Old 06-10-2015, 12:15 PM
Navy Horn 16 Navy Horn 16 is offline
Default Body Roll
I have a 77 "Frankenbird" than I have been working on for the past couple of years. This car was born as an Esprit (though wearing TA front body panels and hood), had a 350 on it's last legs when I bought it, and 2:41 gears. It now has a completely rebuilt 400, Aluminum E-heads via Kauffman, all roller valve train, RPM Performer intake, 3.42 gears (posi), and is running fantastic. To say that I am traction limited would be an understatement.
The next item on my hit list is suspension. This car has none of the fancy WS-6 suspension, though the rear axle did come out of a 79 TA. I have pretty significant body roll when I corner, enough that being hard on the throttle in anything other than a straight line makes me a little uncomfortable. Getting hard on the throttle out of a turn results in enough roll that my rear tire rubs the struts and makes an awful noise.
I received a body bushing kit from my BIL last Christmas, but haven't gotten around to putting it on yet. There are new shocks on the front end. New rubber all around.
My first instinct was to add sway bars, but am second guessing myself. Should the first move to stiffen up an F-Body be sub-frame connectors? Should I do both at the same time? If I go with a sway bar, front or rear first? (wife has me on a budget)
Has anyone used these products, or recommend a better one?
http://www.summitracing.com/parts/up...FdgQgQodV7IAKQ
A bolt in option:
http://www.jegs.com/i/Competition+En...FdM8gQodCZEAEw
The sway bar kits I'm looking at:
Front:
http://www.summitracing.com/parts/hs...w/make/pontiac
Rear:
http://www.summitracing.com/parts/su...model/firebird
Thanks a bunch for any ideas or advice you might have.
Old 06-10-2015, 12:45 PM
JLMounce JLMounce is offline
Get your body bushings installed simply because you have them, but don't expect them to solve your roll issue.
With the car starting life as an esprit, more than likely the spring rate (specifically in the front) is far too soft for the heavier engine package you're now running.
A larger sway bar may help somewhat, but that's kind of the backward approach to suspension engineering. You want your springs and dampers to do the work and fine tune using the sway bar. Not the other way around.
If you like a more stock type ride and stance, I would source replacement springs and leafs from a V8 car. That will likely cure most of your problems.
If you're wanting a modified ride height with greater cornering ability, there are any number of kits, combinations and spring types to choose from.
I am currently running Hotchkis big block springs in the front of my 69 Firebird and their 3" drop leafs in the rear. I've added a half inch tall ball joint to the factory upper arm and currently utilize the factory 11/16th solid sway bar.
I've not begun to test the limit on the car yet, but this setup handles predictably and fairly flat around harder sweeping corners.
In regards to the chassis stiffening, if you're interested in cornering, it's a good idea, it lets the suspension do the work it's supposed to without as much deflection from the chassis itself. However the one thing it may do on an improperly sprung car is make that condition more noticeable.
You'll get better results by doing things in this order.
1. Springs/dampers (include control arm changes in this step if you want to move away from factory control arms)
2. Chassis stiffening
3. Sway bars for tuning balance
As a note, because of how a traditional leaf spring rear suspension works, rear sway bars can sometimes have ill effects. I would opt out of the rear sway bar at first and test your setup. If you find that you need a rear bar, I'd opt for an adjustable sway bar.
As a very general rule of thumb, adding bar in the front provides more traction at the rear. Adding bar to the rear adds more traction at the front.
So going with a large solid bar in the rear can have the effect of creating a car that really wants to oversteer. That's sometimes a good thing, if you're trying to get the car to rotate quickly in an auto-x type setting. It can become dangerous on the street where you want a car to have a more neutral balance that maybe leans towards understeer.
