Old 09-04-2013, 09:46 PM
dwid's Avatar
dwid dwid is offline
Default items sold
Headlight brackets and bezels are sold, thanks Darren.
Disc brake proportioning valve is sold, Thanks Janne.
Old 09-24-2013, 08:29 PM
GTOs-n-Vettes GTOs-n-Vettes is offline
Default Non-A/C Dash Vent Flap Clips
DWID,
I'm looking for the small clips that hold the non-A/C dash vent flaps in place. I've attached a picture of what I'm talking about. Does your car still have them and are they in good shape?
Also looking for a nice glove box insert.
If you're able to help, please let me know what you want for them.
Thanks.
v/r,
Rob
Name:	Vent Flap Clip.jpg
Old 09-24-2013, 08:38 PM
dwid's Avatar
Hey Rob,
I do have some of those clips around, just let me have a look.
Unfortunately the glove box insert was broken when removed.
Rear seat is SOLD - thanks Tom
trunk lid is SOLD - Thanks Richard
Old 09-26-2013, 08:03 AM
stags's Avatar
stags stags is offline
Default glove box door
If the glove box door has the original hinge intact I want it. Could you post a pic along with shipping $ to 18902. Thanks, Mark O.
You can also email the info since I might forget to look here after a while. [email protected]
Ain't as good as I once was, but I'm as good once as I ever was.
Old 09-26-2013, 09:03 PM
dwid's Avatar
email sent on the glove box door.
Front bumper brackets are SOLD - thanks Darren
Old 09-29-2013, 02:45 PM
judger69's Avatar
judger69 judger69 is offline
Are the "Gauges (with bezel and printed circuit) - $200" the Rally Gauges?
Thanx
Old 09-30-2013, 06:12 PM
dwid's Avatar
Default gauges
The gauges are just the standard idiot light ones.
Old 09-30-2013, 06:13 PM
dwid's Avatar
Default corner mouldings
Sale pending on the corner mouldings
Old 10-08-2013, 07:53 PM
dwid's Avatar
glove box door is SOLD thanks Mark
Old 10-08-2013, 07:55 PM
dwid's Avatar
Frame and rear upper control arms are SOLD Thanks Mike
Old 10-13-2013, 08:21 PM
dwid's Avatar
Default updated list of what is left (69 GTO)
inner grills with trim (one side pitted) - $75
15/16" front sway bar (blasted and primed) - $40
Turn signals (housings, bezels, lenses, and brackets) - $100/pair
Front upper control arms $35 each or $50 pair
Saginaw power steering gear - $65
Pitman arm - $30
th400 speedo cable - $25
Heater controls (non ac car) with bezel - $50
Gauge pod cluster housing - $65
Gauges (with bezel and printed circuit) - $175
throttle cable and plastic firewall mounting plate - $35
Headliner bows and clips - $40 set
Headliner tack strips with hardware - $50 set
ash tray assembly (paint to match, rusted inside) - $25
Auto shifter assembly - $75
e brake assembly with pedal - $45 complete
Under rear seat cable protector - $25
Trunk torsion rods - $35 set (2 available)
gas pedal assembly (complete) - $35
rear bumper support bumpers - $20/pr
Door hinges - $75/all 4
Door latches and lock mechanisms - $65/pair
Front lower valence panel (middle section rusted out but excellent for repairs) - $25
Front lighting harness - $50
Intermediate lighting harness - $50
Dome lamp with harness - $25
Lower windshield stainless - $75
front windshield stainless - $50
fender stainless mouldings - $15
Rear view mirror with all mounting hardware (red cover) - $25
Stainless window tracks - $50 pair
Sun visors and brackets (need to be recovered) - $30/pair
brake pedal and pedal pivot bracket - $35
rear bumper brackets (set of 3, rusted and need to be straightened) - $30
original rad support center bracket - $20
front drip rails - $20/set
Tail light housings (plastic) - $50/pair (have 2 to choose from)
rear marker lights - $25/set (will need new bezels)
wiper switch - $20
Trunk latch assembly - $20
Gas tank straps - $25 pair
Front disc brake set up - $200 (spindles,rotors,calipers,brackets.shields etc)
Front steering set up (tie rods, centerlink, idler arm) - $75
Center links - $30 each
Transmission tunnel metal (nice shape) - $40
red door panels (need to be redone) - $150 (complete)
Rad support top plate, centre brace and brackets for 70 lemans $20
Steering column and pedal pivot bracket $25
mid 70's Pontiac dog dish hubcaps - $60/set
Listed below are larger items that I prefer not to ship:
rear glass (2 to choose from non tinted) - $100 each
front windshield - $125
Full firewall and tunnel metal - $100
rear package tray with trunk lid hinges etc. - $85
Trunk divider panel with rear crossmember (where trunk divider meets trunk pan) - $85
Inner rear quarter structures with sail panel - $75 a side
Roof with sub frame - $100
Complete bucket seats (red) - $500
Inner fenders - $125/pair
Rear quarter glass - $65 each
Doors - $100/each (have a few to choose from)
Rear bumper (needs straightening and re chrome)- $65
Front fenders (need heel patches) - $125 each
Fiberglass rear quarters - $75 each
Old 10-17-2013, 07:11 AM
69geeto's Avatar
69geeto 69geeto is offline
Do you still have the 69 tail light housings? I'm interested.
Stu
http://www.CarShowSoftware.com
Old 10-17-2013, 08:01 PM
dwid's Avatar
PM sent on the housings
Old 10-18-2013, 02:28 PM
69geeto's Avatar
PM returned on Housings
Stu
Old 10-19-2013, 02:47 PM
69geeto's Avatar
PM & PP sent.
Stu
Old 10-19-2013, 11:30 PM
dwid's Avatar
Tail light housings are SOLD Thanks Stu
Old 10-20-2013, 09:03 PM
dwid's Avatar
Endura Bumper is SOLD Thanks Frank
Turn signals and brackets are SOLD Thanks Tony
  #38
Old 11-24-2013, 01:59 PM
dwid's Avatar
Default items sold
Trunk springs are SOLD - thanks cuz
Front disc brake set up is SOLD - Thanks Jan
  #39
Old 11-24-2013, 02:02 PM
dwid's Avatar
Dome lamp with harness SOLD as well
