Old 12-12-2012, 04:39 AM
crustysarge crustysarge is offline
Default Dash Interchange
I am working on a 70 Lemans Sport and the dash is really bad, I mean super cracked into pieces on top. I have a cover I was going to try and use but a few days ago a guy I know emailed me and said he has a nice 69 dash he would take $350 for, also has a KM speedo for export that I'd like to get my hands on but he wants $225 for it, pristine but pricey.
Anyway, will the 69 dash fit the 70? Are they the same? This is my first A body so I know very little about them.
Old 12-12-2012, 08:22 AM
carguy66cars's Avatar
carguy66cars carguy66cars is offline
Yep, Will bolt in and with wiring harness and all if he has it. If not the '70 dash harness will work also as it does use the same guages and heater controls. I know of one that has a '60 dash in it!
Lyn.
'72 400 M22 4-speed Lemans Sport GT
'72 400 4-speed Luxury Lemans
'72 Luxury Lemans 4dr. hardtop 45,000 mile car
'72 Lemans 2dr. 20,000 mile car [sold]
'73 Grandville backhalfed Drag Car
'73 Grand Am 400 4-speed
'74 Lemans Sport Coupe-4800 original miles
Old 12-12-2012, 09:51 AM
pggto's Avatar
pggto pggto is offline
It may fit but its not going to look right. The 69 in different around the gauges than the 70. Just google dash faces for both years and you will see the difference. The 70-72 are pretty much the same, the only difference is the 72 has the word Pontiac above the glove box door.
Old 12-12-2012, 07:31 PM
gloryrestoparts's Avatar
gloryrestoparts gloryrestoparts is offline
bought my 70 with a 69 GTO dash in it. The entire unit will work. This winter I'm swapping it to the correct 70 setup though.
http://gloryrestoparts.20megsfree.com/
1970.5 Pontiac Tempest GT-37
400ci 4bbl 4sp 3.90:1
12.73 @ 112.42 2011 Pure Stock Drags
12.71 @ 110.58 2013 Martin FAST/FS race
12.70 @ 111.74 2014 Pure Stock Drags
12.60 @ 111.66 2015 Martin FAST/FS race
1968 Pontiac Firebird 400
TH400/3.08 open
export car - factory heater delete
14.48 @ 95.86 w/ 2.14 60' 2018 Pure Stock Drags
14.47 @ 95.02 w/ 2.16 60' 2019 Martin FAST/FS race
Old 12-12-2012, 09:34 PM
PonchoV8 PonchoV8 is offline
Doesn't he also need the glove box door? Doesn't the '70 and up have a little flare on one end that the '69 doesn't have?
Old 12-13-2012, 02:24 PM
yep, the glove box lock is also different
TH400/3.08 open
Old 12-13-2012, 04:50 PM
Thanks guys, I will just cover my old ratty dash first and see how it looks.
Old 12-13-2012, 05:59 PM
sarge, on the massively cracked original dashes, one can take a razor blade & cut down the erupting areas along the big crack, then fill the crack in with expandable foam, then carve & sand it flat. it will end up giving a better structure to glue the molded dash cover to.
Old 12-25-2012, 04:06 PM
chuckmnv's Avatar
chuckmnv chuckmnv is offline
OPH -
Thanks for that tip. I have the same situation and the dash cover to install at some point. I intend to change the color from black to gray first, tho.
If the rules don't say something is illegal, I have to assume it is legal -- Smokey Yunick
