Old 12-21-2015, 11:16 AM
edvisme edvisme is offline
I haven't read through each post on this one. I found this out just this past weekend. 1970 Firebird accelerator pedal and throttle cables are one year only. Ames was the only place I could find a new replacement cable. The mounting at the pedal is what makes it a one year only piece.
  #242
Old 12-21-2015, 12:13 PM
It's in there but for the carb end.
The carb end uses a stud instead of a ball connector.
So you would have found that out also with a 71-newer.
(if carb is original)
  #243
Old 10-10-2016, 11:15 AM
22687's Avatar
22687 22687 is offline
Default Door glass?
Came across this one this morning in the 1967-76 parts manual. At first I thought maybe it was for a different tint but no because the clear glass is also listed different for 1970. Anybody know any more about this?
  #244
Old 10-10-2016, 12:06 PM
FunctionalShaker FunctionalShaker is offline
If I remember correctly, there's an extra hole in the 70 glass for additional hardware. When I get home I'll have a look.
  #245
Old 10-10-2016, 12:21 PM
22687's Avatar
Thanks for the reply. I was just double checking the number on a driver side NOS glass that's available when I noticed it. Didn't know what the difference might be and thought it might be a useful add to the one year only list.
  #246
Old 10-10-2016, 01:58 PM
Verified. Later glass has an extra hole at the bottom back of the glass for the rear up stop. Not sure when they went from 7 to 8 holes.
  #247
Old 10-10-2016, 11:11 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
While restoring my 70 and 71 TA steering intermediate shafts, I noticed that they are clocked differently. The 70 shaft is one year only.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
  #248
Old 10-11-2016, 03:28 PM
NOT A TA NOT A TA is offline
70 pedal, stainless trim was not factory installed on this one which came out of an Esprit.
John Paige
Lab-14.com
  #249
Old 10-06-2017, 09:40 PM
Formulabruce's Avatar
Lets have a Visual on Another Part of a '70 thats different. Im not really relating this to the "two Holes" for dual door switches on the DS, Im talking about the "BUMP" the holes are on. This "Body" form from Fisher is NOT on any models past 1970, that I have seen. Just parted a 09A '71 model, and its flat, so are all the rest I checked. SO .. I found this even more interesting than the obvious... ones on Quarter and package tray, etc..
Name:	1970 door Jams.jpg
  #250
Old 10-07-2017, 07:36 PM
Transamric's Avatar
Must be a very early deal only. Two '70's here right now and both are flat like the '71 you examined.
BTW, both '70's are May '70 Van Nuys.
  #251
Old 10-08-2017, 01:03 AM
Both cars here are Norwood cars... ( 03 March and 04 April ) HMm.. I know Fisher had a plant there in CA, I wonder if the Body molds were different. Thanks for your Input
Transamric !!
  #252
Old 10-08-2017, 07:25 AM
GRNMTGOAT's Avatar
GRNMTGOAT GRNMTGOAT is offline
Bruce,mine is 05B Norwood,flat both sides.
1970 T/A RA3 #'s match.
  #253
Old 10-08-2017, 10:59 AM
May Van Nuys here, both sides are flat.
There was also talk somewhere about floor plugs and how rear plugs disappeared from production by this time. However they are present in my May Van Nuys car.
Like Formulabruce is thinking, and from what I've seen on other brands, I think the West coast cars differ in quite a few areas verses the Norwood cars.
  #254
Old 10-08-2017, 09:38 PM
Only one of mine is in the garage right now; 04D Norwood, has the bump Bruce noted on the right hand side cowl outer, but it's flat on the left hand side. Must have been built during the "transition".
I had never noticed that before...
  #255
Old 10-09-2017, 02:48 AM
Transamric's Avatar
Guess I need to go check the right sides, was focusing on the left before.
  #256
Old 10-09-2017, 09:18 PM
Here's one for the experts. The license plate bracket on the left (labeled "A") is the original that I just removed from the 04D '70 Norwood car. The one on the right was in my spare parts stash, and matches another spare I have. Both likely came from '70 models, as that's about all I've ever had.
The one on the right (labeled "B") has revised cutouts in the main stamping that enable access to the mounting studs even when the plate bracket is in the up position. Typical of GM, they both have the same part number stamped into them, even though there was clearly a design change.
I suspect the one labeled "A" was an "early" style, and the one labeled "B" was the later style. Anybody else have one like "A", and if so when was the car built?
Name:	Two 70 License Plate Brackets.jpg
  #257
Old 10-09-2017, 09:28 PM
Mine is like "B" pictured and is a May Van Nuys build.
  #258
Old 10-09-2017, 09:59 PM
" A" is "probably " correct for up to April. The Mach car here has the Studs as part of the License plate holder ( type "A" ) and the April car has the cut outs, which used Bolts . Both had never been apart before in that area. I am bettering on a "parts change Pick order" due to redesign and possibly a different manufacture supplier. This could keep the PN the same easy enough.
This could be interesting in a concourse judging ... Hehe "Lower the Plate Sir " hehe
  #259
Old 10-10-2017, 12:59 PM
mlewisariz mlewisariz is offline
My 70 is a Van Nuys built (06B) ,both sides flat.
1970 Trans Am RAIII 4/spd Blue/Blue Van Nuys built
1977 Can AM 400ci Sunroof car
1973 Grand Prix 400 A/T (Parting out)
  #260
Old 11-22-2017, 04:58 AM
I had the chance to get up close with the "Museum" 1970 Pontiac Formula 400 at MACN , a few days ago. It is an April car.. and Norwood...I was Not expecting to see it, but thats 5 now ...I have seen. This car has the taped up floor lights
Name:	1970 Museum 400 formula.jpg
