Old 03-07-2014, 04:42 PM
pfilean's Avatar
pfilean pfilean is offline
Air domes were often used but if you read a lot of the posts here you will find some confusion on just what got them and when they were discontinued. And they were often removed when a fuel pump needed to be replaced. If the replacement pump did not have one (such as non GM parts) your old guy (I can relate to the age) is right - they just disappeared. Check some of the posts on this subject in the 64-65 GTO Tempest forum.
Old 03-07-2014, 05:40 PM
Engine-Ear's Avatar
DMRGTO's pic shows what every factory-A/C '62 that I have owned (six of them, five built at Arlington, one built at Pontiac).
And FWIW, I haven't seen the air dome on any '62s but I wouldn't say they didn't get them.
RediRad circuit designs, branding and intellectual property are for sale.
Serious inquiries only.
Old 03-07-2014, 05:58 PM
LASJayhawk's Avatar
LASJayhawk LASJayhawk is offline
Parts book shows the same dome 1523319 ( group 3.163) used on:
P/8 1958-64 with A/C
T/8 1961-65 with A/C
P/8 1965 389 with A/C
No listing for a 65 421???
65 Bonneville Brougham 4DHT
65 Grand Prix 2DHT......now parts
65 Catalina 2+2 2DHT
65 Catalina Safari 4DSW
Old 03-07-2014, 11:29 PM
Ziggy Ziggy is offline
Thanks, l was not aware of them. But, what was the purpose of the "air dome". To vent the air in the fuel line? To maintain constant fuel presence and remove any voids or air slugs to the fuel pump?
Old 03-08-2014, 10:15 AM
Engine-Ear's Avatar
It is not a vent.
But, much like the air columns located on your basement utility tub's water controls, the small volume of trapped air acts to smooth out pressure pulses of fuel associated with the pumping action, which is probably worse at some RPM than others.
Old 03-11-2014, 01:16 PM
DMRGTO's Avatar
DMRGTO DMRGTO is offline
LASJahawk has itright. That is a damper/expansion chamber to diffuse "pulsing" in the system.
Smoke 'em if ya' got 'em!
