Old 12-17-2012, 11:33 PM
UnchainedGTO's Avatar
UnchainedGTO UnchainedGTO is offline
Default Ignition Issues?
My 79 TA is having intermitent stalling issues. When running it runs perfectly. The other night it died while I was rounding a corner. Wouldn't start at all. It was acting like it was not getting any spark. Once I had it towed to the house it fired right back up. The car has a stock HEI with a MSD box. I am leaning on pulling the MSD. Any thoughts?
Thank you,
Unchained
Old 12-17-2012, 11:58 PM
lust4speed's Avatar
Before doing anything, try and confirm whether it is an ignition problem. Carry an extra spark plug with you and when it quits, pull a sparkplug wire and insert the sparkplug and set it on the valve cover. Turn over the engine and look for spark. If you have spark, move on to the fuel system. If no spark, I'd still look for bad connections (corroded or loose) before pulling out the MSD.
Mick Batson
Old 12-18-2012, 04:52 PM
Aus Goat Aus Goat is offline
i am going for loose wire .What work have you done since the last time everything was running right . Also check grounds
[QUOTE]When running it runs perfectly. The other night it died while I was rounding a corner. Wouldn't start at all. It was acting like it was not getting any spark. Once I had it towed to the house it fired right back up/QUOTE
Old 12-18-2012, 05:06 PM
Mr. G Mr. G is offline
Make sure the battery is tied down and that the positive side is not touching any grounded metal.
Old 12-18-2012, 11:58 PM
All good suggestions. I will comb through the wiring this weekend. The battery is stationary and not budging. I plan to check the rear fuel lines as well just to make sure there are no cracks letting in air.
Old 12-19-2012, 12:02 AM
I had the same problem about a month ago. I had a bad wire connector from the ignition switch to the BATT side of the HEI. Next time it stops on you, see if you have 12v at that point.
Old 12-19-2012, 08:15 AM
gtome's Avatar
gtome gtome is offline
Mine used to do that. But mine was the module would fail when it got hot. When it cooled down it would fire again.
Old 12-19-2012, 08:22 AM
Is the coil in the cap? Next time it dies, put your hand on the cap where the coil is. If that thing is hot enough where you can't keep your hand on it, it's the coil. I had that issue when running an MSD with an HEI. Twice.
Old 12-20-2012, 12:05 AM
A.W.Dille A.W.Dille is offline
I had a similiar issue with my Grand Prix a few years ago. Turned out to be the pick-up unit in the distributor went bad. Replaced it and haven't had any issues since. Might be worth checking.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear
85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book.
87 F350 6.9 4 speed dually
A poor man has poor ways.
Old 12-20-2012, 11:57 PM
Batman's Avatar
Batman Batman is offline
I think you've gotten some good advice. I've had many HEI modules over the years that went intermittent like that before complete failure. I usually keep an assortment of known good modules on hand.
If you're running an electric fuel pump they will sometimes give you the same symptoms before failing completely.
An ignition failure cuts the engine off instantly like a switch was thrown while a fuel pump will usually sputter to a halt.
