Old 11-07-2014, 06:29 PM
lucky1 lucky1 is offline
Default Mounting 65 gto grills
Yet another question. Do the mounting bolts get a washer when installing 65 grills ? Tks.
Old 11-07-2014, 08:09 PM
goatman65's Avatar
mine has washers.
Old 11-10-2014, 10:03 AM
Zimtok Zimtok is offline
A good rule of thumb is that any hole that is slotted or oversize should get a flat washer or a bolt with washer attached.
Slotted holes and oversize holes were used to allow wiggle room when fitting parts together.
Old 11-10-2014, 10:18 AM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
I've got washers on mine. It's a good idea to do.
Old 11-10-2014, 01:13 PM
RA6T7GTO's Avatar
RA6T7GTO RA6T7GTO is offline
Send a message via AIM to RA6T7GTO
originally did not have any washers,
1967 RAM AIR GTO 1 OF 156 AUTOMATICS
Old 11-11-2014, 07:54 AM
69 RA GTO's Avatar
69 RA GTO 69 RA GTO is offline
As mentioned above, no washers were used from the factory
www.69judgeregistry.com
Documenting ALL 1969 Judge and Ram Air GTO cars. If you have one of these cars we would love to hear from you
Old 11-11-2014, 09:54 AM
No washers may have been used at the factory but did the original bolt have a head that served as a flat washer?
If he doesn't have the original factory bolts he may want to use washers.
Old 11-11-2014, 02:07 PM
dld's Avatar
dld dld is offline
Here are the correct bolts. Notice the self threading tips.
can't think of any body bolts that the washers were not integrated to the bolts if used .
my car is on a lift close to me all day LOL
Old 11-11-2014, 02:19 PM
dld's Avatar
dld dld is offline
Here is a pic of head. These very well may be cadmium plated not phosphate.
Old 11-13-2014, 10:24 AM
dld,
You are correct that is the bolt used to mount the grills, and although you are only showing the bottom bolts it is also what was used on the top.
There were no slotted/over sized holes used on the sheet metal (top or bottom) for mounting the grills so therefore no washer is needed.
Although on my (non-original) car I found the bolts that had a slight flange head. They almost look like an oil pan bolt.
Old 11-22-2014, 12:58 PM
Default Thank you.
Thanks for the help.
Old 11-22-2014, 09:16 PM
dld's Avatar
dld dld is offline
I for 1 feel well payed ...your welcome!
