Old 04-30-2013, 07:28 PM
starlightblack's Avatar
starlightblack starlightblack is offline
March of '72 seemed to be the month of 455 H.O. tests. Here is Car Craft's effort.
The Following User Says Thank You to starlightblack For This Useful Post:
  #1482
Old 04-30-2013, 09:51 PM
bossbirdta's Avatar
bossbirdta bossbirdta is offline
Originally Posted by 2manyT/A'S View Post
Good stuff & GREAT pictures...
What magazine was that in?
cover shot....
  #1483
Old 04-30-2013, 10:20 PM
165th's Avatar
165th 165th is offline
Can't quite see who's funny car that is.
  #1484
Old 04-30-2013, 10:52 PM
2manyT/A'S's Avatar
Originally Posted by bossbirdta View Post
cover shot....
Got it......I mean I got it.......I mean,you KNOW what I mean?
You sent me a copy of that a few years back,right?
Didn't realize that the "whacked out" woman in the picture was a "cover girl"...
Eye Candy......garage band?
Go full screen & turn it UP!
  #1485
Old 04-30-2013, 11:02 PM
bossbirdta's Avatar
I believe I did....and its been said that its the same car used in both of those March 72 road tests.....
  #1486
Old 05-07-2013, 01:44 AM
70RAlll 70RAlll is offline
Originally Posted by 1971455HO View Post
Sorry for not remembering which brand, maybe Fel-Pro, but I also remember post about thicker valve cover gaskets being available for guys running a little taller than stock valve train but wanting to retain their stock valve covers. Not the expert here, but I don't think you will need thicker gaskets with the 1.65 RA IV rockers.
I don't know if the RA IV engines came with the baffles, but somebody on here knows!
I remember some of the guys here that build & race really strong Pontiac engines, saying years ago a common practice was to use two gasket sets to achieve clearance with stock covers. You had to seal between them really good to not have any leaks and use longer bolts, but it worked just fine. It's not too obvious and most guys, except the eagle eyed, photographic Pontiac memory guys on here would ever detect it.
I admire all the detail you have put back into your engine. I know you want it right with no issues. It sucks to have to take one back apart after you have ran it and risk chipping paint and spilling oil on pristine parts outside of your engine. You probably know more than me, but really make sure you have your valves adjusted dead on and you don't have any clearance problems.
I had to take my covers back off after my car was totally reassembled. It was wired, hosed, all the fluids and ready to go. I was a day or two from firing it up when I found out the baffles would make contact with the aftermarket rockers. By the way, my car has AC also. See where I'm going. It sucks.
Your engine looks awsome.
Good luck,
Eddie
This is why the RAIV's and HO's(at least 71's) used the "NL" valve cover bolts- and they had two sizes of NL's, standard like the D's, used elsewhere in the car, and long valve cover NL's vs the shorter "D" or "E" cover bolts.. Thicker gasket was used..
  #1487
Old 05-07-2013, 05:12 PM
1971455HO's Avatar
1971455HO 1971455HO is offline
Did not know that little factoid there about the bolt markings and specific end use. Noted and jotted down in my little library of Pontiac facts.
Thanks for schooling.
Eddie
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
  #1488
Old 05-10-2013, 11:30 AM
Formulabruce's Avatar
1972 HO..
http://cgi.ebay.com/ebaymotors/1972-...exp=true#v4-41
ID:	322763   Click image for larger version
Name:	72HO455 windowsticker.jpg
  #1489
Old 05-10-2013, 11:35 AM
SD73's Avatar
SD73 SD73 is offline
I like that. Were those side stripes a factory thing for the Formy? I'm not usually a fan of the vinyl tops on our birds, but this one probably looked pretty striking back in the day.
  #1490
Old 05-10-2013, 11:43 AM
Not those stripes.
They could get stripes, looked a little different.
That car was loaded with everything!
Too bad it wasn't kept in good shape.
  #1491
Old 05-10-2013, 12:11 PM
njsteve's Avatar
njsteve njsteve is offline
The stripe that goes from the "Formula 455" emblems to the rear bumper is the factory available Formula stripe for 1972. It was the same stripe as the 1971 but the cutout didnt contain the louver section that was in the 1971 fender. The rocker stripe is home made.
Oh, let me revise my earlier statement: the factory stripe should be on BOTH sides of the car, not just the passenger side like this one. :-)
  #1492
Old 05-10-2013, 12:20 PM
njsteve's Avatar
That is a really neat car with a ton of options.
And those brand new 4X4 rear leaf springs only sweeten the deal! (see last photo in the listing)
  #1493
Old 05-10-2013, 01:29 PM
2manyT/A'S's Avatar
Wow...another "old HO" emerges & a LOADED W66 to boot!
This also confirms my observation that MOST LS5/W66's were "heavily optioned"...especially automatics.....anybody ever seen a "stripper" HO formula?
NJ steve,this one has about the same option count as yours,I think? (32 vs 34) on yours,including the 2 Canadian mandatories?)
Looks like they forgot the rear spoiler?...what a shame....
ALL of the "important stuff" from under the hood is gone?
That'll be a 5-10K setback for the new owner.....
  #1494
Old 05-10-2013, 01:45 PM
njsteve's Avatar
If you bought this engine you'd be 90% there:
http://www.ebay.com/itm/1972-455-HO-...3b951f&vxp=mtr
  #1495
Old 05-10-2013, 02:05 PM
4birds's Avatar
4birds 4birds is offline
Red face 72 HO Formula
I used to own that car a couple of years ago. It was in need of sooooo much repair and replacement, I let it go. It is missing the original 455HO, air cleaner, manifolds, carb, etc, TH400, and even the rear end has been changed out. The hood is bad, but can be fixed, there are rust thru holes in both rear quarters under the vinyl top, the trunk floor is history and has been horribly fiberglassed as a repair. The side stripe I painted on in about 15 minutes to show my wife what it would have looked like. Sad sad story to a once beautiful car. Can you imagine how this car looked new? Silver with black vinyl top and deluxe black cloth interior with reflective black side stripe and honeycombs! It was hard to let it go. I hope someone gets ahold of it and restores it.
  #1496
Old 05-10-2013, 02:25 PM
2manyT/A'S's Avatar
That's a shame.......the underneath pics didn't look TOO bad......
Those cars look STUNNING in silver.
  #1497
Old 05-10-2013, 02:51 PM
tabob tabob is offline
"Looks like they forgot the rear spoiler?"
Good, they left off the one option they should have.
Would love to have seen it new.
72 TA 4 speed
76 TA auto father/son project
  #1498
Old 05-10-2013, 03:30 PM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
i saw this forsale a year or two ago and almost bought it then. stuck in Afghanistan right now, so out of the question. have almost all the parts in my garage to put it back together, oh'well.
FREEDOM ISN'T FREE
BUT WORTH FIGHTING FOR
  #1499
Old 05-10-2013, 10:08 PM
I thought I remembered it...
Agree - it would have been stunning when new.
  #1500
Old 05-10-2013, 10:39 PM
PB's Avatar
PB PB is offline
Did anyone notice from the magazine article above, the picture of the 455ho engine has the preheater tube run to the backside of the air cleaner?
Pat Brown
