Old 12-28-2013, 07:52 PM
70 bird's Avatar
70 bird 70 bird is offline
Whatever it takes to go fast! Ford and chebby guys don't have a problem with this, some Pontiac guys do? I run a turbo so Im cheating, lol. I do have fun takeing out new LS powered vettes with a Pontiac.
Old 12-28-2013, 07:58 PM
p4msi1's Avatar
p4msi1 p4msi1 is offline
Send a message via AIM to p4msi1
There is no more pontiac.period. That means we can do what we want and not rely on what parts Pontiac would produce for us. Why don't we build something better than everybody else. If All Pontiac or Kauffman would build a spread bore block/crank and matching heads with 5-6 bolts per cylinder and 500cfm capacity, they could call it Pontiac 2.0. We don't know if Pontiac would have built it if they still existed. I think as long as it appears to look like a pontiac and it has a pontiac name on it, and we call it a pontiac, its a pontiac.
Fords new 5.0 does not look like an old 5.0, so is it a ford?
The ls-1 does not look like a typical small block so, is it a chevy?
The new dodges don't start like or look like the old ones. are they dodges?
You guys are getting your panties in a wad over nuthin. You keep peddling the old junk heads and overheated cracked blocks and thats what gets chevy motors in our beloved GTO's and Firebirds. HEY, purist puke, LOOK at me when I'm talking to you... My IA2 block and Tiger heads are not factory correct for my 1969 model year Pontiac Firebird. Man, I'm just gettin started.........
Steve
Old 12-28-2013, 08:00 PM
David Holmberg's Avatar
Originally Posted by twinturrbo406 View Post
... I agree David, but while I have you here, you think you can look into my profile, as I am not able to send PM's for some reason ?? ... I can respond to them, but that's all ...
... thanks ...
Thats odd, Mods don't have that ability, but I will put the right person in touch with you.
Old 12-28-2013, 08:02 PM
Ron Genovese's Avatar
Ron Genovese Ron Genovese is offline
http://www.steveschmidtracing.com/dr...80-billet-hemi
If these guys can call this a Chevy, we can call anything from the Pontiac community a Pontiac!
66 GTO
The Following 2 Users Say Thank You to Ron Genovese For This Useful Post:
Old 12-28-2013, 08:09 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Steve
Relax Francis Sawyer. Your the one getting all wound up over nothing.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 12-28-2013, 08:37 PM
ponjohn's Avatar
ponjohn ponjohn is offline
When the bore spacing changes.
The Following 2 Users Say Thank You to ponjohn For This Useful Post:
Old 12-28-2013, 09:05 PM
p4msi1's Avatar
Who is Francis Sawyer, that you are calling me, Mr. Ferris?
Steve
Old 12-28-2013, 09:09 PM
Bnick166's Avatar
Bnick166 Bnick166 is offline
Could be wrong.........but here's what I was able to come up with...............
http://www.youtube.com/watch?v=7XlnCgpLl1I
Old 12-28-2013, 09:22 PM
Steve
It's a character from the movie Stripes. He seemed to have an anger issue comparable to the post you wrote.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 12-28-2013, 09:24 PM
Thats it! LOL
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 12-28-2013, 09:28 PM
mgarblik mgarblik is online now
I am not responsible for this definition and can't remember where I heard it but it made me think. I was told " if the engine can't be identified as a known other brand, such as Chevy, Mopar, Ford, Toyota, then call it a Pontiac". Sounds a little strange when you first hear it, but it kinds makes sense in a way too. My personal definition is if it is a Pontiac, it should have substantial Pontiac engineering in the engine package. I don't care who makes the parts. To me, that means stock bore spacing, main spacing, in-line valve arrangement, 10 head bolts, a timing case and a valley cover. However, the canted valve, open bore spacing stuff if perfectly fine for other folks. I wouldn't be running around saying they aren't Pontiacs based on the first definition. Our hobby is so small and getting smaller, excluding people doesn't seem very smart.
Old 12-28-2013, 09:35 PM
GTO4spd's Avatar
GTO4spd GTO4spd is offline
The Pontiac engine had some short comings, if the aftermarket addresses this, it's still a Pontiac engine.
Old 12-28-2013, 09:53 PM
miltmilton's Avatar
miltmilton miltmilton is offline
I know that Steve Barcak will disagree with this (and I do support his "NO Corporate BS), but my G8 GXP has an LS3 in it and they still call it a Pontiac and one of the last BTW. On another note, I've run several times at the Norwalk Pontiac Tri-Power Nats against guys with BBC in their "Pontiac" rides. Beauty (IE: Pontiac) is in the eye of the beholder.
milt
Old 12-28-2013, 10:10 PM
lemans411's Avatar
lemans411 lemans411 is offline
... so what's the opinion on lifter-bore design/placement and cam tunnel design changes ?? ... as in moved lifter bores, size options, cam journal design changes ?? ...
... Pontiac or not Pontiac ?? ...
a modified pontiac is still a pontiac in my opinion, if pontiac heads bolt on its a pontiac,
-Rob
67 LE MANS in pieces...
68 gto
84 grand prix twin turbo 496 pontiac 25.3 cage
Old 12-28-2013, 10:16 PM
lemans411's Avatar
they call a 5.3" bore space bbc a bbc, its just a bigger one, if we had a bigger bore space option and different cam and lobe option it wouldnt be a pure pontiac but it would be able to compete with the big dog bbc engines that arent real bbc's
-Rob
68 gto
Old 12-28-2013, 11:00 PM
72projectbird's Avatar
Or maybe...... just maybe, it could be a big block Pontiac?
Maybe
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
The Following 2 Users Say Thank You to 72projectbird For This Useful Post:
Old 12-28-2013, 11:04 PM
p4msi1's Avatar
Jack, go back and re-read my post and take it within the context that it was written. " purist puke" as in the purist that critisizes my car for not being factory correct. I can take that opinion if I want. I can see why you are lashing out at me because I read your signature Restorace. I guess you do some kind of restoring of factory correct race cars? Or model cars? And thats OK, I certainly won't stoop to calling you a name on the internet. You don't know me at all but you call me Francis Sawyer? I believe he was the character that wanted to be called Psycho. Was I that far off base??? Have a sucessful business for over 20 years never been refered to as a psycho.
Steve
  #38
Old 12-28-2013, 11:08 PM
Dude Im just messin with you. Relax...
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
  #39
Old 12-28-2013, 11:38 PM
Well Mickey Thompson DID make and sell HEMI heads for the traditional Pontiac Engine so your comment can't be because the Chebby engine is a HEMI. At least Mickey was 50 years ahead of the Chebby guys on that concept.
Tom Vaught
  #40
Old 12-28-2013, 11:51 PM
Travis Q Travis Q is offline
To me, it's all in what you want to call it.
Some say if it's got aftermarket block and heads, it's not a Pontiac anymore.
Some say if it's got a spread bore spacing, it's not a Pontiac anymore.
Some say if you can't bolt a factory timing cover on it anymore, it's not a Pontiac.
If you look at some of the popular racing engines, you see something interesting...CN blocks call their 5.3 bore space block a "BBC". However, it has a much bigger bore spacing, a factory oil pan won't work, a factory timing cover won't even come close, and there's not even a provision for a distributor. Is it a BBC anymore? Some would say no. I, however say yes, because of this fact: the engine reflects changes in design that started off as a factory block. Here's what I mean....one of the first changes to a BBC was deck height. Big deck heights became really common. Then came bigger bore centers. First came 4.900", then 5.000", then 5.200", the 5.300", before ADRL and NHRA finally said "no mas" and put the limit at 5.300" in an effort to contain costs (funny in and of itself). Then there were really big cam core diameters, and radically moved lifters. Some even have skirted mains. At the end of the day, can we really say that it's a Chevy? Not really, but it is still regarded as a BBC because that's where the foundation was.
So the question is, does anyone want to stifle progression in Pontiac parts (and therefore performance) because of an idea of what does or does not constitute a "real" Pontiac? To me, there's not enough people doing fast Pontiacs as it is.....why make life any harder?
It is what it is, and to each his own, I say.
FWIW.
The Following 11 Users Say Thank You to Travis Q For This Useful Post:
