Old 01-10-2013, 12:14 AM
THEGTOCHISM's Avatar
THEGTOCHISM THEGTOCHISM is offline
Default SWITCH ISSUE 70 TILT
I have a 70 GTO with tilt wheel. recently when i crank to start it, it does not fire unless i release the switch back to run. i think this is a bad ignition switch issue. what do you think
70orbitorange
Old 01-10-2013, 12:16 AM
i should have added it is running a MSD 6al and MSD pro billed distributor.
70orbitorange
Old 01-10-2013, 08:56 AM
2002Z4CSS's Avatar
Have you tried to adjust the ignition switch yet?
1971 Pontiac GT-37
Old 01-10-2013, 12:15 PM
Not yet. It started after i tilted the wheel all the way up working under the dash. Adjusting thats my next move.
70orbitorange
Default tilt wheel switch
70orbitorange
Old 04-11-2014, 04:45 PM
got a original Bog warner and problem cured
70orbitorange
