#161
I have not run it out the back at full power. I did shut it off at the eighth and went 8.58 though.
#162
I'd reckon that would be in that range run out the back side. Nice Nice Nice
#163
So is the Pheonix going to be at Capitol on the 12th? Or what about you Jack?
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
#164
Yes, I plan on being there on the 12th. I hope Brian makes it also!
#165
Spy photo of Brians Project Phoenix
6.98 @ 199mph 4.53 @ 164mph |
#166
I thought that was Brian after wiring up the dash...
#167
Lmao...yes David that's about right!
I'm going to try and make the Capital race but I'm not going to kill myself anymore than I already am to make it.
East Coast Mafia TTFMF Making CVWHAT's great again. I guess it took a deplorable ECM member to do it! Quote:
![]() Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs) |
#168
Hope to run in OPDS Q16 & watch the big boys run. 😁
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
#169
I have about 90%-95% of the interior done...here's a few pics
![]() ![]() ![]() ![]() These are the bulkheads for the lines to go to and from the cool shirt I'll have on. ![]() This a momentary switch to activate the pump I mounted inside the intercooler tank.
#170
I thought that's what a east coast 1st round DUCK looked like.
Keep up the good work. Cars looking great!
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz “It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life” Notre Dame Head Coach Marcus Freeman 69 GTO NHRA Super Street Car 2860lbs 1/8 [email protected] 1/4 [email protected] in St.Louis April 2026 |
#171
Looks very nice and clean. A fast clean looking street car are few and car between.
#172
Thanks Jason! And yes you're prolly right! LOL
#173
How many beers does that new fancy cooler hold where your passenger seat was???
![]() Looks slick!
74 GTO Bracket/Street car and another 74 for the wifey to race with! 70 GTO 400, 4 spd, #'s matching and a little to nice for me to own. Friendship is like peeing your pants..everyone can see it but only you can feel the warmth! |
#174
LOL |
#175
I'm guessing at least a 12-24 beers. Jacks right, it's not enough! lol
#176
HATERS
540 c.i. Ultra Street Combo Tiger Heads with Tiger Intake Induction Solutions fogger with .046s 1.079 4.52 155.15 3000 lbs 7.77 @ 169 1/4 Mile (2015) with EHTTFMF!! 7.17 @ 188 1/4 mile (2024) Special Thanks to: Ron at Rhodes Custom Auto Butler Peformance Jim Hostler's Transmissions (HOSGTO) on here Induction Solutions BES Racing Engines. Cheeseburger VP Racing Fuels Calvert Racing |
#177
I had a couple PM's about this deal and the question was asked on PZ... WTH is this? So I took some more pics of it and will explain what I did.
So here it goes...first of all I cannot take credit for this idea. One of the guys in my camp has a similar set-up. His pump and its location are completely different from mine, but the overall concept is the same. Pic 1 is the mini pump inside the intercooler tank. It's self-priming and has the feed that goes up to the bulkhead fittings along with the wire to give it power. Pic 2 is where the feed tube from the pump connects to the bulkhead fitting, the other bulkhead fitting is a return for the "hot water" when is comes back from the shirt. I passed the wire through the intercooler via a leftover ferrule nut from when I did the brake lines. I epoxied it in place then sent the wire through the ferrule and sealed it up with epoxy as well. Pic 3 is where the lines from the bulkhead fittings connect to the shirt. The white quick disconnect female fittings that connect to the male ends on the shirt are made by Colder Products and I purchased them, as well as the bulkhead fittings, from McMaster-Carr. Pic 4 is just showing you the fittings connected to the shirt. Pic 5 is the momentary switch I mounted on the shifter cover to actuate the pump while I'm seated in the car. I chose this spot because it was out of the way and I could easily get to it while I'm strapped in. Also, I interrupted the negative side of the switch so nothing hot was going inside the shifter cover and could possibly arc. So while you guys are sweating your balls off sitting inside your hot cars , I'll have nice cold 40*-50* water circulating through my shirt keeping me comfortable!!! Cause a brutha can't sweat while he's racin! Intercoolers TTFMF!!!PIC 1 ![]() PIC 2 ![]() PIC 3 ![]() PIC 4 ![]() PIC 5
#178
Wow. Nice workmanship and details throughout. Good luck and enjoy it!
#179
Thanks Dan!
#180
Doesn't make sense at all...Ok, so now your shirt is cool while sitting in your car but your original statement about everyone else "sweating your balls off" still applies to you because you failed to incorporated the cooler into your tight whiteys....
