Old 07-23-2015, 10:01 AM
61-63 61-63 is offline
Default drilling a .030 hole in the hidden oil gallery plug
I noticed my old machinist buddy was assembling a Pontiac engine for someone about a week ago. Yesterday I asked him if he had finished it and he said "yes, it was gone". He mentioned that the guy had insisted that he drill an .030 hole in the hidden oil gallery plug
because he (the customer) had read that this would prevent any lubrication problems with the distributor gear, so he did it. I told him I have been into Pontiacs for years (which he knows anyway) and have never heard of this before.
Has anyone here ever heard of this?
During this same conversation my friend also mentioned that early big block Chevys (396s and 427s) were having problems wiping cam lobes and the problem turned out to be air being captured at the end of the lifter galleries and the fix, which did solve the problem, was to drill .030 holes in the gallery plugs at the end(s) of those galleries; we didn't get into which ones or how many.
Anyone ever heard of this one?
Old 07-23-2015, 10:14 AM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
Yes,, normal practice with Pontiacs,, especially if you run a bronze Dist. gear.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 07-23-2015, 10:18 AM
tom s tom s is online now
Never have done it on a stock gear,only bronze.Tom
Old 07-23-2015, 10:25 AM
Lee's Avatar
Lee Lee is offline
Who has 0.030" drill bits? That is smaller than 1/32", and 1/16" is the smallest you'll typically find in a drill bit set. 1/16" is 0.0625", and I'll admit I've drilled many with a 1/16" and never had a problem.
Not only does the hole help to bleed air out of the system, it also helps to flush out trash in the passage, so I don't worry about the hole being a bit bigger. I've torn down blocks myself, removing the galley plugs, and have often found all sorts of sludge, grime, CRAP collected behind that plug - stuff which could eventually work its way into the #8 lifters, and cause them to have problems.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 07-23-2015, 10:41 AM
fiedlerh's Avatar
fiedlerh fiedlerh is offline
You can easily find a 1/32" (0.03125") drill bit or around a #68 (0.031") drill bit. These are a little delicate to use for hand drilling, so you need screw the plug into a pipe fitting and do it in a drill press.
http://www.pontiacpower.org/
The Following User Says Thank You to fiedlerh For This Useful Post:
Old 07-23-2015, 10:50 AM
i82much's Avatar
i82much i82much is offline
what about a composite gear?
Old 07-23-2015, 10:55 AM
I thought all Pontiacs came from the factory with a .020 hole there, no?
Old 07-23-2015, 10:57 AM
The H-O galley plug sets used to come pre-drilled I thought, and believe you can find plugs pre-drilled, any machine shop should have them.
Drilling one of those plugs is not fun.
Old 07-23-2015, 11:04 AM
68azbird 68azbird is offline
Much easier to do in a lathe
The Following User Says Thank You to 68azbird For This Useful Post:
Old 07-23-2015, 11:05 AM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
You will have to move to the numbered bits. or machinists bits. Very helpfull on carburetors. Here s a chinese set i purchases. Average chinese quality. So mic the bit for sizing before you use them. I had to return my first set of another brand. The first 4 bits were's all the same size.
http://www.ebay.com/itm/61-80-MICRO-...item4ab6500f81
I use an aluminum plug for easy'er drilling. Some will freek about dissimilar metals. But in the grand scheme, the aluminum plug install will out last the build.
If using a steel plug, pre drill thru 80% of the plug with a larger, more durable bit. Then finish with the .030 or .025 bit.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
Old 07-23-2015, 12:52 PM
Well I'll be darn. Thanks for the responses.
Old 07-23-2015, 01:05 PM
1969GTO's Avatar
1969GTO 1969GTO is offline
Also....not all Pontiac engine builders believe in drilling the hole.
color me gone
Old 07-23-2015, 01:35 PM
Schurkey Schurkey is offline
Oldsmobile uses essentially the same oiling system as Pontiac. There's a thread-in plug ahead of the distributor, and most--not all--Olds engines received a drilled plug from GM. Many of the aftermarket plug kits include a solid plug rather than drilled.
One of the Olds blocks I inspected was filled with crap up to the rearmost lifter on that bank. Had to pull the plug out and force the sludge out.
I'll never build either engine (Olds or Pontiac) without a bleed hole in that plug.
I have absolutely no idea why anyone would mount a campaign to NOT use a vented plug there. Better distributor gear oiling, no dead-end oil passage...what's not to like?
Old 07-23-2015, 01:42 PM
Ken Crocie turned me on to this in the mid 1980s. As stated earlier, H-O plug sets came with the 5/16" plug pre-drilled. It serves two purposes: 1) Provide extra lubrication of the distributor gear 2) Helps stop the sediment that can block the RH oil gallery.
Dr. Thomas Sowell
Old 07-23-2015, 01:51 PM
1969GTO's Avatar
Default Not a campaign
He's the builder with over 30yrs experience....not me and no issues with engine, also my engine is a street/strip only, not a race engine.....if that matters?
color me gone
Old 07-23-2015, 01:58 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
My engines get 2. One for the rear of the RH galley to oil dist gear and one for the front of the LH galley to balance the oil pressure and oil the timing chain.
Old 07-23-2015, 03:24 PM
gtofreek's Avatar
gtofreek gtofreek is offline
I always drill them. I've found the easiest way to drill them is in a drill press, spinning very fast, then hold the plug in your fingers, and, while bracing your hands, slowly feed the plug up into the drill bit. I have drilled many plugs this way and only broke one drill bit.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
The Following User Says Thank You to gtofreek For This Useful Post:
Old 07-23-2015, 03:26 PM
gtofreek's Avatar
I used to do the same thing until I primed an engine with the t-cover off, and saw how much oil squirts out that little hole. Also how much oil comes out the factory hole in the cam thrust plate. That made me realize that the t-chain gets absolutely flooded with oil from the factory hole, so I no longer drill the gallery plug in the front. Only the rear one.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 07-23-2015, 03:34 PM
Cliff R's Avatar
Cliff R Cliff R is offline
I do the same here, one hole to spray the distributor, another to spray the timing set.
It's nearly IMPOSSIBLE to drill a .030" hole thru a standard steel plug, and not really very practical anyhow.
I drill them with a slightly larger bit, then peen the hole closed, and finish size them to .030". I can make one in about the time it took to type this.
Another very good option is to drill them and tap for a small brass set-screw, which drills really easy compared to steel.....Cliff
Old 07-23-2015, 03:59 PM
Skip Fix Skip Fix is online now
I had a Warrior set I used that was supposed to be 0.030. When I prelube blasted a LOT of oil out. Pulled off the freeze plug and it was 0.055 so peened it smaller and reduced the giant spray down to what to me looked more normal.
