Old 05-03-2013, 10:30 PM
pontiacs4ever1971 pontiacs4ever1971 is offline
Default options on manual disc breaks help
Im wanting to put manual disc breaks on the front of my 62' Tempest. The car should run high 10's so I need to stop this beast. Any suggestions on what I should go with? Thanks for your help guys!
Old 05-04-2013, 09:24 AM
xlrate's Avatar
xlrate xlrate is offline
checkout:
http://scarebird.com/index.php?route...&product_id=76
Todd
Old 05-04-2013, 09:51 AM
beemergary's Avatar
Run Wilwoods on my 63 and 61 that go down the strip. 63 run NSS/D 11.50 class. Do have to make your own brackets but there a bolt on.
Old 05-04-2013, 04:30 PM
Radman's Avatar
Radman Radman is offline
The Scarebird kit gives you the brackets to adapt the calipers to the Tempest suspension,and all of the part numbers that you need. One thing, you may need to have the machine shop square off the front of the hub along with turning it down to fit inside the disk brake rotor.
Also my tires ended up 1/4 inch farther outboard. The distance of the rotor at the hub.
Old 05-05-2013, 10:24 AM
63Longtop's Avatar
63Longtop 63Longtop is offline
Default Brakes
Wilwood, bolt on deal and their are light! I have a couple of sets of brackets.
Old 05-05-2013, 01:41 PM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
I dont belive the Scarebird conversion lets you use the stock wheels. Anyone know if the Willwood kit does?
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 05-05-2013, 05:38 PM
Radman's Avatar
You are correct, the stock wheels will not clear the calapers. You have to get aftermarket rims.
Old 05-05-2013, 06:45 PM
Don,,Does that include the willwood setup?
Keith Collier
Tech advisor
POCI.org
Old 05-05-2013, 07:21 PM
We picked up a suspension unit from a 62 Tempest and rim - may be able to build a setup that will fit the OEM rim. Should know more in the next week or so.
If not the 83-94 Ranger rim should clear.
Old 05-05-2013, 08:07 PM
Radman's Avatar
Don't know, I used the Scarebird set-up.
Old 05-05-2013, 08:48 PM
JohnFromVentura's Avatar
JohnFromVentura JohnFromVentura is offline
The extra 1/4" offset is a little annoying. The stock wheel backspacing was 4 1/2" and American Torque Thrusts have 3 5/8" BS max. Overall the Skybird setup worked out well! I sent my hubs to Skybird for OD and stud length mods. John
Old 05-05-2013, 10:47 PM
Yeah I wanna use stock wheels on the car. So the willwood the way to go?
Old 05-06-2013, 12:39 AM
Dont know yet. I want to run stock wheels. If I put anything else on my car, they will be stolen the first night!!
Keith Collier
Tech advisor
POCI.org
Old 05-06-2013, 09:21 AM
Budsurfn's Avatar
Budsurfn Budsurfn is offline
yes they do work but they aint exactly pretty, I ended up using that because i had to, I then got a custom steel wheel to fit from early wheel company
also you might have to file or machine part of the caliper like i did in order for it to clear the bracket i believe
Old 05-06-2013, 08:05 PM
I'm wanting to put 15" stock steel wheels on
Old 05-06-2013, 09:04 PM
beemergary's Avatar
I am thinking the stock wheels won't just bolt on, but don't know why with the Wilwoods.
Old 05-07-2013, 10:20 AM
fasteddy's Avatar
fasteddy fasteddy is offline
High 10s with stock wheels? That may be real tough. Or do you mean just on the front?
fasteddy
Old 05-07-2013, 05:23 PM
I will have 2 sets. I have drag slicks on it now but for road driving I want the stock steel wheels.
Old 05-07-2013, 11:27 PM
rod cole rod cole is offline
You can run steel wheels just not the high back space factory wheel. Which in my opinion looks kind of dorky on a performance car. The old dodge Dakota had high back space wheels and looked plain ugly. The scarebird brakes are easily sourced parts work well on my 10.65 62 tempest and have been as fast as 9.90 at 135. The wildwood brakes are drag brakes which do not have cooling fins in them. Will probably work well enough but the whole idea is to get rid of heat. Something a solid disc does not do as well as a vented rotor does. If you run the full hubcap you would never know what wheel was on there. I run the weld rod lights with a 205/70 15 on a 4 inch rim and everything clears exceptionaly well. Rod
Old 05-08-2013, 12:28 AM
Never ceases to amaze me what customers do.