-Jason
1969 Pontiac Firebird
Old 06-10-2015, 12:58 PM
frbformula's Avatar
frbformula frbformula is offline
I used the bolt in sub frame connectors that you posted above with solid body mounts. The sub frame connectors fit really well and I like that you can still take the front sub frame off the car if you need to. I would only do weld in connectors if you never intend to take the sub frame off again. I plan on doing a full resto on my car at some point so I opted for the bolt in ones
Old 06-10-2015, 01:31 PM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
Adding a sway bar to the rear where there was none made a positive world of difference to my A body (coil spring car).
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
Old 06-10-2015, 01:40 PM
David Jones's Avatar
I found a guy that had the front sway bar / steering box off of a 1978 WS6 T/A and installed the parts on my GTO. I also added a BMR Fabrication rear bar. Replacing 40 year old Esprit springs would help your cause.
Weld in connectors would help.
Old 06-10-2015, 01:45 PM
Lucky for me, the previous owner put the correct springs when he put the 350 in it. I've also done an AC delete on the car and lost a good bit of weight by replacing the iron heads and intake with aluminum. My ride is really smooth when driving normally, and there isn't any bounce when going over bumps. It's only when aggressively cornering that I get the body roll.
Thanks for product review FRB. You make a really good point about being able to remove the bolt on kit if necessary. I think the next step is to get that kit ordered and on the car with the bushings and see where I'm at.
Old 06-10-2015, 01:52 PM
Just for the sake of not confusing the OP, I do want to point out that a rear sway bar functions a lot differently on a coil spring car vs. a leaf spring car like an F body.
The problem is that with leaf springs, the axle itself functions as a suedo sway bar. A traditional leaf spring is anchored to the axle and has no inherent pivot along the leaf's parallel axis. What pivot does occur happens primarily in rubber bushings in the eyelets. This is why you never run solid bushings in the eye of a leaf spring. You'd have near 100% bind during cornering.
The converging four link and coil spring setup of the bigger cars allows the axle to pivot a good deal more before the 4 link starts to bind. As a result using a rear sway bar in this application makes more sense.
That's of course not to say that a sway bar can't help a leaf spring rear suspension. It's just usually not necessary on a street car or hobbyist motor sport cars.
If I was running Global West Cat5 leafs that contain spherical bushings and are designed to allow the axle to pivot, then I'd be more apt to also run a rear sway bar.
-Jason
Old 06-10-2015, 02:02 PM
That's good news. From the factory these cars are fairly undersprung as it is. A larger roll bar will help a bit for sure, but I would still caution using a rear sway bar. Especially that solid 1" bar that you linked. That is going to add a ton of wheel rate in the rear.
I would recommend this rear bar instead.
http://www.summitracing.com/parts/he...model/firebird
It's a 3/4" solid bar which isn't going to add as much rate as the solid 1" bar and it's also adjustable which will let you tune it to your style of driving.
-Jason
Old 06-10-2015, 02:05 PM
Mike Fowke Mike Fowke is offline
Ditto what JLMounce posted - especially the rear bar. I upgraded my '78 WS6 T/A with Global West springs, del-a-lums, frame connectors, and solid body bushings. The rear bar was beneficial to the stock set up, but it created over-steer with the aftermarket stuff.
Also, solid bushings are recommended with sub-frame connectors. If yours aren't solid, you may want to sell them rather than replace them twice.
You could also save a few bucks with a used WS6 front bar. I doubt there would be a noticeable difference between it and the Hotchkiss bar unless you're going full blown pro-touring.
If you want to save a few more bucks, I still have the factory WS6 replacement springs from my restoration. They have less than 8k miles on them. PM me if you're interested.
Old 06-10-2015, 02:22 PM
Bigger is Better's Avatar
Bigger is Better Bigger is Better is offline
You didnt mention a budget but if I was looking at an end to end budget solution I would look stiffing the chassis and then increasing the roll/spring rate and front/rear balance.
For the chassis you can get solid frame to body bushings and then the next step would be subframe connectors.
