Old 10-03-2013, 08:24 PM
Darth Menace Darth Menace is offline
Default 69 tempest convertible weatherstripping. need help
Hey there, I am looking into getting a weatherstripping kit for the 69 convertible. I dont need the convertible top seal, but I have noticed the available weatherstripping is the following:
pair of door seals
pair of windshield pillar seals
trunk seal
pair of quarter window vertical seals
pair of lock pillar seals
What I am not seeing mentioned here is the weatherstripping piece that goes horizontal along the outside of the door...the window weatherstripping. Am I missing something here or does it not come in the kits? Or am I missing something here. Sorry if it's a dumb question, but i need the weatherstripping that goes up the A-pillar at the doors, the door window weatherstripping (that I just mentioned) and the two vertical 1/4 window weatherstripping.
Old 10-03-2013, 08:41 PM
goatless's Avatar
goatless goatless is offline
All of the pieces you mention are commonly available.
1966 GTO
Old 10-03-2013, 08:51 PM
I understand they would be, but I cannot find what I am talking about...or maybe I am seeing it, but an thinking it should be called something else. I need the horizontal pieces for the door window (looks like a piece of weatherstripping, then the silver piece then the weatherstripping against the door). I also need the same piece, but for the 1/4 window horizontal pieces. I have seen a lot of door weatherstripping, but nothing for the window pieces specifically. I am just wanting guidance on what the pieces I am talking about are actually called so I don't search blindly or get the wrong pieces
Old 10-03-2013, 09:01 PM
goatless's Avatar
OK then,
Window sweeps or window weatherstrip- PY has as part # RPM48 or RPM48A
1/4 window weatherstrip- PY # RPM112 or RPM112C
Pillar post weatherstrip- PY # RPM166
1966 GTO
Old 10-04-2013, 01:13 PM
great, thanks so much for your help. I knew I was missing something here, and I was
Old 10-04-2013, 01:42 PM
No pics of your car??
Old 10-04-2013, 07:50 PM
Here you go. I bought it off ebay sight unseen in Aug. Pictures show it better than what it is. Needs new wheels, weatherstripping, rear bumper, etc. It idles a bit low and stalls at times, but it hasn't been driven much in a long time so I assume I can work out these kinks over the winter. The paint is a bit foggy so I am going to have to decide how to go about that. I bought it for 12.6k, so I am hoping I didn't get too ripped off.
Old 10-04-2013, 09:41 PM
MD79TA MD79TA is offline
Nice looking car. I assume he sold it to you as a clone? Price sounds like a good deal for a rag top.
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
1979 400 Block, 1970 Heads, Unknown Cam, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base SOLD
1968 GTO convertable project. 400 auto with air. west coast car . Not started in 15 ..update now running (around block spinning tires all the way. Have a lot of cosmetic work to do winter of 17/18
1969 GTO 400 4 Speed this a complete project. Rebuild will start in spring of 2017. SOLD
Old 10-04-2013, 09:54 PM
yes he sold it to me as a clone, and i knew it. no worries there. just upset about the stuff i mentioned earlier that wasn't pointed out. Thanks for the info on it sounding like a good deal....I was devistated when i saw one for sale for $7000. I think after looking around i still got a decent deal even with all the stuff i need to do. Being Canadian makes our unique cars like this even more expensive to buy here, which is why i've bought both my sports cars from the USA and imported them here
Old 10-04-2013, 10:03 PM
The bottom line is that you like it. Nothing like a rag top to me, it is worth the extra money for that alone. Drive it and enjoy it. Don't try to compare prices it will drive you crazy and you never know all of the problems to you have it in hand. Also welcome to the forum you will find a lot of people that will help in any project you have. Good luck Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 10-04-2013, 10:36 PM
heups1629 heups1629 is offline
I think you got a great deal. Congrats.
Old 10-05-2013, 02:12 AM
thanks for the kind words. I will be posting here a lot through the winter and looking for some guidance. Thanks a tonne
Old 10-05-2013, 02:31 AM
and I would LOVE to know if you have some sort of write up on your car and what it takes to get the 69 to go 12.6 in the 1/4
Old 10-05-2013, 01:05 PM
goatless's Avatar
It was in HPP many years back with a little more mild combo-
http://www.highperformancepontiac.co..._4/benson.html
It ran a 13.1 the day after the shootout, which is the best it did with that setup.
Still running a very similar setup, but heads have mild porting, hydraulic roller cam, GM30 3000 stall converter and 3.73 gears currently- pretty much everything else is the same. Oh yeah, G7014 Goodyear Polyglas tires replaced the M/T Drag Radials.
Still totally streetable- I'll hop in and run a few hundred street miles at a time without touching a thing after being at the track.
1966 GTO
Old 10-05-2013, 02:42 PM
How in the world do i get the windowfelts off (front at the moment)? When the window is down you can get two out, but there are 3 or 4 more screws that you cant get access too. And with the window up there is no hope for getting to them
Old 10-05-2013, 03:34 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
Unfortunately you will have to pull the window out.
Old 10-05-2013, 07:07 PM
goatless's Avatar
Actually, you don't need to pull the glass out, but you do need to loosen the stops inside the door to let the glass go down a little farther so you can get to the screws.
1966 GTO
Old 11-19-2013, 06:39 PM
hey doing a windowfelt order. Does anyone know if the windowfelt on a 69 gto the same as windowfelts on a 69 tempest? I seriously have no idea of the differences of these cars
Old 11-19-2013, 06:48 PM
All the 69 custom S, Lemans and GTO convertible weather strips are identical
Old 11-19-2013, 06:49 PM
webfoot's Avatar
webfoot webfoot is offline
Not sure what brand you are ordering, but the PUI/trim parts sweeps I bought fit and look nice. Have also had good luck with Metro weather seals. My LH door seals have been on just barely 2 weeks now and the door is easy to close.
There should not be any difference between tempest/lemans/gto door sweeps.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
