Old 11-25-2012, 09:52 PM
6TEE8GTO's Avatar
6TEE8GTO 6TEE8GTO is offline
Lightbulb
Agree, Water Injection takes up "Air Molecule Space".
You basically reduce the chamber volume for air (which is needed to make the power when the right amount of fuel is added) so you possibly reduce the knock tendency but give up power doing it. Crappy fuel or the cost of fuel causes people to do lots of weird band-aids.
Tom Vaught
Water/Meth injection isn't a band-aid. It DOES raise effective octane rating. This is a proven fact. These systems are very popular with supercharged/turbo setups. The knock on them (pun intended) is that if the delivery vehicle (pump or nozzle or controller) fails, you can have a motor meltdown. In other words, when they work, they work as advertised- You can run more boost, more compression and more timing and make huge power with them. Several of the systems have fail-safe systems like sensors, low fluid interlocks, etc. But some guys opt for C16 for the peace of mind.
You can wire a retard system where, if the system fail-safes are triggered (for example if the fluid level in the tank runs low) then timing is pulled way back to prevent meltdown. These can be incorporated into a non-boosted app as well.
There's pros and cons for sure guys, but it's not really correct to refer to meth injection as a band air or to say it does not raise octane rating of the fuel it's mixed with in the intake system, because it most certainly does.
GREG'S GOATS:
1970 GTO Judge
RA-III, 4-SPD & A/C. Power Windows, Power Seat, Power Brakes, Steering, AM/FM, 8-Track, Formula Wheel, Rallye Gauges, Remote Mirror, Numbers Matching. Assembled at Pontiac, MI Plant 5/26/1970.
1968 GTO
461 CI, RA-III heads, Hotchkis springs, UMI suspension, Bilstein shocks, 12-bolt 3.73's.
1966 GTO Ragtop
4-Speed, AM/FM, Original driveline.
Old 11-25-2012, 10:37 PM
Goat-Racer's Avatar
Goat-Racer Goat-Racer is offline
No doubt that in a boosted application. the WM system can be a huge benefit. The basis of this discussion though is use in a naturally aspirated engine. I think thats where things can differ a bit. Every combination will respond different.
Brian Rock
'65 GTO - Pump gas 496" IA2 w/ High Ports, 200-4R trans, 3.73 gears, 275 Hoosier radials, and 3925 lbs.
9.88 @ 134 N/A on Cali 91 octane.
http://www.youtube.com/watch?v=NJEIY5OJ68g
Old 11-25-2012, 10:57 PM
6TEE8GTO's Avatar
Lightbulb
Agreed, and the thing I should clarify is Tom said "water injection" and I should have read closer. The methanol and water mix however will work on an NA motor also for raising effective octane rating.
In your case, I think you are right; your mixture was probably not of benefit to your application and any benefit of reduced detonation was offset by the the fact that higher octane fuel burns slower and makes LESS power if you don't need it. You obviously know what you're doing, so I assume you tried to run more timing with the meth and it didn't matter. You were in competition and didn't have time to start experimenting with the mixture, you wanted to WIN. (Congrats by the way!)
But we shouldn't discount the possibilities here. If you have a high compression N/A motor combo that needs 110 or 116 to be able to run aggressive timing advance, you could opt for a meth kit and properly setup it could cost less than race gas in the long run and be a lot more convenient.
I think most guys haven't looked at this for an NA setup because the kits have been marketed to the blower/turbo crowd.
Snow's 20020 kit is for N/A combos. And another guy mentioned AIS, I know Rodney, he sold me a kit several years back for one of my Mustangs. I had a Novi 2000 on a big-bore 347 and it was a very comprehensive kit. AIS also makes an NA kit with a pump in the tank.
Not trying to cause trouble here, hope I'm not being seen that way. Just trying to add to the discussion is all..
GREG'S GOATS:
1970 GTO Judge
1968 GTO
1966 GTO Ragtop
Old 11-25-2012, 11:02 PM
Goat-Racer's Avatar
No hurt feelings here. I'm sure that is some potential on a higher compression NA engine as well. I'm totally sold on the boosted applications!
Brian Rock
Old 11-25-2012, 11:53 PM
6TEE8GTO's Avatar
Lightbulb
Michael Plummer is a Snow Performance distributor. This is from his FAQ section (I've known Mike a long time from a Mustang site I've been a member of for 15 years)
3. Does the Snow Performance system work a carbureted application?
Yes.
We have systems for carbureted vehicles without superchargers or turbochargers. They inject according to vacuum and deliver 20-25 point octane gains over regular pump gas when using a 50/50 mix of water/methanol.
Any Snow Performance system can be used with or feature the special 4150 or 4500 style carb plates as well. MC and RT series systems include the carb plates.
Many muscle cars that previously required expensive high octane fuel now use regular pump gas with our system while getting better performance. These cars can use our MC (naturally aspirated) series systems for a clean installation and great results.
GREG'S GOATS:
1970 GTO Judge
1968 GTO
1966 GTO Ragtop
Old 11-26-2012, 12:40 AM
60man's Avatar
60man 60man is offline
Thanks for all the discussion !!!
I "thought" that the Snow kit for NA had a fail safe built into it ?
It would not activate the controller if water/meth mix was low.
I meant to record his (Snow's) appearance on Horsepower.
In my case my CR is 14.58 -1. I am after cooler temps as well as a little more power and saving $$$ doesn't hurt. As hot as the center ports on our Pontiac's get the cooler the better..IMO. Can't hurt..
If I'm correct this stuff was originally used to give our WWII planes with super chargers a kick in the butt at higher altitudes to outperform our adversaries..without blowing them up..
I still think I'm going with the E85....but not a 100% sure..?
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 11-27-2012, 09:29 AM
70 lucerne lemans's Avatar
70 lucerne lemans 70 lucerne lemans is offline
Thumbs up
You'll be happy with E85 Troy,been running it for 3 years,no issues.My car sat for over 6 months this year,didn't drain the fuel,no issues.Gene also runs it and loves it!
Mark
1970 Lemans Convertible,462,6x-4, 234/242 cam.3.42 posi.12.55@109,4100 lbs...SOLD....
1968 Firebird , 467 , KRE d-ports ,stock type suspension,3100lbs
(1.30 60')(6.08 1/8)(113.43)different runs 9.59 @140.71 on E85 all motor
[email protected] on 150 shot