For the roll/spring rate you have a few options. You have some factory options like the WS6 bars (still what I use) but you might have a tough time finding them and there are lots of aftermarket ones now. For springs I would recommend new ones as they are pretty cheap.
Instead of buying from Summit you might want to call a suspension focused shop like Global West, CCP.... I usually recommend Pro Touring F body but they do also sponsor my race car , but seriously they do offer a lot of budget friendly solutions.
Johnny
1980 455 TA
Autocross/Hillclimb
Powered by SD Performance
http://youtube.com/watch?v=Xc5rpSGwXlM
Suspension by www.pro-touringf-body.com
Old 06-10-2015, 03:55 PM
Thanks everyone. My Brother-In-Law was smart enough to get me the solid body bushing kit. I'll check out those sources for the subframe connectors.
The guy that sold me the car has an extra set of WS-6 sway bars in his barn, so those are found.
Thanks again for all the info and knowledge. I originally thought rear-sway bar ahold be first. Sounds like that will be last (if at all).
Old 06-11-2015, 01:22 AM
CROCIE JR's Avatar
CROCIE JR CROCIE JR is offline
No F body car I have ever built, raced, tuned or street driven had the rear bar removed. Lap times are fact, personal feel is subjective. A 7/8" chromoly rear bar and a 1 3/8 solid chromoly front is my choice for all street and auto cross cars. Spring rates in the 480-520in/lb in the front and 115-144 in/lb in the rear. Koni reds or KYB whites. Subframe connectors and solid bushings make the car noisy inside and from all customer feed back plain "annoying." Dont do it. Have you seen f body chassis deflection data? Frequency analysis? Soft springs and big bars are king on the street. BTW this has been tested, proven and for what its worth published in magazines. Winning!
The Following User Says Thank You to CROCIE JR For This Useful Post:
Old 06-11-2015, 01:38 AM
Will Will is offline
^^Ditto.
Swaybars will do the most to correct body lean for the money spent while doing the least to alter the ride characteristics. They are also easier to install than springs.
Springs will definitely help ultimate handling, but for a relatively cheap and very easy to install remedy that will have a huge effect without killing ride quality get some beefy bars on there.
Good shocks would be my next upgrade (I've had excellent results with Koni reds - I don't like the KYBs. I hear Bilstein are also very good). Again, much easier to install than springs and will make a big difference.
If, once you have the bars and shocks, you find the car has too much nose lift/dive on acceleration/braking or still isn't handling up to what you would like, get springs.
Control arm and leaf spring bushings are also a good upgrade. Body bushings and subframe connectors aren't going to make a huge difference.
Old 06-11-2015, 02:20 PM
So, now we have distinctly different camps.
The first group says bushings, sub-frame connectors, sway bar (rear last).
Now I'm hearing that putting in a rear sway bar where there currently isn't one at all is probably the best first step.
Fun.
Well, I went ahead and ordered the rear sway bar. Mostly because it is what I can afford right now and I can install it myself, and there isn't anything there right now.
I'll report back in a week or so once it is on.
Old 06-11-2015, 03:16 PM
android 211 android 211 is offline
It isn't until you replace the subframe bushings that you will realize how much the body was flexing. If the front springs have been replaced with something stiffer and you like the ride height then replace the front bar with a TA 1 1/4" piece. GM used 1 1/8" after 1974 except on WS6 cars which got the thicker one. The rear bar was only 3/4". I'd source TA replacement springs all around. 70-74 was lower and stiffer. '75 up was softer due to owner compliants about stiff ride. I thought my '72 was real stiff until I was going over 70 then it seemed appropriate.
Old 06-13-2015, 08:24 AM
CROCIE JR's Avatar
After many years making these cars pull .95-.98 G on sticky street tires and over a G with race tires, none of them had sub frame connectors. You are not going to be anywhere near those numbers with your set up. I have built cars with roll bars (4 point) in conjunction with sub frame connectors and made for a horrible (subjective terminology) street car. So if any of you guys have actual data lets hear it.
