Old 03-06-2014, 01:12 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Originally Posted by 1968fbird View Post
My impression was the 11 have 85 cc which would be good but too small valves
Nothing wrong with the 1.96 valve on a 350. Unless,you would spend a few more $ for a 2.08 valve while at the machine shop getting screw in studs and good springs.
Old 03-06-2014, 01:18 AM
PunchT37's Avatar
Getting decent compression out of a 350 is gonna be more important than big valves. A 2.11 valve is not necessary even for a wild 350.
Old 03-06-2014, 01:43 AM
1968fbird 1968fbird is offline
So maybe just mill the heads?
Old 03-06-2014, 08:40 AM
PunchT37's Avatar
Mine would have at least screw in studs, new valves and springs. If you`re gonna spend money to mill, do em up decent.
Old 03-06-2014, 08:49 AM
Cliff R's Avatar
Cliff R Cliff R is offline
"Getting decent compression out of a 350 is gonna be more important than big valves. A 2.11 valve is not necessary even for a wild 350."
+2
No want or need for big valves, or really any porting as any stock "D" port head is PLENTY for over 1hp/cid on a 350 build.
I'd find the smallest chamber head that I could, and cut it down to 68cc or so, deck/square the block for zero, and put an 068 size cam in it. This will get the engine up near 10 to 1 compression for optimum power on pump fuel, allow for a larger cam with less negatives in idle quality and low speed power production with the small 350cid engine.....Cliff
Old 03-06-2014, 09:03 AM
PunchT37's Avatar
Yeah, the 1.96 valve on a small cam 350 with 2.78 gears will be better than the 2.11 as the air velocity will be faster, for a better fill than the larger valve at lower rpm`s and lower lifts.
Old 03-06-2014, 09:10 AM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Larry, You coming to Tulsa May 3rd???
That would be nice, not shure yet. It's been a few years since I went.
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
Old 03-06-2014, 09:21 AM
PunchT37's Avatar
Thinking about it now, I can see where a set of the `70, 16 heads would work well on that motor. That should do the compression better than the 11`s without the milling.
Old 03-06-2014, 09:36 AM
Also for the sake of having all its exhaust bolt holes tapped like the 68 #17's the 68 #15 off a 400 big car
Old 03-06-2014, 08:13 PM
77 TRASHCAN's Avatar
If you mill the heads over .030, remember to have the intake surface milled also, some say half the head surface number, some say mill the same amount.
Zero decking the block will increase compression, and improve combustion, depending on your selection of parts...
Shut it off
Shut it off
Old 03-06-2014, 11:51 PM
just501's Avatar
just501 just501 is offline
Had a set of the '70 #16's on a 73 350. That set was 78 cc stock, I had them milled to 68 cc putting CR at 10:1 with flat tops in std bore. I was running 204/214 cam and I really liked that combo, but think that cam was a little on the small side. That combo would have liked something more like the 068 cam especially with my 4-speed and 3.36 gears.
