Old 01-10-2016, 05:18 PM
455hota's Avatar
455hota 455hota is offline
Default Repro deck lid torque rods
I just bought a set of the repro deck lid torque rods from Ames, for my 70 TA. I made sure I ordered the right ones for a rear spoiler (FK386L, and FK386R).
I have them installed on the highest setting, and they will not keep the deck lid open 2 or 3 inches from the closed position, nor do they have enough strength to hold the decklid up in the fully open position if I place it there.
Has anyone successfully used these repro decklid torque rods on a 70 TA?
I will be calling Ames tomorrow.
Thanks for any feedback.
...Steve T.
Pontiacs:
1966 GTO 4 speed Hardtop Alabama car (Marina Turquoise w turquoise interior)
1970 TA 4 speed Canadian car (Lucerne Blue w bright blue interior)
Non Pontiacs:
1966 Lincoln Continental
1967 Ford Thunderbird
1979 Lincoln Continental (Towncar Option)
Old 01-10-2016, 06:25 PM
mklinger's Avatar
mklinger mklinger is offline
I used two of the heavier (thicker) rods with success.
There are no problems..only solutions.
Old 01-10-2016, 06:45 PM
455hota's Avatar
So you just ordered two the repro thicker rods? do you know which part number is the thicker one?
...Steve T.
Pontiacs:
Non Pontiacs:
Old 01-10-2016, 08:55 PM
FunctionalShaker FunctionalShaker is offline
Steve, were they individually labeled?
Old 01-10-2016, 09:10 PM
455hota's Avatar
I don't know they were shipped directly to my body shop.
...Steve T.
Pontiacs:
Non Pontiacs:
Old 01-11-2016, 12:29 AM
mklinger's Avatar
They were OER....ill have to check the parts number. I assume the ones you got were two different diameters..yes?
Old 01-11-2016, 08:36 AM
Formulabruce's Avatar
1. They CAN be installed backwards ( right on left side, etc), and trunk will not stay up.
2. Factory only used ONE stronger rod for 'spoiled" cars
" Long may we DRIVE !"
Old 01-11-2016, 09:59 AM
Formula8's Avatar
Formula8 Formula8 is offline
I only used one rod. It was the thicker repo. Scary as hell to install but worked fine.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 01-11-2016, 11:14 AM
yup, sure is scary.... I would never think of installing one on a painted car... Im not that good, or strong I guess. !
Old 01-11-2016, 11:20 AM
Here's a pic of how they install. I made a tool to make the job easier -- and less dangerous.
Name:	70 - 81 Torque Rods - Installed Position.jpg
Old 01-11-2016, 12:40 PM
455hota's Avatar
I will check when I get back into town. Thanks for the info.
...Steve T.
Pontiacs:
Non Pontiacs:
Old 01-11-2016, 05:55 PM
455hota's Avatar
I called Ames and they told me the right hand rod is the thicker one. And he said you can not install two thicker ones as they don't make a thick rod in the left hand configuration.
...Steve T.
Pontiacs:
Non Pontiacs:
Old 01-12-2016, 11:29 AM
Re did this a bit, and will add to the restoration thread..
Old 01-12-2016, 01:29 PM
455hota's Avatar
This weekend when I get home I will check out which side I have the thick rod installed on. Thanks.
...Steve T.
Pontiacs:
Non Pontiacs:
Old 01-12-2016, 03:15 PM
How about a pic of the tool?
I had a pic of one, but can't find it at the moment.
Old 01-12-2016, 04:37 PM
Found the pic of tool!
And a pic showing how to use it:
(shows X/A bodies, but would think the Fbirds about the same)
ID:	418029   Click image for larger version
Old 01-13-2016, 06:00 PM
Can't be the same because of the configuration.
The one I made is very simple as it's something I'll rarely use. A bolt, a nut and a couple of washers welded together. I then used a socket, long extension and a ratchet to twist it into place.
The thicker rod controls the right hand hinge.
Old 01-13-2016, 10:19 PM
Nice!
Old 01-14-2016, 08:07 AM
So, this pic has the rods backwards?
Old 01-14-2016, 08:40 AM
That depends on how they're looking at it. The thicker rod torques from the left side, but controls the right side hinge. The long end of the rod has a bend in it which makes sense to be upward when installed in the hook(s). I reinstalled mine this way and they work fine.
