Old 09-24-2015, 10:59 PM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
So I had these shift rods gold cadmium plated in 07, yes 2007! Long slow project. Anyway, they sat on the tranny and collected dust. Over time they ended up looking like this. You can see how they only discolored on the tops.
I ended up reblasting them and painting them cast grey. Not ideal but will last much longer.
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
  #402
Old 09-25-2015, 04:53 AM
bkmont's Avatar
bkmont bkmont is offline
Me minus you is such a lonely ride.....
  #403
Old 09-25-2015, 07:42 AM
NYGTO's Avatar
NYGTO NYGTO is offline
$3799?!!! I'll take it! :--) Okay seriously, the car looks great. Glad to see you making progress.
  #404
Old 09-25-2015, 12:41 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
Car is a work of art. Beautiful job.
  #405
Old 11-28-2015, 03:40 PM
GOAT WHORE's Avatar
Been getting a lot done on the car a little at a time. Here is an example. Sand blast tiny screws, paint them and install on restored blower motor.
Hope I don't see this again anytime soon as fenders are scheduled to go on tomorrow.
Going to try and post some other progress tonight if time allows.
  #406
Old 11-29-2015, 05:53 AM
dataway's Avatar
dataway dataway is offline
Oh jeez ... great idea on the bolts ... for years I've holding them in my hand in those big ass gloves and doing them one at a time.
JohnnyB
  #407
Old 11-29-2015, 10:56 PM
GOAT WHORE's Avatar
Finding and cleaning the correct bolts (some got primer on them), going thru pictures to verify where they went etc..... Took half a day but got one fender on. Went great as we already and the shims marked as to where they went and we also had 1/8" alignment holes to line the fender up right where it should go.
  #408
Old 11-30-2015, 08:20 AM
NYGTO's Avatar
Looking at those pictures makes me want to go down to my local Pontiac dealer and order one! Your car looks fantastic.
  #409
Old 11-30-2015, 08:48 AM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
Looking good GW. More pics please . When you have time could you post a few pictures of where you drilled the 1/8th inch holes for alignment? Sorry to see the cadmium plating eroded. I installed a complete front end on the 68 442 only to watch the finish do the exact same thing over a period of time, prior to getting back on the road. Glad to see the progression. As always your work is second to none!
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
  #410
Old 11-30-2015, 07:21 PM
GOAT WHORE's Avatar
Charles, here's some shots if the 1/8" holes we drilled to realign stuff up.
Back of fender to cowl.
Front of fender to core support.
At door jamb.
  #411
Old 11-30-2015, 07:25 PM
GOAT WHORE's Avatar
Also did the doors and decklid this way. Here is a shot of a door hinge.
And a shot of how we kept all the bolts and shims in order when removed from mock up.
  #412
Old 11-30-2015, 07:30 PM
GOAT WHORE's Avatar
Took a while and some help from fellow PY members for me to figure out the orientation of the inner fender splash shields. I had no picture of the lower ones. After some debate on how they came from the factory I am convinced they were installed a couple of different ways. I went with the one that made the most sense to me and that is shown in the picture below.
The upper shields I had a picture if and although I believe they were also installed from the factory a couple of ways the picture below shows how mine came.
  #413
Old 11-30-2015, 07:39 PM
GOAT WHORE's Avatar
Here is a shot of the restored tilt column that will be going into Nana's car. It is not the original to the car as it did not come with a tilt wheel.
Interesting bit of trivia is that the ignition switch found on the column (green thingy in pict) is different from tilt to standard column. On a standard ignition when you turn the key it pushes on the rod that actuates the ignition, on the tilt column it pulls.
And finally a shot of the Dynamat I installed under the dash on the cowl for noise and heat reduction, along with the restored heater box.
  #414
Old 11-30-2015, 08:46 PM
Engine-Ear's Avatar
I'm late to the party but what a great saga!
RediRad circuit designs, branding and intellectual property are for sale.
Serious inquiries only.
  #415
Old 11-30-2015, 09:33 PM
You're really doing a wonderful job with the car GW.
Old 11-30-2015, 11:04 PM
Your doing a great job & the car looks great. Keep it coming.
  #417
Old 11-30-2015, 11:48 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Looking good Greg! Can't wait to see it on the road!
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
  #418
Old 12-06-2015, 09:01 PM
GOAT WHORE's Avatar
More progress!
  #419
Old 12-21-2015, 03:56 PM
GOAT WHORE's Avatar
  #420
Old 12-21-2015, 03:57 PM
GOAT WHORE's Avatar
