Old 11-12-2012, 08:43 PM
85_SS's Avatar
85_SS 85_SS is offline
Default 1970 GTO - 2" rear drop w/ Air Lift
One thing I've wanted to do with my '70 GTO since I bought it was drop the rear end a touch. I don't know for sure, but I believe the rear springs were stock replacements, while the front end had a pretty decent drop, giving the car a pretty strong rake. A secondary problem I wanted to solve was that the car had the somewhat inherent problem of not sitting level in the rear (DS was ~1/2" lower than the PS).
I decided to get the look I was after with BMR 2" drop springs (SP015R) and an Air Lift 1000 bag kit (60744). While I thought the 2" drop might be a bit much, I could of course compensate for this with the air bags, and level the car out as well. Install was straight forward as you'd expect, however note that you will need to buy smaller clamps for the heat shields; the ones provided are far too big for any passenger car exhaust. Nothing really special here, just thought I'd share my install in case anyone else is looking to accomplish the same. For reference, tires are 245/60/15 rear and 225/60/15 front.
I mounted the air valve in a factory hole towards the rear of the frame rails. I would have liked to have used the factory location behind the plate, but I wanted the lines separated in order to adjust the bags individually:
ID:	302987   Click image for larger version
ID:	302988   Click image for larger version
ID:	302989   Click image for larger version
ID:	302990   Click image for larger version
Kevin's Homepage
1970 Pontiac GTO
Orbit Orange Judge Re-creation / YZ RAIII 400 / M21 4-Speed
1985 Chevrolet Monte Carlo SS
5.7 LITRE / TES Headers / SShaker Hood / WCT5 5-Speed
Old 11-12-2012, 08:59 PM
85_SS's Avatar
Old vs. New springs/bags:
I thought I had a better before picture, but this is the only one that really shows the difference in ride height:
Before:
After (you can see the wheel well gap is now gone in the rear):
Measurements were taken at centre of wheel well opening to bottom edge of the trim.
Before:
DS=26", PS=26.5"
After @ MAX 35PSI:
DS=27.5", PS=28"
After @ MIN 5PSI:
DS=25.5", PS=25.75"
...it is apparent by the measurements that the springs were not the issue (which I didn't suspect anyways), so I will have to run slightly different pressures to level out the rear of the car. I expect after some driving the springs will settle a bit and it may drop a touch more, but time will tell. It's not a huge difference, but has given me the look and flexibility I was after
Name:	side before.jpg
ID:	302997   Click image for larger version
Name:	side after.jpg
ID:	302998   Click image for larger version
Name:	2012-11-10 16.27.58.jpg
Kevin's Homepage
1970 Pontiac GTO
Old 11-12-2012, 09:47 PM
On the cheap, El Camino rear coil springs for '68-72 are shorter than normal stock height '68-72 A-body rear coils.
Old 11-12-2012, 09:54 PM
muscle_collector's Avatar
thats interesting, why did they make the elcs shorter i would have thought it would be the other way around.
Old 11-12-2012, 10:03 PM
Elco's of that era had factory airshocks. Believe that disappeared for '73 models...might have been a rare factory option on '73+, but I never saw them.
Old 11-12-2012, 11:16 PM
85_SS's Avatar
Good info, any idea how much difference there is? I considered the 1" drop BMR springs, but didn't want to take a chance on it not getting me where I wanted to be (which they likely wouldn't have considering the 2" drop springs only lowered the rear ~1/2" thus far). I was leary of this as I used 1.5" drop springs on my Monte several years ago and it didn't drop at all (although the springs that were in the car had surely sagged somewhat). The other issue was the car not sitting level from side to side, which was the main reason for deciding to go with air bags.
Kevin's Homepage
1970 Pontiac GTO
Old 11-13-2012, 02:02 AM
Did either of you guys see the show muscle cars on power block last week when the guy they had on siad he had 1 of 2 Judges that were orbit orange???? When he said that all I could do was laugh. I don't know where he got his info but The car was just a Judge with the std. engine the Ram Air III, not a IV. It was the guy who also had a sublime lime Road Runner with a 440 six-pac. His judge was nice but where he got hois info , someone was trying to feed him a big line of DODO.
Old 11-13-2012, 01:06 PM
2002Z4CSS's Avatar
Nice undercarriage.
1971 Pontiac GT-37
Old 11-13-2012, 01:31 PM
thats true i didnt think about that.
Old 11-15-2012, 12:35 AM
85_SS's Avatar
Originally Posted by 2002Z4CSS View Post
Nice undercarriage.
Thanks! I didn't build it, but I do my best to keep as clean as possible. Wiping down the undercarriage isn't fun, but I only do it once at the end of each season and it cleans up pretty easy with the gloss finish.
Kevin's Homepage
1970 Pontiac GTO
Old 12-06-2012, 11:12 PM
JimChevy JimChevy is offline
85SS- your car is sweeeet! Thanks for that info also. I'm going to try the bags. I see you made a heat shield.
Old 12-07-2012, 09:10 AM
4SLASH6's Avatar
4SLASH6 4SLASH6 is offline
nice work.......suspected the same after installing new coils on my car.I ended up adding an extra spring insulator ( or just the outer portion of one so it could lay flat with the other) to one of my rear coil springs to level rear of my goat.
70 GTO 400/[email protected]
Old 12-07-2012, 03:48 PM
pggto's Avatar
pggto pggto is offline
I like the stance, looks good! My 70 convert doesn't sit level, I have a big spring spacer on one side to level it out a bit, but it's still off. I might have to give this set up a try. did you notice any ride difference? May I ask what this set up cost? Thanks for the info.
Old 12-15-2012, 03:29 PM
85_SS's Avatar
Sorry for the late reply guys - I didn't get the reply notifications and haven't been on in a while (the little one in my profile pic keeps me pretty occupied ).
JimChevy - the Air Lift kit actually comes with the heat shields. The clamps they give you are far too big though; I bought some smaller stainless clamps.
pggto - I only had it out for a couple quick rides afterwards; it seemed to ride firmer with less body roll, but not overly stiff or harsh. Springs were $130 and the Air Lift kit was $88.
Kevin's Homepage
1970 Pontiac GTO
