Old 12-23-2015, 07:56 PM
Bermuda Blue Bermuda Blue is offline
Default Fan shroud application
There are 2 different part numbers for fan shrouds
9795194
9795359
After some searching it is unclear what the applications are. Some say the difference is HD cooling (4 core radiator?). Have also heard one has a extra baffle. Also, it has been stated that the 5359 is simply superseded the 5194.
Now if you look at the reproduction shrouds available. You have the option of a 4 core or 3 core shroud.
I have never seen a physical difference in fan shrouds. the rubber inserts seem to be different to accommodate different radiator take thicknesses.
Can anyone shed some lite on the differences between the 2 part numbers and the 3 vs. 4 core reproduction fan shrouds.
Old 12-23-2015, 08:44 PM
dataway's Avatar
dataway dataway is offline
What year?
My parts books says the 68 PN is 9790785 for all 68 Tempest V8s.
The original shroud off my 68 GTO has the part number 9790785 - 2A-3
Books says all A body 69-72 487330
Doesn't show any alternative part numbers for Heavy Duty Cooling, or AC etc.
But these parts books can be kinda screwy sometimes.
Old 12-23-2015, 09:06 PM
This is for 1969. Sorry for the confusion.
I think the 487330 came out after 1970 and superseded both the 5359 and 5194.
Old 12-26-2015, 11:52 PM
69Y97GP 69Y97GP is offline
Default Different
The 9795194 is for a 3 core rad. 9795359 is for a 4 core. I just went thru this myself. Couldn't see a bit of difference until I put the shrouds against the radiator. The difference is on the LH edge (drivers side) where the shroud sits against the radiator along the return tank. Because the 4 core return tank is wider (fore-aft) the shroud is different to accomodate the wider tank. I'll try to post pics but my tablet doesnt cooperate sometimes. I have both so can easily show you.
Old 12-27-2015, 12:02 AM
Default More
Basically you can use the 4 core shroud on a 3 core rad but not the other way around. What really complicates things is many aftermarket 3 core rads use the wider 4 code return tank. This is how I discovered the difference.
ID:	416615   Click image for larger version
Old 12-27-2015, 12:12 AM
marxjunk marxjunk is offline
so the thin one is 4 core?
i have about 15 i need to go thru and figure them out...i need to get rid of some before they get broken...
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 12-27-2015, 12:48 AM
Held for Ransom's Avatar
Mark, I could use an original '5194.
http://www.forums.maxperformanceinc....d.php?t=509320
Old 12-27-2015, 12:57 AM
HFR>>>i have a few with no cut outs on the mount and a few with...which do you want...i will keep you #1 on the list...for a nice one...as i sort i will set you one aside...i need one for my car and prob turn the rest...
i didnt read the post but i will..i have a couple with the extra tab for the battery shield too..i think those are 69..but i will go thru and see what i have
shipping is gonna suck..because they are so big....and i double box and use lots of bubble
Mark..
The Goat whisperer
Old 12-27-2015, 12:58 AM
No cut out, '69 date casting. Thanks.
Old 12-27-2015, 01:00 AM
Smile Thin one
Yeah, the thinner is for a 4 core...or....for a replacement 3 core radiator that uses the wider 4 core inlet tank. I could use an extra of each as well if you have...
Thanks!
Old 12-27-2015, 01:11 AM
ok..let me see what i can come up with
Mark..
The Goat whisperer
Old 12-27-2015, 01:56 PM
Excellent posts. Thank you.
Old 12-27-2015, 02:00 PM
put me on the list for a 1969 9795359. this is a 4 core with battery shield. thanks.
Old 12-27-2015, 04:32 PM
ok i will
Mark..
The Goat whisperer
