Old 09-13-2015, 08:49 AM
elefantrider's Avatar
elefantrider elefantrider is offline
Default 17x8" or 18" on B-body
Anyone have pics of their B-body with these size rims and what backspace did you use?
With the huge availability and very low price of better 235 or 245/45 tires in 17", compared to 15" tires, new rims in this size is starting to make more and more sense to me.
Old 09-13-2015, 10:51 PM
Redpiston Redpiston is offline
225/55R17 front
225/50R17 rear
Don't know why they post upside down. I even flipped them and they still do it
ID:	408073   Click image for larger version
Old 09-14-2015, 02:00 AM
Thanks. What width rims and backspace are you running?
Old 09-14-2015, 07:31 AM
The Champ's Avatar
Originally Posted by Redpiston View Post
225/55R17 front
225/50R17 rear
Is that rear size correct? Maybe 255/50/17? Don't think you'd want your front tires about 1" taller than your rears.
Old 09-14-2015, 12:06 PM
What year b-body?
18s are the 17s of yesterday, tire selection is better than 17s.
I did US Mag Bandits, 18x9 zero offset. They make an 18x8 that's zero offset for around $180ea, seen sets go in the $675 range on ebay, with lugs.
Old 09-14-2015, 01:55 PM
Tire size is correct. Came on the car when I got it. They are 8 inch. Not sure of the offset. Will try to measure. Not sure how accurate it will be though.
Old 09-14-2015, 02:52 PM
Wheel widths are generally in 1" increments. Some manufacturers measure from the inside of the lip where the tire bead lays, some measure from the outside. When a manufacturer lists a wheel in a half inch increment, they are measuring from the outside of the wheel lip/bead.
So if you measure a wheel, you really only need to get close when it comes to width, because it's usually 7, 8, 9, or 10 inches wide. Depending on the manufacturer, they may list a 8" wide wheel as 8.5".
Offset/backspacing is a more critical measurement.
Old 09-14-2015, 02:53 PM
It's for my '69. The Bandits look nice. Need to find out if they make them in 5x5.
Old 09-14-2015, 03:03 PM
It's not easy to top the look of Rally2, but I am also thinking Billet Steelies in Flat Black or Flat Green.
Old 09-14-2015, 05:19 PM
No Bandits in 5x5 or what some call 5x127.
Here's a couple alternatives though:
http://www.ebay.com/itm/18x8-Gray-US...ce6bde&vxp=mtr
http://www.ebay.com/itm/1-18x8-B-G-R...c63a46&vxp=mtr
http://www.ebay.com/itm/18x8-Ridler-...a90ba0&vxp=mtr
http://www.ebay.com/itm/18x8-Gray-Bo...34a194&vxp=mtr
http://www.ebay.com/itm/18x8-Gray-Wh...5b476e&vxp=mtr
http://www.ebay.com/itm/18x8-Black-W...c0bd13&vxp=mtr
http://www.ebay.com/itm/18-American-...c88349&vxp=mtr
http://www.ebay.com/itm/Boss-338-Sup...9e594b&vxp=mtr
All are in the $150-$190 range, and this is just a quick search. 17s are less expensive, but not by much. You can search by size, Google, Summit, eBay, and can get pretty good ideas what they will look like if you go Google images.
Old 09-15-2015, 01:50 AM
The prices are right but too flashy for me.
I like the understated look of Circle Racing Billets. On the top two photos and here is another:
Old 09-15-2015, 07:46 AM
I was just throwing those out there as an example, and are many more. Crazy how wheels all of a sudden became affordable again!
I like the Circle Racing ones too, though in general, I think they look best on pre-'64 cars. Shame the Bandits don't come in 5x5, that I think fits the car very well.
So B-bodies and wagons are all 5x5 pattern?
Old 09-15-2015, 08:21 AM
A spoke wheel I think is hard to beat, and pretty much anything that looks good on a 68-72 Tempest, LeMans, GTO, etc, will look good on that wagon. That Rod Works silver wheel isn't a bad option, it's not as open as some of the others, and is a painted/clear coat wheel, low maint.
Check out some of these examples:
ID:	408152   Click image for larger version
ID:	408154   Click image for larger version
ID:	408155   Click image for larger version
Old 09-15-2015, 08:37 AM
The Champ's Avatar
Summit has the Wheel Vintiques 12 series smoothies in a 5x6, 17x8 with 4.5" BS:
http://www.summitracing.com/parts/wv...5042/overview/
Old 09-15-2015, 09:09 AM
Wow, those are $220 a wheel!
Old 09-15-2015, 11:39 AM
A "vented" or painted GM OE wheel would look more period-correct. So to achieve that stock look with 17s or 18s, it's going to be $200ea for a heavy 40lb steel wheel by Wheel Vintiques or $500ea for a 30lb billet version by Circle Racing. That is just the price of custom, small batch manufacturing in the US these days.
Old 09-15-2015, 05:23 PM
Period correct? Didn't 68-up get rally IIs? I would think if you wanted to go that route, you could do rally Is, Year One has them for 5x5 (dual pattern actually) in 17x8, all the trim for $1k.
Centerline billet wheels start at $300, and can get deals too. The Vintage Comp series don't look bad, thought I saw them for 17x8 on sale for $250ea.
Billet wheel are a polishing nightmare IMO, and they go out of round after every pot hole. Ask me how I know.
I dunno, think you may be better off just paying for 15" tires, be less expensive anyway. Wheels are a funny thing, everyone has their' own opinion on what looks good, I was just trying to help, give ideas.
Old 09-15-2015, 10:01 PM
The Champ's Avatar
Yup...
And I'm looking at them for my '64 GTO so that I can continue to run my poverty caps...
I'd like to find a lower cost alternative, but haven't found one yet.
But if I paint the "redline" on the rim, I don't have to pay for expensive redline tires in the future (my last set ran an average of $250.00 per tire, plus shipping, mounting and balancing for a pair of 235 and 255/60/15's.
Old 09-15-2015, 11:49 PM
Appreciate the feedback. I guess my point was that painted steelies - billet or steel- blend into the car and factory appearance better. 17 or 18 rally 2s would be my second choice but since I don't want to repaint or restore the exterior of this wagon, they will probably look good and too tall if that makes any sense. I had not thought about the bending issue of billet, will check that out. Having recently dropped $230 a tire on Coker G70 redlines for my GTO, I also want to be done with overpriced and underperforming 14 or 15" tires.
