Old 09-22-2014, 03:46 PM
Default 81 core support to frame holes
OK guys the frame has 1-1 1/4" square hole in it for the bushings.The 1/2 bolt has a lot of room there. Are the perfectly centered? Mine seem to be offset bu the body panels seem to line up good.
Old 09-23-2014, 08:22 PM
77 TRASHCAN's Avatar
My brother has his 73 Camaro in a body shop at moment.
Has a bunch of "import" sheet metal on it.
The import stuff has made it a challenge, but theres SO many issues w/ the O.E. parts, it's pathetic. Many things have to be adjusted to get body lines tighter than original. The body guy is a seasoned pro, and friend. He said "F" bodies can be difficult....who knows.
From all I've seen on this Camaro, IF, IF, it lines up, count your blessings, carry on
Shut it off
Shut it off
