Old 04-10-2014, 12:39 PM
post toastie's Avatar
http://sfbay.craigslist.org/sby/pts/4402830601.html
That firebird needs this high horse power motor.
  #2462
Old 04-10-2014, 12:56 PM
Mr Twister's Avatar
Looks like a scam or uneducated seller. I see very old heads and 2 freeze plugs in the block. Is that carb looking thing and autolite inline 4 bbl? Plus he says "don't choke his chicken," thats funny right there!
  #2463
Old 04-10-2014, 01:20 PM
hada76's Avatar
hada76 hada76 is offline
Turns out the car has 8 tailpipes too.
actually only 6, cause 8 would be just too much. maybe a little corvette influence there?
___________________________________________
the more im around people, the more i like my dogs
  #2464
Old 04-10-2014, 01:41 PM
Verdoro 68's Avatar
Ha...I just saw a bunch and didn't bother to count. Given the rest of the car I assumed one for each cylinder! But you are right, 8 would be tacky. 6 is tasteful.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #2465
Old 04-10-2014, 01:52 PM
Captainofiron's Avatar
Captainofiron Captainofiron is offline
dont you guys know, you need more nozzle flow area for more thrust!
www.fquick.com/Captainofiron
68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4
97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil
14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires
  #2466
Old 04-10-2014, 02:12 PM
Chris65LeMans's Avatar
How old is that engine builder if he's been doing Pontiac engines for 75 years?
  #2467
Old 04-10-2014, 02:50 PM
David Jones's Avatar
The pictures show the blower simply sitting on a valley pan. I wonder how that affects efficiency?
  #2468
Old 04-10-2014, 03:44 PM
choke your chicken
Name:	choke chicken.jpg
  #2469
Old 04-10-2014, 07:24 PM
FirebirdHank's Avatar
My guess is that "rollerized" means that the stand it is sitting on has rollers under it.
  #2470
Old 04-10-2014, 08:02 PM
Alvin's Avatar
Alvin Alvin is offline
Talking
Look below - "She's 'rollerized' too!"
  #2471
Old 04-10-2014, 08:58 PM
Stuckinda60s Stuckinda60s is offline
Those are the old style pistons, I'd bet that's a 326 instead of a 350. I don't believe you can get 350 pistons with the old valve-relief pattern. I wonder how long ago that engine was built.
Rich
The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance.
Henry Ward Beecher
"The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher
  #2472
Old 04-10-2014, 09:04 PM
Rich
Henry Ward Beecher
  #2473
Old 04-10-2014, 09:34 PM
He say he has 5K in the bottom end, is there a bag of money sitting in the block somewhere. Those are old style TRW piston that would cost about $ 200.00 a set & I didn't see anything else that was close to the money he's asking. The blower looks to be at least 25 years old.
  #2474
Old 04-10-2014, 10:42 PM
GT182's Avatar
GT182 GT182 is offline
Is it me or is the blower sitting on it backwards? If so then that will really choke his chicken, and throw efficiency right out the window. LOL
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
  #2475
Old 04-10-2014, 11:26 PM
I just took a second look at that ????? 350 with the blower. WHY would a reputable engine builder use heads with press in studs for a blower engine. You would have to think the first time you wound it up you would pull a few of the studs right out just because of the pressure of the ??? roller cam & valve train parts. 75 years of Pontiac engine building , he would have started out on the flat heads, but if he was doing it now could he even pull the torque wrench to tighten the heads because he'd have to be at least 92 years old now. Thats if he started at 17 years old. Just make ya wonder.
  #2476
Old 04-11-2014, 12:11 AM
It's an early block it has 2 freeze plugs aside. I'm pretty sure thats a super duty 326 lol
  #2477
Old 04-12-2014, 01:20 PM
jmt455's Avatar
jmt455 jmt455 is offline
Now here's a deal you won't want to miss!
Only $4500!
http://detroit.craigslist.org/mcb/pts/4410714280.html
"Keep your stick on the ice...and your head up."
1910 Buick Model 19 Touring
1924 Cadillac 5 passenger coupe
1933 Pontiac 4 door sedan project
1933 Sport Coupe project
1941 Packard 120 coupe - Factory AC and OD.
1968 GTO, 428, THM400, 2.73 posi cruiser
1958 Buick Caballero 4dr hdtp wagon
2018 Ram 1500 to tow stuff
2024 Buick Encore GX
  #2478
Old 04-12-2014, 02:07 PM
Yep, I'm sure everyone is running to the phone right now.
  #2479
Old 04-12-2014, 02:09 PM
Alvin's Avatar
Talking "Project car"
"Bring a trailer because it will not run down I-45 until the motor is put back in it. One tire is flat as well." http://houston.craigslist.org/cto/4414905057.html
  #2480
Old 04-12-2014, 02:19 PM
Alvin's Avatar
Talking
" 1967 firebird street or strip"
"firebird frame off restoration project. this car has been stripped down and media blasted"
http://sanantonio.craigslist.org/cto/4409849851.html
Meant that literally,"street or STRIP"
