Old 06-12-2015, 11:35 AM
JamRSW6 JamRSW6 is offline
Default 70 GTO Turbo 400 gasket/seals
My 70 GTO turbo 400 tranny is leaking fluid. I think it is the gear selector shaft seal. Who makes quality seals and pan gaskets that don't leak? Looking for top quality parts. Who do y'all recommend? Thanks, Jimmy
Old 06-12-2015, 05:46 PM
BierManVA BierManVA is offline
I used a Mr Gasket cork pan gasket and it seems to hold fine. Properly torque the pan bolts to 12 foot lbs. Of course, check for dings and alignment, etc on both mating surfaces.
I can't recall who made the shaft seal I used as I ordered a rebuild kit from somewhere. Just go with a reputable seller and you should be fine.
