Old 02-24-2015, 01:17 PM
PMD1969's Avatar
PMD1969 PMD1969 is offline
Default Storing a crankshaft
What should I coat a crankshaft with to store it in my attic? Cosmoline?
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213)
99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale
http://sohcsix.yuku.com/forums/1/OHC-lounge
Wanted: 1969 OHC "H" Camshaft
Old 02-24-2015, 02:49 PM
78w72 78w72 is offline
standard wheel bearing grease or any grease on the main & rod journals is all thats needed, maybe a light coat on the rest of the casting to prevent surface rust/
& store it on end! do not lay flat unless supported at the mains as if it were in a block.
Old 02-24-2015, 03:11 PM
track73 track73 is offline
I've seen crankshafts painted, after being degreased.
Old 02-24-2015, 03:25 PM
I has some spray anti seize I used on one of my 409 cranks-worked great for many years of storage.
Old 02-24-2015, 04:21 PM
Kano Products Weatherproof and store the crank standing up.
Old 02-24-2015, 08:48 PM
mgarblik mgarblik is offline
Valco Cincinnati has a product called Gel Lube. It is a spray lubricant that sprays out kind of thin but after several seconds jells-up and gets quite sticky. It is in an aerosol can and not expensive. I coated an entire IAII with it and it stayed rust free for several years until we put it in service. Same with crankshafts. Check out their web site. Great company, great prices and they have a racer net program that is VERY inexpensive. I am talking Quality RTV for like 1.50 a tube.
Old 02-24-2015, 10:08 PM
PMD1969's Avatar
I have it bolted to the flywheel and it is standing on end. I have a tub of standard wheel grease. Should I apply it with a small brush or something else?
Old 02-24-2015, 11:36 PM
DeanBenson DeanBenson is offline
Back when I was a kid my Dad would make me coat bare blocks and cranks with grease with my bare hands..... You can use a soft brush, a finger, ??? just be sure to cover all of the machined surfaces. The one little spot you miss is the one spot that will rust.
Old 02-25-2015, 07:13 AM
Man O man some things persist forever!
If it's a cast crank you do not have to store it standing up and doing so reduces the chance it will get knocked over and then you might have a issue!
Old 02-25-2015, 11:40 AM
GRX's Avatar
GRX GRX is offline
Furniture polish sprays like lemon Pledge. Cranks which I have had bagged for several years cleaned up
like the day they were first polished. Plus it smells lemony fresh.
1969 GTO hard top ~ Std bore 400, '70-RA3 block, 670 heads, Bal. & Blue... M22, 12-bolt w/3:55s
Old 02-25-2015, 12:02 PM
77 TRASHCAN's Avatar
Start your 428 project yet???
Shut it off
Shut it off
