Old 05-20-2013, 09:00 PM
ron cozzo's Avatar
ron cozzo ron cozzo is offline
49 Days 'til Dayton. I finished assembling the console. And, the driveshaft is in. I made up my own stripe pattern for 5 speed manual: Red/Green
ID:	323726   Click image for larger version
ID:	323727   Click image for larger version
'04 GTO Yellow Jacket, A4, Kooks, CAI, etc.
'02 Firebird, V6, auto
'68 GTO Convertible, HO, 4spd, driver
'66 LeMans Hardtop, 400, FI, A/C, 4L80E.
'65 GTO Hardtop, restoration ongoing
'64 GTO Hardtop, "389", Tri-power, 5 speed, A/C, Yorktown Blue.
http://www.gtoaco.com
  #242
Old 05-22-2013, 06:01 PM
ron cozzo's Avatar
47 Days 'til Dayton. Last night I finished the console install. I think most would be hard pressed to tell there's a Tremec under there. If I made a custom shifter handle I could get the '64 shifter plate to work, but this bolt on handle is just too tall. I'm OK with the boot for now. The console top just clears the heater outlet with the raised tunnel.
ID:	323928   Click image for larger version
Name:	IMG_0563 (Large).jpg
ID:	323929   Click image for larger version
Name:	IMG_0564 (Large).jpg
  #243
Old 05-22-2013, 06:07 PM
ron cozzo's Avatar
And today's progress is the interior is essentially finished. The front and rear glass go in Friday. I think I'll be focusing on getting this thing fired soon.
Name:	IMG_0566 (Large).jpg
ID:	323936   Click image for larger version
Name:	IMG_0568 (Large).jpg
ID:	323937   Click image for larger version
Name:	IMG_0569 (Large).jpg
  #244
Old 05-22-2013, 07:14 PM
62 bv 62 bv is offline
looks great who did you have re chrome the console thanks brody cant wait to see it
  #245
Old 05-22-2013, 08:35 PM
ron cozzo's Avatar
Thanks Brody. All of my bright work was done by Metal-Brite Polishing in Dayton. 937 278-9739
  #246
Old 05-26-2013, 12:46 PM
ron cozzo's Avatar
43 Days 'til Dayton. The glass is in. The installer did a nice clean butyl job. Everything is now on the outside of the car except wipers and antenna mast. I installed the drip rails and grilles. I used the aqua trunk mats because they look better with this color car. The jack and spare are installed. I have a more correct wing nut/washer and hook coming. Is this the correct placement for the jack mechanism? Also, they sell a sticker for the 64 jack, but I haven't installed it yet. Is that another one like the "Don't spill fuel" sticker that maybe shouldn't be there?
So now I've moved on to electrical debugging. Several issues. The first is no brake lights and no front left turn signal. I've got power in and out of the brake switch, so I figured it was the new turn signal switch I installed. I found my old one from the pile of don't throw away parts and plugged it in and all's well. Shouldn't have changed it. So this afternoon's project will be swapping out the turn signal switch. I hope not to remove the whole column and do it in the car. We'll see.
Other electrical issues:
-The two speed wipers don't park. I checked the ground, no change. I've got another motor on order. I thought I bench tested this one, but must not have checked for park.
-Underdash courtesy light not working (dome works).
-Console courtesy light not working (glove box works, console box works).
-Fried two of my new T3's when first turned on, they smoked inside the bulbs, crap parts. Another set is on order.
-RR Defroster works, but squeals. I had that motor all apart and bench tested with no issues also. I must have bound something up installing it.
And the saga continues...
Name:	IMG_0572 (Large).jpg
ID:	324260   Click image for larger version
Name:	IMG_0573 (Large).jpg
ID:	324261   Click image for larger version
Name:	IMG_0579 (Large).jpg
ID:	324262   Click image for larger version
Name:	IMG_0580 (Large).jpg
  #247
Old 05-27-2013, 01:33 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
It's pretty easy to swap the Turn Signal switch in the car (non-tilt).
