Old 12-20-2013, 08:38 PM
mike leech's Avatar
mike leech mike leech is offline
Originally Posted by Jeff Kinsler View Post
i will simplify this.
FOOT ON GAS PEDDLE = GO FAST..
EHTTFMF
VISNERS TTBMF!
no gas peddle on a computer or calculator though.
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
The Following User Says Thank You to mike leech For This Useful Post:
  #342
Old 12-20-2013, 08:44 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
FOOT ON GAS PEDDLE = GO FAST.. What about CV1s????
EHTTFMF
VISNERS TTBMF!
[email protected]. 3460#s
  #343
Old 12-20-2013, 08:51 PM
gene simmons gene simmons is offline
(what's that head called anyway?)
Available!
The Following User Says Thank You to gene simmons For This Useful Post:
  #344
Old 12-20-2013, 08:53 PM
EHTTFMF
VISNERS TTBMF!
Gas Peddle TTFMF
The Following 2 Users Say Thank You to gene simmons For This Useful Post:
  #345
Old 12-20-2013, 08:54 PM
Gaby Labiosa Gaby Labiosa is offline
[QUOTE/]
Right now I'm building a car to run in heads up class, NA 7#/CID, car is now 499.999 CID and 3500#, will a smaller engine at less weight be faster? [/QUOTE]
YES
I'm not so sure about racing "under" peak but avg. power down the racetrack is where it's at.
At the HIGHEST rpm possible. Acceleration RATE is key.
Gaby Labiosa
EIC Motorsports Inc.
1320ft=What separates the internet "experts" from the real players..
  #346
Old 12-20-2013, 09:01 PM
mike leech's Avatar
Originally Posted by Gaby Labiosa View Post
[QUOTE/]
YES
Oh damn! and from a guy who builds class racing engines.
EHTTFMF!
  #347
Old 12-20-2013, 09:31 PM
Aaron Quinton's Avatar
Aaron Quinton Aaron Quinton is offline
Gaby,
I agree with you, area under the power curve over the operating range in the application is what makes the car move.
Why does the HIGHEST rpm possible make it any faster?
  #348
Old 12-20-2013, 09:41 PM
LiL Jack's Avatar
Originally Posted by Aaron Quinton View Post
Gaby,
I was told more compression strokes = more power.
  #349
Old 12-20-2013, 09:50 PM
charlie66's Avatar
I know my motor peaks at 6600 but It will flat line past 7500 (same hp) Its faster when I shift at 7300 then when I shift at 6800. I always thought it was because of the extra momentum/inertia from the 500 more rpm's.
My Half AN Injun.....
  #350
Old 12-20-2013, 09:57 PM
mike leech's Avatar
winner. plus if its flat you raise the average by taking it to the higher rpm it will fall to a higher number on the shift.=raising the average.
EHTTFMF!
  #351
Old 12-20-2013, 10:02 PM
ponjohn's Avatar
ponjohn ponjohn is offline
I thought this equated to lower ET?
  #352
Old 12-20-2013, 10:52 PM
Sounds like you guys are confusing things?
It's the SAME total HP we were talking about.
How much time does you're engine spend at a low RPM?
Mine is basically at a 1000 RPM range if not less.
  #353
Old 12-20-2013, 10:53 PM
PONTIAC DUDE's Avatar
Post
Or the velocity in the port?
FWIW: Slower velocity can take more time for the engine to recover thus higher rpm shift points even thou the HP curve is flat.
  #354
Old 12-20-2013, 10:56 PM
More HP to the ground equates to lower ET's.
Not HP at a high RPM or even low RPM, just good old HP!
If you're ET's don't equate to you're HP, then something on your car needs work.
  #355
charlie66's Avatar
All I know is when I shift into 3rd gear at 7300 it hits way harder then at 6600. So that's sayin something to me....
  #356
Old 12-20-2013, 11:03 PM
Stan Weiss's Avatar
OK, lets talk acceleration rate.
I have a manual trans. (clutch) car traveling a long at constant velocity. I push the gas pedal to the floor and accelerate to the red line. Where was the max. acceleration rate as data logged on the G meter?
a) When I first floor the gas pedal
b) Peak Torque RPM
c) Peak HP RPM
d) Red Line RPM
e) none of the above
Stan
Pontiac Pump Gas List
  #357
Old 12-20-2013, 11:05 PM
Stan Weiss's Avatar
Did you ever have the motor dynoed to see where peak HP is and how quickly or slowly it falls off?
Stan
  #358
Old 12-20-2013, 11:08 PM
charlie66's Avatar
Stan
Yes I did..
  #359
Old 12-20-2013, 11:12 PM
Stan Weiss's Avatar
Yes I did..
So what did the dyno sheet look like?
Stan
  #360
Old 12-20-2013, 11:15 PM
3fastgtos 3fastgtos is offline
Here's my two cents.....crap, sorry it's only worth one cent. Carry on, Merry Christmas everyone
The Following 3 Users Say Thank You to 3fastgtos For This Useful Post:
