Old 02-04-2014, 12:25 PM
PONTIAC DUDE's Avatar
Wink
Originally Posted by Jeff Kinsler View Post
damn even ray cox is going to put you on the trailer.. LMFAO!!
EHTTFMF
That will never go down. First he has to make it down the track............ to the end
without coasting.
  #282
Old 02-04-2014, 12:44 PM
Stan Weiss's Avatar
Originally Posted by PONTIAC DUDE View Post
Compression works out to 12.75-1 but with the cam, the cranking compression shows (On the computer calculation, Bwahahahaha) that's it's 170 psi. Pump gas ?......... hummmmmm.
The pistons are coated and might try it if mjm421` gives me enough sh*t and still is running his pump gas combo. LOL.
Ken,
Do not know what the spec are for you engine. Lets say Bore = 4.185 - Stroke = 4.5 - Rod Length = 6.75. Using my calculator, for you to have a 170 PSI cranking compression you would have to have IVC @ 97 ABDC.
Stan
Pontiac Pump Gas List
  #283
Old 02-04-2014, 01:03 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Thanks Ken. That is an interesting dilemma. I think Slowbird ran low, low nines with pump gas.
Regardless, good luck and look forward to seeing you out.
  #284
Old 02-04-2014, 01:05 PM
mike leech's Avatar
mike leech mike leech is offline
Im sure if you both siphon out your tanks at a gas station in town and drive back to the track then race with the same gas same pump he will take you up on that BEST 2 out of three wins......if yours is still alive mike will woop ya....jus sayin
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
The Following User Says Thank You to mike leech For This Useful Post:
  #285
Old 02-04-2014, 01:10 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
THATJUSTHAPPENED
[email protected]. 3460#s
  #286
Old 02-04-2014, 01:27 PM
Post
Ken,
Stan
Used Performance Trends Engine dyno calculator. It spit out the results. I just input the info.
Try this.
Compression:12.75-1
Bore: 4.375
Stroke: 4.460
Rod length: 6.8
Cam specs: 283/[email protected]
114 LSA with 6 degree advance.
  #287
Old 02-04-2014, 01:28 PM
Wink
Bwahahahahahahahahaha,
Sounds like a plan. But don't want to get the cart before the horse. Gotta get it put together first and make passes and tune. Just a prediction................ for now.
Oh...................... BTW...................... EHTTFMF.
  #288
Old 02-04-2014, 01:47 PM
Stan Weiss's Avatar
Try this.
Compression:12.75-1
Bore: 4.375
Stroke: 4.460
Rod length: 6.8
Ken,
My calculator uses seat numbers at the valve. Since weather has an effect this was run with temp = 70 and Barometric Pressure = 29.92
Stan
  #289
Old 02-04-2014, 02:10 PM
Question
Ken,
Stan
Cam spec: .003
IVC = 99
Your chart shows the same 170 cranking psi
  #290
Old 02-04-2014, 02:27 PM
Stan Weiss's Avatar
Cam spec: .003
IVC = 99
Ken,
I get 163.56.
Stan
  #291
Old 02-04-2014, 02:43 PM
LiL Jack's Avatar
Who has the fastest calculator on PY???
  #292
Old 02-04-2014, 02:53 PM
Stan Weiss's Avatar
Lil Jack,
What do you use to calculate your Compression Ratio. Wait I as sorry you done, you just write another check.
Stan
  #293
Old 02-04-2014, 02:58 PM
Wink
Ken,
I get 163.56.
Stan
I should be able to run pump gas with that number. My hyd roller combo cranked at 170/175 and ran 93 Sunoco.
Fastest calculator?
Come on wheelie boy. Don't be hatin.
What do they use to figure out a cam profile for a combo.
What do they use to figure compression
Just trying to get a grip on a N/A pump gas combo. Back in the day Lingenfelter built high hp high compression engines running on pump gas. Even did a SBC with 14-1 on pump gas.
Don't you have a toilet to unstop or something?
Heard there is a Plumbing trade show in the N.E. Is the rumor true that you & Gach are rooming together.
  #294
Old 02-04-2014, 03:13 PM
GTO Dan's Avatar
Post
Lil Jack,
Stan
Don't be hatin'. . I'd rather be like LJ and have a checkbook balance so large that I need a calculator to balance it.
  #295
Old 02-04-2014, 03:37 PM
LiL Jack's Avatar
Talking
It's not that large anymore!
I'm ready to take up donations
New motor is only going to be 13-1 I wonder if I coat everything and retard the timing and run a cold plug if I could run pump gas too?
  #296
Old 02-04-2014, 04:03 PM
blaktopr's Avatar
blaktopr blaktopr is offline
Ken is gonna hurt some feelings with this.
  #297
Old 02-04-2014, 04:07 PM
john marcella john marcella is offline
4 people on the lake are missing there tail rudders for their paddle boats.
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
The Following User Says Thank You to john marcella For This Useful Post:
  #298
Old 02-04-2014, 04:10 PM
GTO Dan's Avatar
Ahhh... I can see Ken is going to run E-85 but I think it works better to convert the straw to alcohol and not just throw the raw crop into the intake.
  #299
Old 02-04-2014, 04:11 PM
R 70 Judge's Avatar
Hopefully he moves the family of mice out before he fires it up.
James
1970 Trans Am
  #300
blaktopr's Avatar
Ssshhhhhh. That's secret squirrel s**t right there! Dont like it?
