Old 01-27-2015, 11:21 PM
lugnutt's Avatar
lugnutt lugnutt is offline
Send a message via MSN to lugnutt
Default Hydraulic roller cam thought
Has anyone run this cam?
Lunati Voodoo cam
Advertised Duration (Int/Exh): 282/290
Duration @ .050 (Int/Exh): 231/239
Gross Valve Lift (Int/Exh): .530/.550
LSA/ICL: 110/116
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 2200-6200
Looking to run in 462 10:1 motor Edelbrock heads (87cc)
4:10 gear 28" tire
I want a driver, comparable to a c6 corvette power.
68 Firbird
If its one thing I know, its..... Uhhh I forgot .
What do you mean I couldnt be the president of the United States of America, Its still WE THE PEOPLE, RIGHT!!
Old 01-27-2015, 11:37 PM
nachomax's Avatar
nachomax nachomax is offline
I purchased that cam, but haven't finished installing it in my 455 -- hopefully in the next few days.
The ICL should read 106°. Typo on the catalog, but timing card shows 106°.
Old 01-27-2015, 11:54 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Definitely install it at 106°. The VooDoo cams HAVE to be at least 4° advanced to work right.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 01-28-2015, 12:01 AM
lugnutt's Avatar
What's the specs on the motor Nacho?
Old 01-28-2015, 12:09 AM
nachomax's Avatar
Lugnutt,
455 + .040". 9:1 compression, port matched iron d-port heads.
Old 01-28-2015, 01:54 PM
ta man ta man is offline
You have way too much gearing.Do you have the heads already?How much power do you want?Or how quick do you want to run?
Old 01-28-2015, 02:16 PM
tom s tom s is online now
I agree,3.73 to 3.55s should be fine.Tom
Old 01-28-2015, 02:23 PM
Steve C. Steve C. is offline
For conversation.....
Calculate RPM for given MPH, Rear Gear Ratio and Trans Gear Ratio
http://www.wallaceracing.com/calc-rpm.php
105 mph 1/4-mile trap speed (a guess)
28" tire
4.10 gear
1.1 trans ratio (presume a TH400 trans)
Result = 5166 rpm
(does not factor in converter slip and tire growth)
Now ask at what rpm will the proposed engine make peak power at ?
Old information here:
Old 01-28-2015, 02:36 PM
David Jones's Avatar
5166 mph
Hell of a cam...........
Old 01-28-2015, 03:09 PM
Bwahahaha... good catch. I changed it.
And of coarse the mph was a wild guess. Not enough known about the proposed combo.
Example of a combo, again for conversation only....
4.210 stroke, unported alum heads, 10:1 compression, Performer RPM intake w/ Q-jet, headers and a 230 degree hyd flat tappet cam will make peak power at about 5200-5300 or so rpm. A similar roller cam might extend that some.
And keep in mind where a combo makes it's 'peak' power rpm at is much different than where it will 'rev' to. Often 'reving' it a lot higher can be non productive. Also where it will be shifted at for best performance at the track.
Old 01-29-2015, 09:39 AM
lugnutt's Avatar
Not really looking for a "quarter mile cam", I am more concerned with its characteristics on the street. Throttle response, best converter, will it work with e85?
I have a Ehead wideport combo right now (65ccchambers).
I Just decided to try to make a driver out of my car, instead of a race car. I may even throw a Procharger on later!
Old 01-29-2015, 10:03 AM
60man's Avatar
60man 60man is offline
It's tubed isn't it? Got room for a 32" steamroller tire Kev.....
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 01-29-2015, 10:45 PM
lugnutt's Avatar
Yea, it has 31's on it now but, they are slicks.
I would like to put some 19's on the rear.
How are you doing Troy?
Old 01-29-2015, 10:55 PM
lugnutt's Avatar
Default 31x18-20
I guess I could run something like these
