Old 04-07-2015, 08:05 PM
The little Ford in 1998 (with less cubic inches, less tire, and conventional headers) ran several tenths quicker vs George's combination today (using a belt driven supercharger with the same mass flow as George's engine). PERIOD.
  #122
Old 04-07-2015, 09:24 PM
2manyponchos's Avatar
2manyponchos 2manyponchos is offline
I like boost numbers...my 5.9 regularly sees 35 psi.
Back to topic...Brian the car is looking great. Can't wait to see it tearing up the track.
P.O.S.I - It's not just a club...it's an addiction!
  #123
Old 04-08-2015, 09:36 AM
GTOGEORGE's Avatar
Damn Tom you must be really, really bord or you just don't have a life........what is it? LOL!
NEVER said I ran 12 lbs of boost.........1/2 truth!
You stated my car has never been weighed..........1/2 truth! I weighed it at Norwalk not that long ago.
Obviously you are GREATLY over paid at Fords! If that's the best you can do........engineer my BUTT! LOL!
Unlike your Ford buddy's I actually bracket race my car. Hello McFly its a bracket race engine.........SMALL cam, LOW rpm, LOW boost A BRACKET engine!
My info has never changed as you stated, check my posts ........more 1/2 truths! LOL!
GTO George
  #124
Old 04-08-2015, 02:58 PM
George, read thru the threads once in a while before you post. I realize that it is hard when Jeff, Brian, Jack, Mike, and others are actually trying to help you at the end of the day.
Good luck with your deal Brian.
  #125
Old 04-08-2015, 03:47 PM
GTOGEORGE's Avatar
Oh yea bye the way your buddy's (bracket car) LMAO Ford is also WAY QUICKER then every car that you mentioned above!
GTO George
  #126
Old 04-09-2015, 06:35 PM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
... get a room you two!!!!
  #127
Old 04-09-2015, 06:36 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Brian, when you become King of the CV1s with the only one out there running half way decent do you think all the nut swingers will come back to your nuts?
[email protected]. 3460#s
  #128
Old 04-09-2015, 07:09 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
I will answer that. YES
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #129
Old 04-09-2015, 08:33 PM
Aaron Quinton's Avatar
Aaron Quinton Aaron Quinton is offline
It should run well with few issues with the changes Brian has made. Good luck man and get that dude rockin down the track soon bro!
  #130
Old 04-10-2015, 08:23 AM
Flyin79bird's Avatar
Flyin79bird Flyin79bird is offline
Any upgrades to the heads for this year over past years? If so, who did the upgrades?
BTW...car looks great!
68 Firebird "Indian Giver" 540 MR1, HP's, Wenzler -- For Sale $12,500 rolling Best of 5.12@134 on 175 shot
72 LeMans "POS" - Next US beast
  #131
Old 04-10-2015, 11:55 AM
GTOGEORGE's Avatar
Brian, did you ran an inter cooler on your old set up?
GTO George
  #132
GTOGEORGE's Avatar
Brian, did you run an inter cooler on your old set up?
GTO George
  #133
Old 04-10-2015, 01:26 PM
bad69bird's Avatar
bad69bird bad69bird is offline
Flyin... yes some issues were fixed while it was apart and BES did the work.
Thank you for the kind words!
GTO George
No intercooler before. So it will be an added bonus to the setup.
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs)
  #134
Old 04-10-2015, 05:38 PM
Distribution of fuel should be a lot better with the Marcella Intake Mods and the conversion to Fuel Injection vs the Blow-thru Carb set-up.
Charge air temps in the intake manifold should be +50% lower with the addition of the Water to Air Inter-cooler system.
Lots of good mods for this years racing effort.
  #135
Old 04-10-2015, 06:08 PM
BADDTA's Avatar
BADDTA BADDTA is offline
Looking forward to seeing it run!
Brian
Boobs & bacon
  #136
Old 04-10-2015, 08:17 PM
bad69bird's Avatar
Thanks Tom and I agree!
Brian
Thanks Brian... me too! Lol
  #137
Old 05-14-2015, 11:14 AM
bad69bird's Avatar
More progress made...
Mounting the Holley LCD 7" screen to the dash
The water tank and trans-cooler/chiller are mounted in the truck and ready for tubing.
  #138
Old 05-14-2015, 11:15 AM
bad69bird's Avatar
Part 2
Pics of the crank support that is being modified by Mark @ Luhn Performance. The original support was an All-Pontiac piece and LPI is changing around some things to meet my needs.
  #139
Old 05-14-2015, 11:18 AM
bad69bird's Avatar
Part 3
Piping fab is done and being welded this week. Below are pics of the pipe inside the car and the pass-thru pipe that I panel bonded to the firewall.
Special Thanks to John Marcella (AKA: Magic Man) for coming through on the 5" V-band when no one else could get one!!!
  #140
Old 05-14-2015, 03:25 PM
jdw_poncho's Avatar
jdw_poncho jdw_poncho is offline
Looks like it's coming along nicely. How do you perfectly align the stub shaft on the bearing support? I'm assuming the mounts have a slight amount of play in them?
