Old 05-21-2015, 12:38 PM
http://www.ebay.com/itm/Pontiac-Tran...m=221776673802
Old 05-21-2015, 03:08 PM
Brewster's Avatar
Brewster Brewster is offline
Limited options as if was ordered to run the strip
Old 05-22-2015, 04:16 PM
unruhjonny's Avatar
meh;
IMHO, if it were meant to run the strip on a budget, the Formula was the winner.
1970 Formula 400
Old 05-22-2015, 09:28 PM
bossbirdta's Avatar
bossbirdta bossbirdta is offline
Exclamation
nuther one....
http://cgi.ebay.com/ebaymotors/Ponti...21212b&vxp=mtr
Old 05-22-2015, 10:04 PM
Originally Posted by bossbirdta View Post
I read the seller's story on the car at the bottom of the auction, and the reference to it having been orange with tweed interior when he bought it jogged my memory. Attached pics are what it looked like in 2007...
ID:	398477   Click image for larger version
Name:	Interior Front.jpg
ID:	398478   Click image for larger version
Name:	Engine Compartment.jpg
Old 05-22-2015, 10:12 PM
Bentwheelbob's Avatar
The guy definitely gets this weeks honesty award. The prison part is priceless.
Old 05-22-2015, 11:45 PM
Probably not the smartest thing to tell people when your selling a car.
Old 05-22-2015, 11:53 PM
bossbirdta's Avatar
....this latest one is defiantly a Bird of a different feather.....no doubt there has been some $$$ spent in trying to save it....poor thing.....
Old 05-23-2015, 12:09 AM
Has '80/'81 gauges.. He would've been better off leaving the aftermarket gauges in it IMO. Looks like its loaded with bondo too.....check out the R/R 1/4 around the marker light..
He's gonna lose his a$$ on this one...
Old 05-23-2015, 08:32 PM
FASTASSBIRD FASTASSBIRD is offline
Originally Posted by grrrrregg!!! View Post
I don't get it, are those the wrong wheels
Nope. Close though. Wrong tires
Old 05-23-2015, 08:40 PM
10 bolt posi? 8)
Old 05-23-2015, 08:56 PM
72projectbird's Avatar
That thing actually looked pretty cool in orange. The tweed interior screams late 80's early 90's build. The paint on the wheel wells was an interesting choice.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 05-24-2015, 12:33 PM
REEDRACER's Avatar
REEDRACER REEDRACER is offline
At least the guy admits he needs to sell it to help make a better life for him. But man that car is messed up! The office furniture when it was orange, was yuck!
69 Judge RAIII 4SP 2ND OWNER
63 Catalina 421HO 4sp
66 GTO Conv 4sp
73 Trans Am 455 4sp
http://www.sdperformance.com/
Drag racing. An adrenalin rush like no other. It felt like going into combat, tasting your first beer, and losing you virginity, all in about 8 seconds.
Old 05-24-2015, 02:46 PM
Brewster's Avatar
A pumpkin with a blueberry interior, Wow
Old 05-26-2015, 08:52 PM
Well, I had a deal to buy this car, but upon inspection pulled back. All the mechanical parts checked out correct PN and date, but the master cylinder, even the starter. However, the left fender and hood were late model, and the shaker had no markings. I think the car got hit on the left and the fender, hood, and shaker had to be replaced. A beautiful car that someone will be very happy with, but not me. Here is the link and inspection report.
All 4 wheels are JW dated 1/26.
70 22387 NOR 719439
201 26 26
02C WS4
Engine:
R- Head #12 dated A280
L- Heads #12 dated A280
Intake -9799068 dated A220
Carb:
7040270 0080 WA
Alt.: 1100902 A270
Starter: part number ends in 436 9M22
Rearend: COX 12 bolt
Left fender and hood are not correct, Hood has four rectangular holes in front inner structure. Date under hood is A232
Brake booster is painted instead of plated.
Small paint chip on left rear trunk spoiler end.
scratch on right rear corner of back bumper.
Left fender alignment to door is not right, too wide of gap toward the bottom.
front bumper alignment to fenders on ends could be better.
minor paint touch up on center of front nose.
saw pic of vin. number of block and it matches.
Small coolant leak at timing cover where it meets the block, may seal with stop leak or need fixed.
Leak found at rearend chunk, not sure if it is rear gasket or what.
The car is a nice looking car with lots of correct parts. It would need some work to be concourse show. Paint looks good overall. Places noted in this report detail any problems with finish.
I could not see AMP on the shaker, could have been covered up or something.
Gauges worked when driven.
Rear Roll Pan bottom edge was not painted and can be seen from the ground.
Old 05-27-2015, 01:35 PM
Judge273's Avatar
Judge273 Judge273 is offline
That's a good inspection report!
Few questions...
How can you see starter numbers without removing it?
Trans has matching vin too?
Rear usually has date too?
Like to check date on block, engine code, and look at other things just in case it's been tampered.
Sounds like it checked out good, and you're looking for a concourse?
What are you interested in mostly?
Mike/Illinois
Old 05-27-2015, 07:58 PM
The Boss's Avatar
The Boss The Boss is offline
Mike,
We know that Bob's going to take it all apart anyways, but for that much money he didn't want to take it that far apart. Ya know?
Chris
And go racin' in the street.
  #38
Old 05-27-2015, 10:14 PM
Few questions...
Starter - couldn't see the whole number, but saw enough using a mirror to be comfortable
Trans - couldn't see trans due to exhaust and placement in tunnel
Axle - could only verify COX code and that it was a 12 bolt. Given everything else it seems a reasonable bet to assume date code was good.
Block - VIN was verified as was YZ code. Couldn't see date code even with mirror, but given VIN match, and date code match on heads, intake, right ex manifold, alt, and distributor, that too seemed a safe bet
Probably not a concourse, but for what you would have been in on this money wise after replacing hood, shaker, fender top, stripes, MC, fuel line, fixing spoiler chip, re painting rally II's and buying polys, et cetera, you would have been into it for concourse money with no room left. Pay transport, taxes, licensing and you are upside down.
It's a really nice car, but what really bothered me was that within 30 seconds of opening the hood any reasonably bright Fbody guy was going to be asking about the hood and fender.
Mike,
Chris
You nailed it. What's the fun if you can't tear a perfectly good car apart and make it a little better. That's about the only thing keeps me sane with the BS I have going on at work. The problem is I don't do body work, and replacing the hood and fender top are going to open up a whole can of paint and body issues.
I need to get back on the Gold Car, but me, MPD and the W72 need to take a little road trip before that can happen, and time is in short supply during the week for me right now.
  #39
Old 05-29-2015, 01:01 PM
bird72's Avatar
bird72 bird72 is offline
I don't usually shark tank cars, but a couple things just made me chuckle here:
http://www.ebay.com/itm/Pontiac-Fire...m=221780189483
1) The vinyl case placed in all dash shots over we all know: "The Hole". Whoops, I didn't mean to leave my sunglasses over that hole, sorry about that!
2) It looks like 4 or 5 cans of splatter (maybe) paint exploded in the trunk. Kinda creepy.
72 Bird
  #40
Old 05-29-2015, 02:01 PM
71formula455's Avatar
71formula455 71formula455 is offline
I think that's the car that Motoexotica has been trying to sell for 6 months or so. Wrong fenders and the wrong color. If it's the same car it was originally Quoizel Gold.
Notwithstanding that, nice looking ride.
Wow. .That's a decent chuck of coin for that car, $48K!
Wrong honeycomb caps
Terrible CD player in dash
Wrong spoiler ends
71 Starlight Black Formula 455 L75
88 Flame Red Metallic GTA Notchback
