OHC-6 TECH Over Head Cam projects, questions and advice.
Old 03-24-2013, 02:41 PM
Jeff Hamlin's Avatar
Question Crankshaft # ID
Tearing down a '69 250 Sprint and came across a number I am not sure of.
It's either 3878802 or 9878802 I don't have anything on my list for this one.
Any help identifying greatly appreciated.
Old 03-24-2013, 03:55 PM
PMD1969's Avatar
PMD1969 PMD1969 is offline
Not able to answer your question but it does raise another.
Check and see if the 69 Sprint Rods are "special" or not. Do they look like all the other rods that our OHC's use or are they different? Pics?
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213)
99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale
http://sohcsix.yuku.com/forums/1/OHC-lounge
Wanted: 1969 OHC "H" Camshaft
Old 03-24-2013, 06:39 PM
hpp's Avatar
hpp hpp is offline
Looks like the same casting # thats on my 69' 250 1bbl crank
I think your casting # is actually 3876802
Name:	OHC 4bbl Y pipe 009.jpg
ID:	317395   Click image for larger version
Name:	OHC 4bbl Y pipe 010.jpg
Old 03-24-2013, 08:01 PM
whew,
Thanks I was beginning to think it was a Chebby crank swap.
Old 03-24-2013, 08:12 PM
FYI;
Rods are no different the any of the others I have on hand.
Old 03-24-2013, 08:29 PM
hpp's Avatar
hpp hpp is offline
Almost looks like the only difference between the 1bbl and 4 bbl crank is more holes drilled into the 4bbl cranks counterweights.
How do the journals look will the crank need any machine work or just a polish?
Old 03-24-2013, 08:37 PM
Cammer-6 Cammer-6 is offline
Originally Posted by Jeff Hamlin View Post
FYI;
would you please REPEAT that very loudly for those that are hard of hearing
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 03-24-2013, 08:41 PM
that will vary from one crank to the next
only part of rotating assembly that differs from 1 to 4bbl was the damper and bearings
Old 03-25-2013, 05:54 AM
NOW HEAR THIS,
THERE IS NO DIFFERENCE BETWEEN THESE RODS AND THE OTHERS I HAVE IN STOCK!
THAT IS ALL.
Old 03-25-2013, 11:23 AM
NOW HEAR THIS,
THAT IS ALL.
HIS?
Old 03-25-2013, 11:26 AM
PMD1969's Avatar
NOW HEAR THIS,
THAT IS ALL.
ROTFLMAO
Old 03-25-2013, 11:48 AM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
lol
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
Old 04-17-2023, 07:29 PM
In_The_Pink In_The_Pink is offline
Just discovered the crankshaft in my '68 casting date 250 is also 3876802. A quick online search seems to indicate this is a Chevy crank. Is this in fact a correct/original Pontiac part/part number, shared with Chevy I6 engines?
Old 04-18-2023, 06:27 AM
OHC CRANKSHAFT NUMBERS I HAVE ON FILE;
9782279 ‘66-67-230
9790154 ‘68-69-250
3876802 ’69-250
Old 04-18-2023, 09:48 AM
Thanks, Jeff. I had seen the first two listed online, but not the third number, so thanks for confirming.
