Old 01-30-2013, 07:34 PM
74gto's Avatar
74gto 74gto is offline
Default 2003 Chevy 2500 HD Transfer Case Question
Have a 261HD transfer case for the above truck that let go. It had the dreaded oil pump moving around problem that wears a hole in the transfer case. About a year and a half ago, it developed a small hole and blew all the ATF out the case. JB welded the case back together and added fluid. Worked fine till last week when pushing snow, it died. Took it out of the truck and split the case. Am trying to get the oil pump and shaft half out of the case, but it won't slide. The breakdown looks like their is a clip behind the oil pump, but you can't get to it till you get the shaft slid out. I can't het the shaft slid out. Any tricks to this??
Again, this is the 261HD transfer case, which has the manual engagement in the cab, not electronic. Any help appreciated. Thanks, JOHM
74 GTO 406 T400
74 Firebird 350 4-speed
68 GTO Convertible 400 T400
76 GP LJ 400 4BBL T400
78 Chevy 1/2 Ton Truck
Oh yea I love my wife very much
For some reason it got erased when I put it here last time!!!!!! hmmmmmmmm
Old 01-31-2013, 10:47 AM
74gto's Avatar
Found the acces hole for the clip. No brainer really, just was'nt paying attention
74 GTO 406 T400
Old 01-31-2013, 10:31 PM
sonjaab's Avatar
sonjaab sonjaab is offline
Ah............The dreaded "pump rub" issue !
72 Lemans Sport convt., 84 Z-28, 13 Chevy Impala,
94 Buick, 77 Triumph Bonneville
Old 01-31-2013, 11:03 PM
FrankieT/A's Avatar
Did you buy the kit that fixes the prob? I had the same prob on my son's Tahoe. Put in the kit for $70.00. Permanent fix!
Old 01-31-2013, 11:48 PM
sonjaab's Avatar
This effects all late model New Process GM cases in both the 1/2 and 3/4 tons.
The dreaded issue and the Merchant Auto "fix kit cure" link
http://www.merchant-automotive.com/t...grade-kit.aspx
ID:	311748   Click image for larger version
Old 02-01-2013, 10:00 AM
FrankieT/A's Avatar
That's the kit I used. However, the real trick is to install it before the problem surfaces. Before the the hole is worn through. But, it is real quality piece. Plus a relatively easy fix for anybody mechanically inclined.
