Old 06-21-2015, 02:54 PM
The Boss's Avatar
The Boss The Boss is offline
My video has you chomping at the bit huh?
And go racin' in the street.
  #782
Old 06-21-2015, 05:02 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
Can you do my Y88 next?
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1996 Trans Am WS6
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
  #783
Old 06-21-2015, 07:47 PM
Bentwheelbob's Avatar
Thanks for the kind words.
Yeah Chris, your video definitely has me chomping at the bit. I can't wait to see all the delinquency...
Well, a little got done today at the Hot Rod Garage. Had to spend some time getting the snap up's installed on the trailer and remounting the emergency brake switch and that limited progress. On a safety related note, while I was drilling a 5/32" hole in the trailer tongue to mount the brake switch the drill bit shattered. I ended up with a cut above my lip from flying metal and MPD got a cut right on his upper lip. If it had hit one of us in the eye it would have been life changing. I have never seen a drill bit shatter like that, but I will wear safety glasses in the future.
On the Gold Car, the exhaust manifolds are now in place. They slid right in and the bolts threaded and tighten up without drama. The tranny got gear lube as well. We couldn't get to the starter because I couldn't find the nylon Z-bar bushing and the ball pivot seal, and it seemed best to get the clutch hooked up first. The original flash chrome valve covers are in place and look good. They got a lot of scrubbing and I also buffed them out. They look almost as good as new. The paint inspection mark is also back on the firewall, and the OK-5 is stamped on the right engine head. All in all, a pretty good day, but the clock is ticking rapidly.
Here are some pictures.
  #784
Old 06-21-2015, 08:32 PM
The Boss's Avatar
Stunning!
Waiting....waiting....waiting....
  #785
Old 06-22-2015, 01:48 PM
Alvin's Avatar
Alvin Alvin is offline
Cool
Looks great, thxs for the safety tip reminder and the update.
What is your planned procedure for reinstalling the innner fender liners on the front?
Reason for the Q is last time I worked with them I ended up scratching and cussing...which I'd be concerned messing up your nicely restored engine compartment and suspension components...
  #786
Old 06-22-2015, 05:30 PM
Six hands, lots of blue tape, blankets and towels, and a little luck.
  #787
Old 06-22-2015, 07:54 PM
The Boss's Avatar
You forgot to mention the bourbon.
  #788
Old 06-22-2015, 08:24 PM
Formulabruce's Avatar
All this AND A/C !! hope you have a 160 T stat in that beauty!!
" Long may we DRIVE !"
  #789
Old 06-23-2015, 01:35 PM
dreamn69 dreamn69 is offline
Quick question Bob: I noticed you went with the brass prop. valve. Was this just personal preference? I don't believe it was the same in your tear down pics.
1972 Formula 455HO
1979 W72 Fire Am
1975 455 4 speed TA
  #790
Old 06-23-2015, 02:10 PM
Alvin's Avatar
Talking Just a little "flood damage"
When MPD and you're finished "screwin round" w that GOLD car here's another NSX for 'da shop:
@ http://repairablecars-forsale.com/
  #791
Old 06-23-2015, 09:24 PM
Good eye, it was different. This one came with the master and booster and after a half-hearted search for a good original I decided to use it.
Alvin - I think even Dave would be scared of that car. Probably worth more for parts.
On the Gold Car, a few more pieces got bolted on today. It's starting to look like an engine compartment again.
  #792
Old 06-23-2015, 09:56 PM
Alvin's Avatar
Hey Bob, don't forget the ground straps, right?
  #793
Old 06-24-2015, 09:38 PM
Thanks Alvin, we'll be sure not to forget. Do you have a picture or diagram showing where it is supposed to get connected?
A few more things got done today on the Gold Car. On the topside, the idle stop bracket and solenoid, choke shroud, throttle return springs, and brake booster vacuum line are all installed. On the bottom, the starter is in and wired, and the exhaust is hooked up and ready. It is moving forward step by step.
Here's a few pictures....
  #794
Old 06-24-2015, 10:12 PM
Looks sweet!! Was a heat shield optional for the starter?. I have owned a couple but didnt notice. Valve covers look very familiar
  #795
Old 06-24-2015, 10:32 PM
I don't know if the heat shield was optional or not, but I put one on just in case. The original valve covers really cleaned up well and I am lucky in that regard since they are so hard to find. Now I just need to get the exhaust shroud installed that you hooked me up with.
  #796
Old 06-25-2015, 07:48 AM
The Boss's Avatar
It's all in the details! Very nice work guys!
  #797
Old 06-25-2015, 01:05 PM
2manyT/A'S's Avatar
Solenoid heat shield was standard equipment on ALL 75-79 Pontiac V-8's....(not sure about 301's)
ahem......valve covers requires slight blue overspray on the overhang edge....
NICE job!
Eye Candy......garage band?
Go full screen & turn it UP!
  #798
Old 06-25-2015, 04:05 PM
Maybe I am thinking of another car or I just can't tell in pics, but wasn't one of the return springs for the throttle yellow and one blue?
1972 Formula 455HO
1979 W72 Fire Am
1975 455 4 speed TA
  #799
Old 06-25-2015, 07:54 PM
You are the second person to suggest this. I am pretty sure that the blue and silver is correct, but I want to get it right so I look forward to other comments. My original springs are pictured below and were blue and silver. Also, I bought a spare correct intake that was fully dressed and included correct manual transmission carb. It also has gray under blue carb return springs. Someone else chime in here. Let's get this right Here is my original set up before the madness started.
  #800
Old 06-25-2015, 10:58 PM
Alvin's Avatar
Wink
Sorry for the reply delay... here's most efficient answer source for you from TAC peeps below:
List of Grounds http://transamcountry.com/community/...?topic=48557.0
Redundant Ground http://transamcountry.com/community/...?topic=50233.0
