Old 03-31-2016, 10:16 AM
dci dci is offline
Originally Posted by Chris Uratchko View Post
LOL
That doesn't even scratch the surface of bizzaro world in engine building.
Most folks in the maximum effort category are wiling to shell 6-10k on cylinder head castings and rightly so after all the work involved.
But, for the engine guy, who is responsible for making it all happen .... you think he can charge 10k labor? Rarely......... if ever.
It's so bazaar to me that people don't value your time, expertise, experience, and ability to make it all function properly, but will go out and spend $3500.00 on a carburetor or $10,000 for a bare set of heads in hopes of picking up a half a tenth.. It's been a mystery to me since I started back in 1979. I would say the only people that know how much time it takes to design, make fit together, clean, assemble and figure out why something didn't work the way that you thought are less than 1%.
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
  #142
Old 03-31-2016, 10:29 AM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Badass for sure. These guys got it going on. Hope today goes good!!!!
Mike works hard for sure and deserves these results. .
EHTTFMF
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #143
Old 03-31-2016, 12:19 PM
JSPONT's Avatar
JSPONT JSPONT is offline
LOL
Depends on the clients, us poor Pontiac folks can't pay what you guys are worth. I can not afford a build like this, but the knowledge I keep getting is good for when I hit lotto. I cheaped out and added a turbo which has it's issues too.
Good luck Mike, Marcella posted a nice number he thinks it will hit.
  #144
Old 03-31-2016, 05:21 PM
mike leech's Avatar
mike leech mike leech is offline
Well we were on our way. Now we got a little work to do
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
  #145
Old 03-31-2016, 05:45 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Tough break, Mike. I'm sure you'll get there!
Go fast, see Elvis!
  #146
Old 03-31-2016, 06:16 PM
Probird's Avatar
Probird Probird is offline
That doesn't look good Mike!
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
2024 Chief of the Pontiacs
  #147
Old 03-31-2016, 06:30 PM
mike leech's Avatar
Just a broken spring and rocker and......?
EHTTFMF!
  #148
Old 03-31-2016, 06:48 PM
Keep "Getting Up" when stuff knocks you off your feet Mike. You will get there.
  #149
Old 03-31-2016, 06:50 PM
mike leech's Avatar
Its not that big of a deal. We will go again in a week or so
EHTTFMF!
  #150
Old 03-31-2016, 07:17 PM
dci dci is offline
Mike, This is why I like you. Your never say die attitude is inspiring and motivating. All the turmoil these kinds of engines create and always surprise us with will devastate most people. You shrug it off like it's no big deal and it is a BIG deal. I know it doesn't make it any better, but Thank You for showing us how it's done. The good and the bad !!!!!
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #151
Old 03-31-2016, 07:21 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Is that hardware from last year or new?
  #152
Old 03-31-2016, 08:02 PM
mike leech's Avatar
New.
EHTTFMF!
  #153
Old 03-31-2016, 08:24 PM
mgarblik mgarblik is offline
Mike, I can't see for sure what you have for retainers, keepers, lash caps and so forth. But if you had a failure in that area, we have had great luck with the Manley lash locks. They are a 3 piece assembly and the keepers fully surround a special lash cap. The lash cap has a hard ground surface with a large surface area for the T&D roller. We run 450 lbs. on the seat and around 1100 open. We were using Manton lash locks which are like a jigsaw puzzle piece, but I like these better. Glad you didn't have any big damage.
  #154
Old 03-31-2016, 08:40 PM
twinturrbo406's Avatar
twinturrbo406 twinturrbo406 is offline
Originally Posted by mike leech View Post
No. There is not enough money in my wallet to do anything with the mains. And the rod is 2.2 per the recommendations of Bryant. We chose rigidity over small journals. The last crank was wiggling around a bit. Plus Crank throw overlap. If we were to say 2.5 inches on the main and Honda journal on the crank, The rod pin would be completely divorced from the main pin on the crank. This was deemed to be a bigger problem at our power level than bearing temp
... there's ways around that too, we run a "Large Radius Arm" design crank, and it solves this issue, even at over 6 inches of stroke on a std. BBC main ...
... Bryant is the best for sure IMO, we've had serious breakage due to engines free-wheeling past the limiter after a snapped input shaft, and it hit 10,000rpm, the crankshaft was fine ...
  #155
Old 03-31-2016, 10:01 PM
aaronman aaronman is offline
Thanks for giving us a peek into what it takes to make this type of power. This is exactly the type of post that will put more Pontiacs in the winner circle.
  #156
Old 03-31-2016, 10:32 PM
john marcella john marcella is offline
Weight breaks for being subpar are what will put Pontiacs in the Winner's Circle. Just saying. Lol.
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
  #157
Old 03-31-2016, 10:44 PM
slowbird's Avatar
slowbird slowbird is offline
Lol, some truth there
  #158
Old 04-01-2016, 12:51 AM
Jack Gifford's Avatar
Jack Gifford Jack Gifford is online now
formerly 'Pontiac Jack'
Hmm... those outer springs resemble the front suspension coils on my daily driver; I'd expect breakage if I used them as valve springs...
Seriously- are the retainers a good (snug) fit in the springs?
  #159
Old 04-01-2016, 01:14 AM
Originally Posted by Jack Gifford View Post
...Can you run less side clearance because of it?...[The oil-escape passages on the sides of the rods' big ends]
  #160
Old 04-01-2016, 07:49 AM
Chris Uratchko Chris Uratchko is offline
I keep repeating to myself....
It's great when it's good, so you have to enjoy the moments because it's not always good!! And when it's not great, it's really bad. Engines are an all or nothing proposition in this sport. Love hate relationship.
Uratchko Racing Engines
www.ure-racing.com