Old 06-13-2015, 09:52 AM
Sirrotica's Avatar
In the suspension shootout between Herb Adams and Dick Gulstrand, Adams won the matchup with softer springs and the largest sway bars he could bend up. I believe they were 1 5/16 inch front, I can't recall the rear size.
For those of you that don't know who Herb Adams is, he was the suspension designer at Pontiac and designed the original suspension for the T/A. Dick Gulstrand was mostly noted for Corvette suspensions and his approach was stiff springs and small sway bars. In any published information Adams has always said large bars to control body roll and soft springs that more easily conform to road irregularities to keep the tires in contact with the road.
Here is a link to the thread talking about the shootout:
http://forums.maxperformanceinc.com/...Dick+Gulstrand
There are definitely two schools of thought about what makes a better handling 2nd Gen F body. In my own 73 T/A I followed Adams suggestions for a street driven autocross car and had great success with it winning the local SCCA championship for the year I ran the car.
There is a reference to another shootout that Ken Crocie refers to that I have never read, someone asked for a link to the article, but none was ever furnished.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 06-13-2015, 03:46 PM
johnsma22's Avatar
johnsma22 johnsma22 is offline
I had Dave from Pro-touring F-body.com help me design the right suspension system based on the specs of my car and what I planned on doing with it, which was auto cross and spirited street cruising. I went with solid body mounts, welded DOM tubing subframe connectors, Dave's Competition front and rear spring kit (lowered 1.5" from stock height), heavy duty tie rod sleeves, adjustable shocks, front swaybar brace to go with my factory 1.25" sway bar , G-bar braces, and heavy duty rear swaybar drop links to go with my factory 1" sway bar.
Also, tubular upper and lower controls arms from DSE, 1LE front disc brakes done with SSBC parts, Willwood rear discs on a Moser 12 bolt rear and TKO-600 5-speed. I did all these mods at the same time, and the results were nothing short of astounding compared to how it handled in stock form. The ride is pretty stiff, but it's not harsh. The car is on rails, so much so that I had to change to a road race oil pan with trap doors to keep oil at the pick up during hard cornering.
John
"There are no stupid questions, but there are a LOT of inquisitive idiots!"
Old 06-13-2015, 04:19 PM
It all depends on what your rear like in handling.
Problem for me with Herb Adams soft front springs big bar was brake dive. Soft front spring lets front dive under moderate to hard braking . That unloads the rear and then the tires have less traction for braking allowing rear lock up esp in a turn when they were set great for less dive. Stiffer front spring less dive more weight on the rear more braking traction.
When I autocrossed my 78 TA hard and alot in CP with sticky DOT autocross tires or even stickier road race slicks I found for me, 500- 700 lb/in front springs 1 1/4 WS6 front sway bar, stock rear springs , solid frame bushings(tried every one for fit and drop) solid lower A arm bushings , solid/Nyliner Herb Adams upper A arm bushings,SMALL 5/8 rear bar. Guldstrand valved Bilsteins all corners(ant they work good for drag racing too!). Yes had those poor fitting Moroso subframe connectors as it was a T top car. They helped a little on the sag of the doors when car was jacked up.
Ride was softer than my factory full sized Bronco and very streetable.
Old 06-13-2015, 04:52 PM
Overkillphil's Avatar
Overkillphil Overkillphil is offline
X2!
Btw, I followed the Adams approach with my 2nd gen birds since the early 80's and never had a problem with front end dive/rear axle unloading during hard braking. But I also did whatever I could to remove unnecessary weight from the front of those cars which helped considerably.
Regarding the stock front springs: I trimmed mine to get the stance I wanted. Ride was always great but firm and the cars handled beautifully on the street and didn't swap lanes unexpectedly when hard cornering and encountering rough, washboard surfaces unlike friends Camaros with rock hard springs.
___________________________________
"Objects in mirror are closer than they appear"
