Old 03-04-2013, 03:22 PM
Felix C's Avatar
Felix C Felix C is offline
Default Which intake for a street engine with a mild camshaft?
RAIV reproduction with Q-jet
Edelbrock performer with AFB
Edelbrock Performer RPM with AFB
Selection above to be port matched to the intake ports.
Is the Edelbrock Performer basically the standard intake? and their RPM a Performer but with a cast in spacer beneath the carb?
Old 03-04-2013, 04:20 PM
66bonne's Avatar
66bonne 66bonne is offline
The Performer is basically an aluminum cast that is not much better if at all then a stock intake. Yes, the RPM is a "high rise" version and will generally outperform a stock intake. I like AFBs and their E-brock clones as they are a very simple carb and I have run them on all my daily drivers. Prefer Holley and Holley style carbs for performance.
Just my 2 cents from personal experience.
Jim
Old 03-04-2013, 04:25 PM
Felix C's Avatar
Thanks. Have not worked on Pontiac since the mid-1980s. We owned a 1970 and 1979 Trans Am in our family. Brother and I are considered a Trans Am/Formula purchase and building a mild vehicle as we had in our late teens. Assembling a budget on how much to expect.
We did a RAIV intake + Q-jet, + 068 Camshaft + Hooker headers + 7K3 heads, etc.etc. back in the day.
Old 03-04-2013, 07:28 PM
Edel Spreadbore P4B (on my GTO when the Torker I isn't) or Repop RAIV ( i know nothignabout them)
Old 03-04-2013, 09:29 PM
A.W.Dille A.W.Dille is offline
From personal experience I have sound a stock iron intake on the 400 in my GTO to outperform the Edelbrock Performer. When I was still racing my GTO the best it ran in the eighth was an 8.72 with a Performer, with a Torker1 an 8.52 and the stock an 8.46, broke a motor mount and trans mount on the first pass right after putting on the stock iron so couldn't stay into it for good shifts. Difference in sixty foot times were dramatic, Performer's best was a 2.12, Torker a 1.92 and the stock a 1.80 (all with slicks). Have never ran one of the reproduction RAIV's so can't give any input on them. When I was racing I ran an 800 spreadbore Holley, now I run Q-jets and quite happy with them. My .02.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear
85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book.
87 F350 6.9 4 speed dually
A poor man has poor ways.
Old 03-04-2013, 09:33 PM
paul s.'s Avatar
paul s. paul s. is offline
I would say it depends on the displacement, tranny, gearing and vehicle weight. Just how mild is the cam?
If the engine will be a smaller displacement and it will be loaded right off idle, then smaller runners would be called for.
Sandoval Performance
www.sandovalperformance.com
Pontiac Crate Engines
CNC Edelbrock heads
Custom Ground Cams
JOHNSON Limited Travel Hydraulic Roller Lifters
Old 03-04-2013, 09:37 PM
Felix C's Avatar
400CID
Super T-10
3.23 or 3.42
3720lbs
Camshaft still undecided. 5500rpm peak. Still learning what is new today and applying modern methods to camshaft selection.
Edelbrock aluminum D-ports.
10.5:1
Old 03-04-2013, 09:46 PM
frankyboy455 frankyboy455 is offline
stock cast iron would be the best in your case but repro RA IV would be great for the cool factor, I don't think you'd loose a lot compared to a stock cast iron.
Old 03-05-2013, 08:21 AM
2002Z4CSS's Avatar
I have the Edlebrock Performer intake and a Holley 750 vacuum secondary carb. Works welll with my 400.
1971 Pontiac GT-37
Old 03-05-2013, 11:31 AM
Felix C's Avatar
I note the cast iron is often recommended in previous threads here and other Pontiac forums. Is the previously held assumption that aluminum runs cooler and provides a denser a/f charge than cast iron incorrect? Same with the benefit the air-gap in the RAIV when the heat crossover plate is not in use? How about taller dual plane intakes provide more torque than shorter ones due to ram tuning? There was also the belief in the benefit of no hot oil splashing on the bottom of manifold runners holding the a/f charge.
A great deal has changed in what works and what does not?
Old 03-05-2013, 01:22 PM
ta man ta man is offline
Originally Posted by Felix C View Post
400CID
Super T-10
3.23 or 3.42
3720lbs
10.5:1
I looked at this thread quickly and thought it was a mild engine build but do you actually have the Aluminum d ports?What are your goals with this combo?No sense wasting the potential of those heads.If you haven't bought them yet maybe buy a camshaft/head"package "from one of the Pontiac vendors.
Old 03-07-2013, 01:18 PM
GTOLou GTOLou is offline
Are the repro IV intakes better than they used to be? Runners line up, etc??
Agree with TAman - you've got the makings of a sweet combo. With a decent cam and headers - I'd go with an RPM. Would not go to a single plane with a 400. Just me.
Let us know more about your cam choice.
Old 03-07-2013, 02:31 PM
surfsama's Avatar
surfsama surfsama is offline
Careful with repo Ram Air IV manifolds. I'm not saying this is how they all look but this is what I got and I had to eat the shipping costs both ways.
The bottom manifold is my stock unit to compare.
Old 03-07-2013, 03:06 PM
Tim Corcoran's Avatar
Factory Q-Jet intake would be the best choice.
Tim Corcoran
Old 03-08-2013, 09:33 AM
Felix C's Avatar
Surfsama regarding post #13.......Thank you for that heads up!!
What a mess. Hopefully epoxy can be used to correct the poor runners. I will confirm what expected conditions are before purchasing one of these if I go this route.
Are these made in China? What terrible quality control.
Old 03-08-2013, 09:43 AM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Default intake
When I was deciding to go back to a factory intake I steered away from
the repo and picked up a 69 iron intake and saved myself some cash and heartache.
Would love to have an aluminum style factory intake but want ports to line up better than that. I am in awe they run/seal that way.
Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds
Old 03-08-2013, 10:50 AM
Mr Twister's Avatar
That intake above looks bad. What is it? I did not catch it as I read thru the posts.
If you are going to run E-heads then you should consider a manifold that best suits the head/cam/intake package. I think that there a lot of posts that go along with the "stock intake is better" bandwagon based on web postings vice dyno time or dragstrip results. There are some proven instances where the iron intake has outperformed aftermarket ones but I think that there is much more to the puzzle. Search here in depth or just call the Pontiac vendor where you are getting the parts and ask them.
Old 03-08-2013, 10:57 AM
Felix C's Avatar
The intake with the misshapen ports is a reproduction from an unknown manufacturer.
Yes, I know it is about combo. Yes, I am searching mucho.
Old 03-08-2013, 12:06 PM
tom s tom s is offline
Since your in FLA why not get a hold of Ken and have him help you put a proper complete package together for your needs?Guys like him do this everyday for a living?He post here under Pontiac Dude.Tom
Old 03-08-2013, 12:21 PM
Felix C's Avatar
That is good advice but I will tell you this. I learned how to tune my LS1 rather than use a tuner. Installed my own parts and even designed my own custom camshaft. Results have all been as expected. I do this as an informed hobby and the route getting to where I want to be at is as interesting as finally getting there.
I pay a shop for aspects I cannot do myself-machining, dyno rental, etc.
