This is my current setup as of right now (basic rebuild) with the addition of the 73 GTO 350 heads I'm about to put on and was just wondering if I should go with different rockers/rods or stick to factory?
ENGINE 77 400 (L78) Rebuild bored 60 over Edelbrock 2157 performance plus cam/lifters Edelbrock performer Intake new cast pistons Crank turned 10 new cam bearings new main rod bearings all new freeze plugs block was decked and line bored new elderbrock valve springs install new bronze valve guides and they also got a three angle valve job and new push rods. HEADS #46 heads (74' 350 GTO), I took them to Long's Racing Engines to have them worked on. They did a complete valve job (2.11), milled heads, bowl job, replaced guides, valves, seals. |
Wow! I thought someone would of had some kind of advice...
Might get more comments in the street section.
