Old 05-26-2015, 01:49 PM
4214speed 4214speed is offline
Default 1972 lemans gt tire size
Hello i am new to the abody deal. I like my big cars. I was wonderomg what size tires and if u have pics you guys are running. I am planning 15x7 rims in front and i was thinking 15x8 or. 15x9 in the rear. Will a 9 inch rim fit under the wheel wells or could i even go 10 inch. Thanks joe
Old 05-27-2015, 08:18 AM
2002Z4CSS's Avatar
I have 245/60/R15's on my GT-37 right now. I believe I could fit a 255/60/R15 tire on it because I still have plenty of room. They still don't have a problem lighting up.
Click on the photo to see the video of these tires going up in smoke.
1971 Pontiac GT-37
Old 05-27-2015, 11:58 AM
indymanjoe's Avatar
275/60-15's in back of my Lemans I want to try 295's in back soon.Front wears 255/60-15's no rubbing anywhere.
ID:	398858   Click image for larger version
ID:	398859   Click image for larger version
I am the Thread Killer!
Old 05-28-2015, 09:27 AM
2002Z4CSS's Avatar
Those tires have nubs on them Joe. Time to melt them off.
1971 Pontiac GT-37
Old 05-28-2015, 09:31 AM
indymanjoe's Avatar
LOL,soon my friend soon.
Old 05-31-2015, 07:52 PM
Thanks guys for the pics. What size rims u running with those tires
Old 05-31-2015, 09:26 PM
indymanjoe's Avatar
Mine are rally2's 15x7's front and back.
Old 06-06-2015, 02:24 PM
SteveGB21's Avatar
SteveGB21 SteveGB21 is offline
Send a message via Yahoo to SteveGB21
2002Z4CCS,
What is your wheel size in the rear? I am in the process of getting tires for the rear in my 70 LeMans. Have two 15x7 that will be used in the rear, while I have two 15x6 in the front and a 15x6 salvaged rim via junkyard used as a spare (which I will use a P205 75R15). Thanks.
Old 06-08-2015, 09:06 AM
2002Z4CSS's Avatar
Originally Posted by SteveGB21 View Post
2002Z4CCS,
Those are 15X7 I believe.
1971 Pontiac GT-37
Old 06-08-2015, 04:14 PM
SteveGB21's Avatar
Default Thanks.
Thank you. My '70 LeMans will have 15x6 up front (found a pair in a junkyard, where they aren't bent, but have some slight surface rust that I need to grind off & will be great). So I'll have to ask at the tire shop what size they recommend for the front with 15x6.
Old 06-15-2015, 11:28 PM
post toastie's Avatar
I have 275 60 15's on rear and 245 60 15's on the front on 15x7 rallys. I also have a pic with a 15x8 with the wrong back space. With correct backspace I know 15x8 would fit and probably 295 60 tire.
ID:	400563   Click image for larger version
ID:	400564   Click image for larger version
