Old 01-25-2016, 02:42 PM
adamo adamo is offline
So the recommended lash is .006 hot? I set mine at .006 cold. So this means my hot lash is too loose?
  #122
Old 01-25-2016, 03:20 PM
Larry Navarro's Avatar
may not be in other applications but it worked for me.
  #123
Old 01-25-2016, 03:46 PM
So I guess check my lash once the engine is nice and hot. Then subtract the difference from whatever my hot lash is to .006. Then tighten up the cold lash the difference then check the hot lash again?
  #124
Old 01-25-2016, 07:17 PM
Overkillphil's Avatar
Overkillphil Overkillphil is offline
Hot would be tighter in this scenario, perhaps too tight.(?)
___________________________________
"Objects in mirror are closer than they appear"
  #125
Old 01-25-2016, 07:33 PM
**** now I am confused lol. When I first set up my combo I set the intake at .006 cold and exhaust at .008 cold. So is that what the lash should be when it is hot?
  #126
Old 01-25-2016, 07:43 PM
Given the example from Darby, set the cold lash at .003" (instead of .006").......and after engine gets to operating temp., check the lash hot and adjust as required to achieve the lash of .006".
The thermal expansion in components can lead to confusion, as it did with me, but after thinking about it more, it made sense.
  #127
Old 01-25-2016, 08:02 PM
goatman65's Avatar
Dave mentioned that Marcel has a 271/278 @ .050 cam in his street 468, Now that sounds like my kinda street cam.
  #128
Old 01-25-2016, 11:10 PM
grandville455's Avatar
.006 x rocker ratio, so if 1.5 the hot lash shouldn't be more then .009...., all depends how much expansion when warm to achieve the desired amounts...
Darby
M/T 275/60 ET SS Drag Radial
  #129
Old 01-25-2016, 11:14 PM
My cam is 265/270 @050 , on a 110 LSA its really not that aggressive sounding to me, depends how the tune is on the idle sound. Imo
Darby
  #130
Old 01-27-2016, 07:50 AM
So with a 1.65 rocker I should have .0099 hot lash
  #131
Old 01-27-2016, 08:10 AM
Correct, you dont want to go over that, or your off the end of the ramp and not doing your valve train any good according to mike jones of jones racing cams, So set it cold get it good and warm drive around etc and see how much it opens up hot , then adjust accordingly to stay in that window or just below ,he's the one that designed my cam.
Darby
  #132
Old 01-27-2016, 11:08 AM
Steve C. Steve C. is offline
Response from Mike Jones / cam designer that Darby mentions here....
A few years ago I e-mailed him and asked if 150 lbs seat pressure might be ok with using solid roller lifters with the Comp Magnum High Lift hydraulic roller lobes number 3122 & 3120 used for the Old Faithful cam. His response:
"I don't know enough about the ramps used on those Comp lobes to be able to tell you what seat pressure you need. If they're gentle, 150# might be fine, if they're aggressive, it could take 180# on the seat. Some hydraulic roller cams have an opening ramp that's too aggressive to run with a solid roller lifter. You'll need to check with Comp, so you don't run into any issues."
Old information here:
  #133
Old 05-20-2017, 07:01 PM
Formula8's Avatar
Formula8 Formula8 is offline
Updating this post. Turns out I had the opportunity to take the heads off and took the 1000 mile old 99838's to Paul K for a pressure test. He came up with 150 lbs at 1.8" which is pretty much what the catalog specs them at. Either way, since I had things apart and the motor will likely see some higher RPM this time around, I took the opportunity to upgrade to Crower's 68380X2 spring. It turns out this spring fits perfectly in the same space as the 99383 and depending on what installed height I want to run I can use the retainers Dave set my heads up with and I have sufficient seal clearance etc. Paul K tested this spring as well and it produced 210 @ 1.8 which puts me at 470 over the nose. Crower says it should be at 197 @ 1.8 FWIW. https://www.crower.com/valve-springs...-w-damper.html
With my combination of retainers and locks, I can achieve pretty much anywhere between 173 and 210 lbs (calculated) on the seat. My coil clearance is .09" at the 1.8" installed height. What do you spring experts suggest for a seat pressure?
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
