Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 11-19-2014, 01:47 PM
kking's Avatar
kking kking is offline
Default 505 IA-II
505 , IA-II Block, Serial # 95, 4.350 bore 4.250 stroke, 13.5:1 compression, Moldex billet crank, GRP pro 500 aluminum rods(set of 10), Ross flat top coated pistons (set of 10), Titan billet oil pump, BOP motor plate, BOP belt drive, BOP MSD front drive distributor, BOP belt drive distributor kit (composit gear) BOP crank trigger, BOP Aluminum oil pan, Comp solid roller cam (Duration @.050 276 intake 280 exhaust lobe separation 110 lobe lift .440 intake .422 exhaust), Crower offset lifters, T & D 1.6 offset shaft rockers, Butler Edelbrock Victor Wideport intake, Pontiac Auminum Valve covers, Aluminum valley pan, MSD Wires, Knowlton Wideport Edelbrock Thunder Heads with Titanium Valves, Cometic head gaskets, CSR water pump, Aerospace components 3 vane vacuum pump, Ran consistent 8.30 's in a 2400# car, 30 passes since freshen. This Motor was built with no expense spared I have more than $30,000 invested in parts alone. I'm open to reasonable offers would consider trades also.
Asking $20.000.00 Call 414-852-2700
ID:	382403   Click image for larger version
ID:	382404   Click image for larger version
ID:	382405   Click image for larger version
1963 Tempest
1969 Pro Touring GTO All Aluminum 505 IA, 4L80, Roadster Shop Chassis
2004 GRAND AM TUBE CHASSIS RACE CAR 505 IA II 7.92@173
Old 12-04-2014, 11:52 AM
kking's Avatar
New Price $18000.00 Carb to pan. This Motor only has about 100 passes since new. You can't build for this price
ID:	383613   Click image for larger version
ID:	383614   Click image for larger version
ID:	383615   Click image for larger version
1963 Tempest
