Old 04-01-2013, 03:25 PM
njsteve's Avatar
njsteve njsteve is offline
Go to your "PRIVATE MESSAGES" tab in the upper right hand corner of this page. On the left side there will be a link for "edit your avatar." Click on "Use Custom Avatar." Then you can browse your own photos on your computer. Best bet is to reduce the size of one of your existing photos to around 100 MB otherwise it will keep getting rejected as too large.
  #862
Old 04-01-2013, 03:57 PM
weranc55's Avatar
weranc55 weranc55 is offline
Thanks. Got it.
  #863
Old 04-01-2013, 04:10 PM
weranc55, For some twisted reason, I love that picture in your avatar, good to see it again.
Originally Posted by weranc55 View Post
Thanks. Got it.
  #864
Old 04-01-2013, 06:01 PM
weranc55's Avatar
Mine is not as bad as the one TAkid455 has.
  #865
Old 04-01-2013, 06:15 PM
njsteve's Avatar
Look what I found! I was perusing ebay one Sunday morning, a couple weeks ago, right after someone listed this alternator. It's the exact one I needed for my car. I emailed the seller and asked him what he wanted for the alternator. He said $50. I had him send me a paypal invoice and I bought it immediately. It arrived today and I had it tested at the auto parts store and it works fine.
It's a 1101015 80 amp with a 1M14 date code. If I deduce correctly, that is December 14, 1971, perfect for my Jan 11, 1972 shipped car. This is a real oddball piece since they only came on the Firebirds with A/C and electric rear window defogger with the heating elements in the rear glass.
I disassembled it this afternoon and I am soaking the case in the trusty old Purplestuff degreaser at the moment. I found a new front bearing for it in my box of alternator parts and it should be good to go.
  #866
Old 04-01-2013, 07:36 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
wow, great find Steve, those are like hens teeth especially with the right date code for your car! They skipped the I's on the months on many electrical parts so I think you are right on the date.
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #867
Old 04-01-2013, 09:16 PM
Pepi's Avatar
Pepi Pepi is offline
Nice find Steve. What search were you looking under when you found it?
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #868
Old 04-01-2013, 09:45 PM
Held for Ransom's Avatar
Probably 1101015.
http://cgi.ebay.com/ebaymotors/ws/eB...m=190815866622
  #869
Old 04-01-2013, 09:48 PM
Pepi's Avatar
Thanks HFR, I was trying to look and keep forgetting about looking under closed auctions.
  #870
Old 04-02-2013, 03:01 AM
Formulabruce's Avatar
Sweet find!! All the ones I find have some part of the case broken, I wonder if its vibration from the odd way its mounted.. Grats Again!!
  #871
Old 04-02-2013, 06:48 AM
njsteve's Avatar
I think the broken case is from people trying to draw the rear of the case toward the rear bracket on the intake, instead of loosening the intake bracket and adjusting it up close against the alternator case before tightening. The alternator on my grandmother's car has the rear bolt boss broken out because of that.
  #872
Old 04-06-2013, 08:05 PM
njsteve's Avatar
I got some more of the welding done at the Votech class last week. I finished up the bodywork on the passenger side trunk drop off and the large rust hole in the outer wheel tub. Luckily the rocker panel rail end was fine. As I mentioned before, anywhere that there was a large concentration of body seam sealer/caulking is where the rust occurred. Once that stuff gets old, it acts just like a sponge and holds the water next to the metal until the metal rusts away.
Here's the finished trunk drop off on the pass side:
And here is the before shot of the rust hole in the front of the passenger side wheel well:
And after I surgically removed the rusty portions and welded in a section of the reproduction outer wheel tub, and finished the body work, seam sealer, and partially undercoated it:
And for comparison's sake, here is the wheel well from Gramma's 75 Firebird in all its sloppily applied seam sealer glory:
  #873
Old 04-06-2013, 11:20 PM
Wow, Nice!!! I noticed the long crack in the seam sealer on the 75 too......hope its high and dry
  #874
Old 04-07-2013, 06:35 AM
njsteve's Avatar
It's not a crack, it is an optical illusion due to the angle of the camera flash. It is actually a shadow on the side of the tall, goopy stream of seam sealer/undercoating/body shutz. Some of the seam sealer strings are an inch thick and three inches wide. It's like they were having an undercoating gun fight that day on the Norwood assembly line when Gramma's car was built.
  #875
Old 04-07-2013, 06:54 AM
LeighP's Avatar
LeighP LeighP is offline
THAT is one neat repair!
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
  #876
Old 04-07-2013, 10:34 AM
njsteve's Avatar
I put the alternator back together after some parts cleaning. I soaked the case in the Purplestuff for a couple days and scrubbed it with a brass wire scrub brush (something softer than the cast metal case). I then used some 0000 steel wool and Orangestuff hand cleaner and gently scrubbed the outside of the case under really hot water. It turned out great, it has that just tumbled look out of the casting mold.
As for the pulley and fan blade, they turned out to be just dirty. The original silver cad plating on the pully cleaned up nicely. The finish on the back half of the pulley was perfect, the front half, not as nice due to being out in the elements all these years. The fan blade still retained its original grey phosphate finish and just needed some soaking in the Purplestuff degreaser and scrubbing with a plastic scrub brush. After seeing the original finish on the pulley and fan blade, and all the cobwebs inside, it looks like this alternator had never been apart in 42 years, so it retained all its factory hardware after all this time. The only repair needed was a new front bearing and to heli-coil the upper mounting bolt hole which is always stripped out on these cases.
And you can even see the part number and date code on it now!
  #877
Old 04-07-2013, 11:44 AM
I like it. Looks great.
  #878
Old 04-07-2013, 12:45 PM
sweet!! lots of luck you had finding one, and the finish work is impressive!
Are you interested in doing some promo work for the "purple Stuff" ?? Im sure you have far exceeded their plan for ideas for uses!!
edit. Im going to put some purple stuff in a steam cleaner ( Not a pressure washer, in its soap basin) in a month to finish the rear underside of my car..I wonder how sudzy it might get ... Purple steam for the win?? hehe
  #879
Old 04-07-2013, 01:07 PM
njsteve's Avatar
They should sponsor me! After 8 years of reusing the same 4 gallons of purplestuff for soaking, plastic paint stripping, and degreasing, I am down to my last gallon. I might have to actually buy some more soon.
If they won't sponsor me, I will have to move on to using the orangestuff!
  #880
Old 04-07-2013, 10:17 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
Where do you get this purple stuff and oranges tuff you speak of?
I'm doing a bunch of work on a '69 Chevelle right now and would like to get a good cleaner/degreaser.
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
