Old 11-24-2015, 08:23 PM
grd777 grd777 is offline
Default 5 c heads
have a set of 5 c heads , what info can I get on these and what year car are they from
Old 11-24-2015, 09:11 PM
johnta1 johnta1 is online now
Start here: Head Codes
Old 11-25-2015, 05:40 PM
thanks , still not sure what year thease heads came on
Old 11-25-2015, 09:19 PM
RAIVJUMB's Avatar
RAIVJUMB RAIVJUMB is offline
If you look further on there they should be 74-5 and the diagram shows where the date will be located on them so you can find the date they were cast.
69 GTOx2
69 Judge CR 4SPD
70 RAIV Auto Judge
71 GT-37:usa2
71 T/A WHT AUTO
71 T/A LB 4SPD
72 T/A WHT 4spd
74 SD T/A Admiralty Blue Auto
others that reside in the barn too
Old 11-25-2015, 11:06 PM
5C's were cast during the '75 model year up into mid February of '75 when they were replaced by 6X's.
Years ago, when I had a core 400 engine deal going, I pulled an original assembled '75 400 with a 5C and 6X head that both dated in mid to late Feb '75
Old 11-25-2015, 11:36 PM
how do they rate against the other heads
Old 11-26-2015, 12:30 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
They are basically the same as a 6x head. Good heads.
Old 11-26-2015, 03:20 AM
Basically all Pontiac heads are the same. If you want a good heads, Iron heads you buy any 2 bbl head & put the work you would have in them. The 2 bbl heads usually haven't been beat up as much & once you put the bigger valves in them & port them they will good heads for just about any engine. It all depends how much work you put into them. Get good port work & good big valve with new guides springs & rockers & you can have a good set of iron heads fro a reasonable amount.
