Old 12-14-2013, 09:27 PM
Jonsey Jonsey is offline
Very clean solution.
  #102
Old 01-22-2014, 08:31 PM
LPI's Avatar
LPI LPI is offline
Default Serp drive W/EFI and CTB
Here is a system we are working on for a customer that will incorporate the Holley 60-2 crank trigger ring and their sensor with our mounting brackets.
The CTB assembly will work with our new 6 rib serpentine drive belt system with a spring loaded tensioner for the alternator, gen II power steering pump w/remote reservoir and the Sanden 508 style compressor.
The trigger wheel will be mounted to the balancer behind the crankshaft pulley.
We will post pictures as the parts get completed.
Holy cow Tom that's a dirt road...
www.luhnperformance.com
  #103
Old 01-22-2014, 08:44 PM
Ollie's Avatar
Ollie Ollie is offline
Something like this.
Its ok to giggle and snicker, Dont laugh and point
  #104
Old 02-02-2014, 07:35 PM
darbikrash darbikrash is offline
Making a little more progress with the 461. EFI is a Holley HP system. While not the cheapest solution, I like the Injector Dynamics LS style injectors. These are the shorty ID725 high impedance injectors mounted on a Torker II EFI intake, ported to match the heads by Dave at SD Performance.
Fuel rails are Edelbrocks.
I fabbed up some stainless standoffs to raise the fuel rail slightly higher to accept the 48 MM (O-ring to O-ring) injector height. No changes needed to the intake.
I also added a 1.5" Wilson spacer under the throttle body, this buys me some additional plenum volume, and raises the throttle body high enough to let the linkage clear the fuel rails.
1964 Catalina 2+2 4sp, 421 Tri-power
1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM,
Holley EFI, DIS ignition.
1969 GTO 467, Edelbrock 325 CFM, Terminator EFI
1969 Firebird Convertible
The Following User Says Thank You to darbikrash For This Useful Post:
  #105
Old 02-09-2014, 06:51 AM
krisr's Avatar
krisr krisr is offline
Decided to pull my finger out and make up a new cam sensor for my coil per plug setup now. I didn't want to hack up the MSD distributor as I can easily convert it back to a normal dist for someone and it's still in great condition.
Anyhow, I took 1 small body points mallory distributor, gut it, threw all of the guts in the bin, machine the steps and raw casting out on a lathe, modified the shaft so that where the advance weight spring anchors off one of the pins, linish that so it's a 1/8" flat now to acts as the pickup for the MSD magnetic sensor. Add an 0.491" BOP gear, make a top plate and we are away!
  #106
Old 02-09-2014, 11:25 AM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
Nice!
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
  #107
Old 02-09-2014, 04:16 PM
Ollie's Avatar
Default Pontiac Cam Position sensor.
Nice work Krisr,
Good to see what everyone is doing for a Pontiac cam position sensor.
Keep up the Good work.
Just received this Mark III cam position sensor from the machinist.
Molded after a Ford Cam Position Sensor.
Link in post #95.
ID:	352394   Click image for larger version
ID:	352395   Click image for larger version
The Following User Says Thank You to Ollie For This Useful Post:
  #108
Old 02-09-2014, 05:30 PM
krisr's Avatar
Geez that's nice and compact! Going to cut them on a CNC or one off?
  #109
Old 02-09-2014, 05:46 PM
Ollie's Avatar
One off, I do have AutoCAD drawings.
Check the link in post #95 on page 5.
  #110
Old 02-09-2014, 06:12 PM
Fishin2Deep4U's Avatar
Fishin2Deep4U Fishin2Deep4U is offline
Ollie,
Did you not get the one I sent you? Went out months ago.
Dave
'68 Bird Vert, 455 , 6x-8, 1.5 HS, HEI, PPR TC-02-HF, TH400, 2500 Hughes, 2.56 8.2 (getting swapped for second gen with shorter gears)
Fishing guide in the Washington state for Salmon, Steelhead and Sturgeon. Fish-On!
  #111
Old 02-09-2014, 07:28 PM
Ollie's Avatar
No I did not receive one from you Dave.
  #112
Old 02-09-2014, 10:22 PM
NBF823's Avatar
NBF823 NBF823 is offline
Anyone got the part number on that ford sensor?
Also, who has cad drawings? And are they for that ford sensor?
Jon B
  #113
Old 02-09-2014, 10:31 PM
Ollie's Avatar
I have CAD drawings the bottom part is Pontiac the top is Ford.
Read post 109, above and post 95 on page 5 follow the links.
There are two Ford Sensors. The one on the right has a half moon,
That is the one to use the cap has a 3 prong plug.
ID:	352488   Click image for larger version
Name:	FORD CAM SENSOR2.jpg
ID:	352489   Click image for larger version
  #114
Old 02-09-2014, 10:34 PM
NBF823's Avatar
I followed the link and they said Taurus, wind star v6.
Am I missing something?
Do you think I could make one like Derbikrash and mill the rotor half moon for full sequential MS3?
Jon B
  #115
Old 02-09-2014, 11:05 PM
Dog gone it! I sent back your sensor and other pieces. I'm sure it's too late to track now. I'll check out our tomorrow.
Dave
  #116
Old 02-09-2014, 11:24 PM
Donovan Donovan is offline
modern art!
  #117
Old 02-10-2014, 09:34 PM
Ollie's Avatar
Dave
I checked the Post Office today. Was told if a package is not picked up in 16 days it is returned.
  #118
Old 04-15-2014, 11:46 AM
A little more progress on the EFI 461. The Holley 60-2 wheel is now mounted on the balancer, and a crank trigger bracket has been fabbed up and installed on the timing cover. The bracket positions the sensor face .020 above the tooth surface, and the maximum run out of the tooth OD on the wheel is <.002/inches. This precision run out and close sensor gap insures a solid signal for the crank timing. The bracket has a radial slot which allows adjustment of the position of the sensor in an arc around the crank C/L to position it correctly relative to TDC. The sensor position is set at 10 teeth after the “gap”, which is 60 degrees BTDC. The ECU takes over from there to establish engine timing.
Special thanks to Mark at Luhn Performance for all the hard work he did designing and fabricating the crank trigger bracket and the serpentine belt system. There are not many serpentine belt options out there for a Pontiac using an electric water pump, P/S and A/C-that includes an adjustable belt tensioner.
I still need to finalize the pulley spacing with the Gates laser alignment tool, and then it’s off to the anodizer. The motor is set in the chassis and is almost ready to light off.
Really happy with this system, and thanks again to Mark Luhn who has been great to work with.
  #119
Old 04-15-2014, 11:55 AM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
Great job!
  #120
Old 04-15-2014, 12:28 PM
Nice work, kudos to all! And like the fact that the setup uses a type II PS pump. Still don't understand why other systems use the old one...
