Old 11-04-2015, 07:44 PM
pontiacman63383 pontiacman63383 is offline
Default Wrong motor mounts?
So motor should be coming back from the machine shop any day now and i'm getting the engine bay ready. Here where my problem comes in. This is a 69 custom S. Originally it was in inline 6 but im dropping in a 400. The frame was shot when I got it so I swapped the frame. The frame is out of a 72 GTO or so I was told. The trouble is I ordered new mounts for a 69 GTO from napa, just cheap ones for now. They seem to be to small for the frame mounts or the frame mounts are to big. So my question is which is wrong?
Heres the frame mounts I have
and here is the engine mounts up agents the frame mounts. The frame mounts are about a 1/4" to wide.
So is it the cheap mounts, the frame mounts or the fact that they are for a 69 instead of a 72?
Old 11-04-2015, 08:17 PM
Gary H's Avatar
Gary H Gary H is offline
Default Frame mounts
Your frame mounts are wrong. Not for a V-8 Pontiac, but I'm not sure what they are for.
Old 11-04-2015, 09:29 PM
Need Pontiac A body V8 frame brackets, have several pair. $80 shipped
Old 11-05-2015, 12:16 AM
68pongto's Avatar
68pongto 68pongto is offline
Those are 6 cyl. frame mounts. You need 8 cyl. frame mounts.
Old 11-05-2015, 07:50 AM
That's what I was thinking. Thanks for the info guys.
Old 11-10-2015, 10:11 PM
MD79TA MD79TA is offline
If you pick up this month hot rod magazine it has a page on pontiac motor mounts
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
1979 400 Block, 1970 Heads, Unknown Cam, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base SOLD
1968 GTO convertable project. 400 auto with air. west coast car . Not started in 15 ..update now running (around block spinning tires all the way. Have a lot of cosmetic work to do winter of 17/18
1969 GTO 400 4 Speed this a complete project. Rebuild will start in spring of 2017. SOLD
Old 12-13-2015, 04:17 PM
1NC Again 1NC Again is offline
PM sent
