Old 08-31-2015, 11:55 AM
wwilder9's Avatar
wwilder9 wwilder9 is offline
Originally Posted by 165th View Post
Brewster, here's a pic that may be helpful. Note the cylinder numbers are stamped on each plug wire.
Hey Brian,
I was the guy holding the phone with the wire numbers wrote down on it, What I had on the phone that you guys gave me (from another car) compairing with the numbers on the wires above, we had the 3 and 5 switched, I think that was your problem.
68 Firebird Coupe 350/Auto/Air
70 RA III Formula/Auto/Air
71 T/A 455HO/Standard/Air
73 T/A 455/Auto/Air
  #2562
Old 08-31-2015, 04:37 PM
bird72's Avatar
bird72 bird72 is offline
Looking for 71 HO intake & X-over if any HO people like trip over one walking in the woods or anything
72 Bird
  #2563
Old 08-31-2015, 08:08 PM
PureSD's Avatar
PureSD PureSD is offline
Pm sent
1970 Formula 400 RAIII 4spd. Lucerne Blue 12k mile survivor
1972 Trans Am Lucerne Blue /white 4spd
1973 Trans Am 455 4spd, White, POCI Gold 2012
1973 Trans Am SD455. Brewster Green, auto, 29k miles
1948 Lincoln Continental Cabriolet V12. Restored.
1951 Willys Jeepster 6 cyl.
1970 Olds Cutlass W31 4spd Rallye Red/White
1970 Challenger RT Convert,383 4spd. Hemi Orange
1971 Datsun 240Z 4spd.
1978 Datsun 280Z Black Pearl edition 5spd.
1983 Jeep CJ7 Renegade 5spd.
  #2564
Old 08-31-2015, 09:36 PM
Brewster's Avatar
Brewster Brewster is offline
Originally Posted by wwilder9 View Post
Hey Brian,
Okay, that makes sense and a good possibility. Will check it out this weekend and post the result. Sure gets frustrating at times.
  #2565
Old 09-02-2015, 05:45 PM
alloy indian's Avatar
alloy indian alloy indian is offline
Not really the place for this but they don't speak of ebay cars on the 67-69 tech so. Did anyone else see the one of eight trans am verts on ebay with a non original ram4 engine! Looks pretty sweet! seems legit D80 code and PHS.
  #2566
Old 09-02-2015, 06:50 PM
A Schab A Schab is offline
It's a clone.
  #2567
Old 09-02-2015, 07:01 PM
I know but someone went to a lot of trouble to make it believable. It needs the air let out of the rear shocks though! I hate it when they leave a 69 so high in the rear the rake to the back makes them look like there going a hundred miles an hour siting still!.
  #2568
Old 09-02-2015, 07:23 PM
Alvin's Avatar
Alvin Alvin is offline
Wink
Did you notice Bart has '72 HO intake part listed in FS section?
  #2569
Old 09-05-2015, 05:51 PM
bird72's Avatar
So are 72 and 71 crossovers not interchangeable? Will repro work on 71? And another puzzle: some 197 heads are drilled for 2 end exhaust bolts and some only one? what I deduce from ebay ads. I just got set that have one hole drilled, and Ram Air Ent manifolds are cast for two bolts, so I should have shop drill end hole when do heads I assume (?).
72 Bird
  #2570
Old 09-05-2015, 07:53 PM
njsteve's Avatar
njsteve njsteve is offline
71 and 72 crossovers are different due to the exhaust riser opening shape on the 1972 heads. Major exhaust leak if you use the wrong one.
  #2571
Old 09-05-2015, 08:20 PM
bird72's Avatar
That is what I thought Steve, thanks. Do you know anything on the end bolt situation? Should I concern on missing bolts or go with 3... (?) or drill & tap?
72 Bird
  #2572
Old 09-05-2015, 08:58 PM
You can use both just by installing a thin piece of metal behind the cross over at the port on the head to fill the difference in the gap that doesn't cover it. It's had to be done on a lot of late model heads when changing the intakes . It works fine & if you paint it you can't tell it's there.
  #2573
Old 09-05-2015, 09:51 PM
PAUL K's Avatar
PAUL K PAUL K is online now
Most of the reproduction exhaust crossovers are designed to work with either 197 or 7F6 heads.
Go fast, see Elvis!
  #2574
Old 09-05-2015, 11:45 PM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
i'll just say I drilled and tapped mine. I liked the idea of more bolts holding, just me.
FREEDOM ISN'T FREE
BUT WORTH FIGHTING FOR
  #2575
Old 09-06-2015, 08:06 AM
Judge273's Avatar
Judge273 Judge273 is offline
Good information. 71 is much different in carb, linkage to carb, choke, the look of intake, and exhaust in configuration and part numbers.
Best to find correct piece. Tapping and drilling for nom makes its a molested part....
Mike/Illinois
  #2576
Old 09-06-2015, 08:22 AM
Brewster's Avatar
Altered might be a better term Mike
  #2577
Old 09-06-2015, 08:37 AM
The Boss's Avatar
The Boss The Boss is offline
Mike made that sound a little dirty didn't he?
And go racin' in the street.
  #2578
Old 09-06-2015, 09:29 AM
4birds's Avatar
4birds 4birds is offline
Default 71-72 HO Heads
Anthony, which heads do you have? If you have 71 HO heads, you must use a 69-71 intake crossover. If you have 72 7F6 heads, you must use the 72 intake crossover, as it is different.
Are you going to use factory GM exhaust manifolds or reproductions? (or headers?) The factory exhaust manifolds on the 71-72 HO's only used 3 bolts to hold them on. That's why the 2 holes are not there in the heads. The reproduction manifolds use 5 bolts (copied from the 73-74 SD) for improved sealing. Therefore you will need to drill and tap the heads if you use the 5 bolt reproductions or headers.
The first picture is of the GM 3 bolts OE manifold. Picture #2 is a R.A.R.E. reproduction round port manifold. Pictures 3 and 4 are 72's. The last picture shows the different long slot for the crossover for 71. (the 71 197 HO heads will match this long slot)
ID:	407412   Click image for larger version
ID:	407413   Click image for larger version
ID:	407414   Click image for larger version
ID:	407415   Click image for larger version
  #2579
Old 09-06-2015, 09:49 AM
4birds's Avatar
Default Gaskets
1972 and later gasket on top, up to 1971 gasket on bottom.
  #2580
Old 09-06-2015, 10:09 AM
PAUL K's Avatar
Originally Posted by 4birds View Post
Anthony, which heads do you have? If you have 71 HO heads, you must use a 69-71 intake crossover. If you have 72 7F6 heads, you must use the 72 intake crossover, as it is different.)
You are correct when using GM parts, however most reproduction crossovers were designed to work with either head.
Go fast, see Elvis!
