572
Old 08-15-2012, 10:37 PM
Thanks for the info Larry -
was about to ask if this was the TA that Country Singer Randy Travis just wrecked this past week .
  #3573
Old 08-15-2012, 10:48 PM
Super Duty D's Avatar
Super Duty D Super Duty D is offline
Yep,
I forgot about those pictures.....remember seeing them...
Pergande had a red 73 SD auto too... I don't think that one was ever wrecked.
Board member here owns the red car now, it is a real nice car.
SDD
73 SD TA auto.
73 SD TA auto.
74 SD TA auto.
74 SD TA 4spd.
72 442 W-30 auto, post coupe Bamboo. 1 of 19 total.
90 300zx TT 5spd.
  #3574
Old 08-16-2012, 08:37 AM
So, the pics Lloyd posted are Pergande's SD?
  #3575
Old 08-16-2012, 09:19 AM
Brewster's Avatar
Thats Right! Then it was restored to a number one show car but I have never seen those pictures.
  #3576
Old 08-16-2012, 09:25 AM
Lloyd-TX's Avatar
Yep. Sitting forlornly in Gay Pontiac's (Dickinson, TX) body shop.
I can't recall if they repaired it and it later went to Sam Red for the resto and show paint, or if Sam did the entire job . . .
Regards,
"455HO" Lloyd
  #3577
Old 08-16-2012, 09:38 AM
Lloyd-TX's Avatar
Thumbs up
Originally Posted by Super Duty D View Post
Yep,
SDD
As far as I know Mike's red SD was never wrecked, EB.
Considering how bad the Brewster car looked in those old pics, it sure turned out nice . . .
Here are some "back in the day" shots of Mike's Buc Red car. Gotta dig those "Formula 1 Super Stock" tennies, and Mike's 'do as well!
ID:	294634   Click image for larger version
ID:	294635   Click image for larger version
ID:	294636   Click image for larger version
ID:	294637   Click image for larger version
Regards,
"455HO" Lloyd
  #3578
Old 08-16-2012, 12:03 PM
Brewster's Avatar
Correct Lloyd, that car never got damaged and still retains its original sheet metal today. The engine bay was covered with WD40 or something which was a pain in the @ss to remove however it probably saved allot of corrosion in the long run.
The car rarely see the light of day now a days and its to bad since it is a pretty darn nice ride.
  #3579
Old 08-16-2012, 12:08 PM
Norwood's Avatar
Check the PERFECT stance in picture #3
  #3580
Old 08-16-2012, 12:17 PM
Lloyd-TX's Avatar
Thumbs up
Yessir - I absolutely agree, Craig!
Regards,
"455HO" Lloyd