Car looks great!
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
  #248
Old 05-28-2013, 09:25 PM
The car looks so good it would take forever to compliment all of it .
But i have to ask if the steering wheel is maybe the wrong color ... it just looks like wrong shade . it sorta sticks out a lil bit
Just curious if that is the way they were ?
  #249
Old 05-28-2013, 09:59 PM
ron cozzo's Avatar
I understand what you see Baron. I think what I have for the wheel color is at least close to correct. I haven't seen a dark blue steering wheel. They all look like this:
  #250
Old 05-29-2013, 09:14 AM
bill ryder's Avatar
bill ryder bill ryder is offline
Hi Ron, You have PS and PB. Are you going to put the chrome trim on your pedals?? I'll get a trunk pic later today. "Bill"!
  #251
Old 05-29-2013, 09:45 AM
ron cozzo's Avatar
bill, maybe I confused everyone. The car in post 249 is not mine. That's just an example of a blue steering wheel not matching the dark blue interior, which I found online. Notice the contrast between the wheel and column. This is the same blue that was on the steering wheel now in my car, before it was recast.
Regarding the pedals, yes, mine have the stainless trim on them as seen in the first picture of post 243, which is my interior.
Thanks in advance for the jack orientation picture.
  #252
Old 05-30-2013, 10:04 PM
ron cozzo's Avatar
39 Days 'til Dayton. As 6 Grrrs confirmed, it's not too bad to remove the turn signal switch with the column still in the car. Not fun, and a little nerve racking not to scratch anything on the column, but possible. I did get my old switch back in the column and now all of my exterior lights function properly. Also replaced the wiper motor and they now park correctly, so I installed the arms/blades. Everything is now on the exterior and interior of the car. All of the fluids are in. I did struggle with a leaking thermostat housing but it's fixed (for now). Just need to finish up the A/C parts under the hood. Waiting for custom A/C lines to arrive mid-Jun. The plan is to start the car this Saturday, fingers crossed.
Name:	IMG_0584 (Large).jpg
ID:	324818   Click image for larger version
Name:	IMG_0582 (Large).jpg
  #253
Old 06-01-2013, 11:03 AM
ron cozzo's Avatar
37 Days 'til Dayton. Huge, Awesome day today. She lives.
The Hillard Performance "389" is purring away.
http://www.youtube.com/watch?nomobile=1&v=gREESkfrsS8
  #254
Old 06-01-2013, 11:22 AM
65Mark 65Mark is offline
Sounds great!
  #255
Old 06-01-2013, 12:37 PM
that s great i remember when i got to start my 62 after 8 years it sounds great later brody
  #256
Old 06-01-2013, 02:18 PM
64woodwheel's Avatar
64woodwheel 64woodwheel is offline
Congrats! Looks Purrrrrr-fect!
  #257
Old 06-01-2013, 02:30 PM
UK_66_LeMans's Avatar
UK_66_LeMans UK_66_LeMans is offline
Send a message via Yahoo to UK_66_LeMans
COOL
Andrew Peters, Brit with good car taste
  #258
Old 06-01-2013, 02:31 PM
s2k1 s2k1 is offline
Congrats!!!
1964 GTO Hardtop Black/Black
1964 GTO Sedan Black/Black
1969 Grand Prix Model J
1972 GMC K20 427/TH350
1972 Chevy C30 FlatBed 402/TH400
1972 GMC C10 350/TH350
  #259
Old 06-01-2013, 04:30 PM
Hurst65's Avatar
Hurst65 Hurst65 is offline
Sweet!!!
1965 GTO, 408 tri-power, 4 speed, Currie 12 bolt w/3:42's, Hurst wheels
  #260
Old 06-03-2013, 12:29 PM
HUMBLER's Avatar
HUMBLER HUMBLER is offline
Wow, just beautiful, and that sound!
I hope to get down to Haydocy to see it, if not, Dayton.
Would you mind if I shared the video on the GTOAA facebook page?
1969 Judge (Liberty Blue / Blue, 4SPD)
