Old 04-15-2013, 11:19 AM
Michael Brand F/SA Michael Brand F/SA is offline
Default 1973 Formula - Hood Question
Hello,
I'm looking for information on the hoods that came on the 455 4X Formula Firebirds for 1973. Did any of them come with the flat or trans am hoods or did they only come with the formula hood?
Thanks so much,
Michael
Old 04-15-2013, 11:29 AM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
Just the Formula 455SD cars got the shaker so the standard 455 Formula would have come with the twin scoop Formula hood. No Formulas came with the flat hood regardless of engine option.
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
Old 04-18-2013, 12:42 PM
unruhjonny's Avatar
The only reason why the 1973-1974 Formula Super Duty 455 cars came wit hthe shaker hood was because of emmisson's testing, as I recall reading, the certification was done with the shaker aircleaner, and to certify for the Formula air cleaner would have been another round of testing.
In summary:
all 1970-1975 Formulas, with the sole exception of the 1973-1974 SD-455 cars, came with the same "Formula" hood.
1970 Formula 400
Old 04-18-2013, 01:00 PM
Formulabruce's Avatar
In summary:
I read it was actually noise related certification...guess I need to do more research
Old 04-18-2013, 02:11 PM
Norwood's Avatar
Norwood Norwood is offline
That's why they put the block off plate on
Old 04-18-2013, 02:30 PM
bird72's Avatar
bird72 bird72 is offline
one of the quirks of emerging by 73 "rules" and such..... one could get an open scooped proper Formula hood ram air D port Formula 455 in 1973, or a cool round port thumper with a stopped up shaker to confuse it's Formula identity and make it forever a WTH? car we are still discussing.
I understand the shaker was stopped up due to noise, which seems silly in itself. I take it the now stopped shaker SD engine was certified EPA for that exact air cleaner set up, and a Formula Ram Air pan'd SD would have required a seperate EPA certification. Probably to save a buck, or maybe even risk not passing the test (?) with a different set up caused a "ah, stick the shaker on the Formula" fix to the whole dilemna and it was definitely the cheapest out....
shakers with no other TA parts look funny on a bird to me, but I think I could live with that oddity if an SD was under it
72 Bird
Old 04-18-2013, 03:51 PM
unruhjonny's Avatar
I too had understood that the shaker was closed off because of the noise level created under WOT;
I had also come to unerstand that the noise deal was under the blanket of emissions testing...
I was pretty certain that I read the air cleaner was a factor in certification at that time, and the for certification purposes the shaker was used...
I have been wrong before, and beofre I take my dirt-nap, I'm sure I'll be wrong a-pleanty-o-more times
1970 Formula 400
Old 04-26-2013, 10:04 PM
SD Formula's Avatar
SD Formula SD Formula is offline
Originally Posted by Michael Brand F/SA View Post
Hello,
Thanks so much,
Michael
Michael, Here is some part number information I received years ago on Formula fiberglass hoods, I don't remember where I got it from, or if it is accurate. I also do not know if these numbers are stamped in the bottom of the hood or not. Hope this info. helps.
70-72 Formula non-ram air hood 480172 --- 70-72 Formula ram air hood 479677
73-75 Formula non-ram air hood 490660 --- 73-75 Formula ram air hood 490661
73-74 The 101, SD Formulas used the (73-76 Trans-Am) steel shaker hood 500154
Maybe others could chime in with additional information and clarity.
When removing an unreplaceable washer, the part will be heard hitting the floor and then vanish from the face of the earth!
Old 04-28-2013, 03:17 PM
firebirdbob70.5 firebirdbob70.5 is offline
Default 1970 Formula Hood
1970 Formula Hood Ram Air from the factory are the scoops back wall cut out completely or does it have seven evenly spaced holes per (HIGH PERFORMANCE PONTIAC MAGAZINE ) Feb 2004 issue page 69
Old 04-28-2013, 04:47 PM
RAFormulas's Avatar
RAFormulas RAFormulas is offline
Ram air hoods and non-ram air hoods are identical except for the cut outs. The factory left a slight ridge when they cut out the ram air hoods. Many people make this smooth which is incorrect. There is no need to cut the 7 holes that you spoke of.
Steve
1970 Formula 400 (YS) M40 (67-Castillian Bronze / 215-Deluxe Medium Saddle)
1970 Formula 400 (WT) M20 (67-Castillian Bronze / 213-Deluxe Dark Brown)
1970 Ram Air III Formula 400 (YZ) M40 (26-Lucerne Blue / 201-Standard Medium Bright Blue)
1970 Ram Air III Formula 400 (YZ) M40 (26-Lucerne Blue / 211-Deluxe Medium Bright Blue) *SOLD*
Old 04-29-2013, 06:38 AM
Loffen's Avatar
Loffen Loffen is offline
Does anyone have a picture of a factory cut out ?
Old 04-29-2013, 07:03 AM
The Boss's Avatar
The Boss The Boss is offline
Here you go...
ID:	321524   Click image for larger version
And go racin' in the street.
Old 04-29-2013, 07:14 AM
formula400's Avatar
formula400 formula400 is offline
70 formula hood is one year only. Looks the same but doesnt have the support riveted on like the others
Old 04-29-2013, 07:36 AM
The Boss's Avatar
The early ones are like this but some time before the new 71 models showed up the hoods with the straps started showing up. We've never had a big enough sample of original hood cars to narrow down a date.
ID:	321526   Click image for larger version
Old 04-29-2013, 07:39 AM
Loffen's Avatar
Here you go...
Great Thanks !!
So around 1/8" high edge maybe a little bit more ?
Old 04-29-2013, 07:48 AM
The Boss's Avatar
Look at the inside of the scoop - it'll be real clear where the edge should be.
Old 04-29-2013, 09:30 AM
Loffen's Avatar
I can see the edge man
I did just wonder if it is 2,3 or 4 mm high. (mm = millimeter ( 1/10 of 1 cm (cm = centimeter ( 1"= 2.54 cm or 25.4 mm ))))
Old 04-29-2013, 12:02 PM
Brewster's Avatar
Brewster Brewster is offline
The Formula SD cars received the shakers due to that was the only set-up that had been approved by the feds. There wasn't enough time to submit any other options before production thus it was that or nutting.
