Old 09-16-2013, 09:25 PM
bobbob21 bobbob21 is offline
Default 68 GTO Dual Gate Shifter cable hookup
On my Dual Gate there is a "U" shaped bracket on the shifter with a hole in each side. One side looks like it is threaded. On the end of the trans cable there is a hole in the end. How does the shift cable connect to the Dual Gate shifter? Is there a special bolt? Anyone have a picture of the hookup?
Old 09-19-2013, 05:24 PM
No one out there know how to hook the cable to a dual gate shifter?
Old 09-19-2013, 05:38 PM
Verdoro 68's Avatar
Posted this in your other dual gate thread a while back. The upper right of this diagram has a pic that shows how it connects. It's a pin with an r-clip if I remember right. Diagram is from the GTO Resto Guide.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 09-19-2013, 06:02 PM
dmorg1's Avatar
dmorg1 dmorg1 is offline
Clevis pin and Hair pin
Dave
68 GTO
68 GTO Convertible
68 LeMans
68 LeMans Convertible
68 Tempest Convertible
79 Firebird
Old 09-19-2013, 06:11 PM
Thanks you so much!
Old 09-20-2013, 06:15 PM
Scott Thelander's Avatar
Default Hi \
pm sent
I should have one
Scott
Old 09-21-2013, 12:37 AM
Default Hi
extra
[email protected]
Old 09-21-2013, 08:16 PM
JVM225 JVM225 is offline
Just changed my shift cable.
Probably easier for you to install the shifter end if you disconnect the cable from the transmission first so you don't have to fight it.
Put the car in park.
Remove cable from shift lever on trans by removing pin and pulling it off of stud, then remove U shaped retainer clip from bracket back where the back of the rubber accordion shaped boot sits.
Once the U shaped clip is out, work cable out of bracket on transmission.
Head back in to passenger compartment.
Feed the cable up through the holes you mentioned, move the shifter all the way to the rear position. Secure with clevis pin and cotter pin, then secure the cable with U shaped clip that goes up against the hole you mentioned that is closer to the firewall.
Once it's secured properly inside the shifter, put the shifter in the park positions, go back under the car and reverse procedure to re-connect cable to shift lever on transmission.
Make sure rubber grommet that seals the hole in floor is properly in place, and you're done.
