Old 07-06-2013, 06:14 AM
67'7F6'Bird's Avatar
Default MSD Ignition Rotor Phasing Kit for Dist
Does any one know if any stores in MA or NH carry this in stock?
Part# 84211
http://www.msdignition.com/product.a...69&terms=84211
Thanks,
Steve
Old 07-08-2013, 06:25 AM
Don 79 TA Don 79 TA is offline
my guess is only a performance/speed shop probably will
i'm sure any place that has msd stuff can get it
check out jegs, they are now offering totally free shipping
summit is too after spending a $100
but i noticed lately, their prices on almost everything have gone up
Old 07-08-2013, 08:29 AM
TOP 452's Avatar
TOP 452 TOP 452 is offline
Send a message via Yahoo to TOP 452
Steve you have a pm
Old 07-08-2013, 09:26 AM
Thanks Guys.
I am going to Switch to the Ford Big Cap. Its the Cap-Adapt by MSD with the Phasable Rotor.
Still not sure why this needs to be Phased. Very basic setup. 6AL with Timing Computer.
But Looking at the Cap, its firing on the far edge corner of the CAP Pads.
Steve
Old 07-08-2013, 11:11 AM
You might ask if the adapter will work correctly for you?
I bought an 'Adapt-A-Cap' for my car about 10 years ago.
It would not work for adjusting the rotor.
MSD said it was only good for the chevy or clockwise rotating distributors.
They said at that time they did not make one for the Pontiac.
(or counter-clockwise)
Old 07-08-2013, 12:13 PM
ventura7211's Avatar
ventura7211 ventura7211 is offline
Originally Posted by 67'7F6'Bird View Post
Thanks Guys.
Steve
Be sure to check the rotor to cap clearance with that deal, and keep an eye on it.
I've managed to phase pretty easy using a sharpie to mark the distributor, a "kit" can be made with an old cap by cutting a hole in it so you can see where the rotor is in regards to the cap, FWIW.
Old 07-08-2013, 12:35 PM
Hi John,
I just called MSD Tech Line, they said the Cap Adapt (Part No. 8420) will work on the Pontiac Pro Billet Distributor.
http://www.msdignition.com/Products/..._Chevy_V8.aspx
http://www.hotrodhotline.com/md/html/rotorphasing.php
They also wanted me to Check the Following:
1) The 2 Wires from the 6AL to the Distributor need to be at least 6 inches away from any other wires. Making sure there is no Magnetic Interference.
2) After removing the Rotor look through the Square and Round Alignment Holes because they should be Directly aligned with a Reluctor.
3) Do Not use a Dial Back Timing Light or Digital Timing Light as they will give erratic readings Due to the MSD Ignition.
He did say that the Distributors are set up to spark on trailing edge.
Steve
Old 07-09-2013, 06:26 AM
i can attest to #3
wierd though... some people have problems, others don't
as for #1, i guess that is why i see them listing a shielded cable, which i have not tried at this time, but i don't think my wires were interfering with anything
also i think that is more prone on the analog boxes versus the digital ones?????
last time i check my rotor/cap, i was amazed at how centered the marking were
the last msd dist i had, was towards to the tail end
