Old 07-27-2015, 10:18 AM
gtofreek's Avatar
gtofreek gtofreek is offline
Looking Good!
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
  #382
Old 07-27-2015, 09:25 PM
NYGTO's Avatar
NYGTO NYGTO is offline
Nice to see the progress and I'm enjoying the updates.
  #383
Old 07-28-2015, 12:46 PM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
Quick question GW. I noticed the center caps on your Rally II wheels on the last photo you posted are red with black PMD letters and not black with red PMD letters. Do the wheels on the car actually go on a 70 model and your 69 ones are being restored? This is not the first time I have seen red with black PMD letters on center caps used on a 69 car, and is the reason I am asking. I thought black with red letters was used on 68/69 and red with black letters was used on mid 70 model cars.
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
  #384
Old 07-28-2015, 01:31 PM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
Yah those are off a 70 I have, just to roll around.
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
  #385
Old 08-18-2015, 12:47 AM
GOAT WHORE's Avatar
Long weekend painting the car, FINALLY! Things went real well. Went thru about 1.75 sprayable gallons of the DBC and a gallon and a half of clear. All parts got 3 coats base and 2 coats clear.
We cut the body and 're-coated with two coats clear. The rest of the parts will get the same treatment after we get them installed. We are waiting to do the other parts just incase we chip or scratch anything during assembly.
This car is not going to be cut and buffed it is going to be left with some peel in it.
  #386
Old 08-18-2015, 04:30 AM
Verdoro 68's Avatar
Looking sharp! Always liked that color.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #387
Old 08-18-2015, 09:29 AM
sjdiesel's Avatar
sjdiesel sjdiesel is offline
Beautiful!! Love that gold!
Sean
1967 GTO
Koerner built 468 with Edelbrock RP’s 315cfm by Butler, Luanti Voodoo HR 20510713, 4l80e, Holley Terminator EFI
  #388
Old 08-19-2015, 06:38 AM
bkmont's Avatar
bkmont bkmont is offline
Can't wait to see her all together. She's a beauty!
  #389
Old 08-19-2015, 12:40 PM
gtohurstjudge's Avatar
gtohurstjudge gtohurstjudge is offline
The car is looking fabulous......I'm so glad you left the car the same color.
Your Grandma would be very proud of you.
  #390
Old 08-19-2015, 05:47 PM
GOAT WHORE's Avatar
Thanks for all the encouragement guys.
  #391
Old 08-20-2015, 10:04 PM
Drag Star Le Mans's Avatar
Damn that looks good. I'm jealious, it's going to be a few years before I get started on mine.
DragStarLeMans
  #392
Old 08-26-2015, 02:16 PM
GOAT WHORE's Avatar
Got the doors on. Mike had them looking perfect it short order. He likes to remind me there is probably a better body guy out there, he's just not here!
Screwin the engine together soon, waiting on the Crane rockers so I can measure for pushrods then set it frame rails. Then we can install the front clip.
Trying to get this thing to Seattle next year for the Natties.
  #393
Old 08-26-2015, 10:13 PM
65blackplate's Avatar
65blackplate 65blackplate is offline
Great job lookn good
________________________________________
65 GTO
owner since 84
original ca car
  #394
Old 08-30-2015, 08:26 PM
GOAT WHORE's Avatar
Welded these studs on to my ARP head bolts so I can still use my heat riser on the exhaust manifold and ground strap from battery.
Put on heads and torqued down. Coming along, just slowly as usual.
  #395
Old 08-30-2015, 08:39 PM
Holy Crap!!!! that gold looks good!!!
Old 08-30-2015, 09:32 PM
NYGTO's Avatar
The car looks fantastic and I'm enjoying the steady progress. A true salute to the hobby and a great tribute to your family and grandmother. Excellent!
  #397
Old 09-24-2015, 10:08 PM
GOAT WHORE's Avatar
Crower solid roller bushed lifters (no bearings) installed.
Crower Endura rockers installed. Lash set at .006 intake and .007 exhaust per Dave Bishop.
  #398
Old 09-24-2015, 10:40 PM
GOAT WHORE's Avatar
McLeod RST twin disc, check.
Muncie 4 spd, check.
  #399
Old 09-24-2015, 10:49 PM
GOAT WHORE's Avatar
Ended up using Bill Hirsch engine enamel. It's a little less vibrant then the Plastikote from rattle cans. I think the quart was about $40. Could do 4 or more engines with the quart.
  #400
Old 09-24-2015, 10:51 PM
GOAT WHORE's Avatar
What what, what!
Reunited and it feels so good!
